  3. 3 BinarySwitch + 3 motions
4 Posts 3 Posters 1.7k Views 3 Watching
  • E
    E
    Elfnoir
    I tried to integrate 3 BinarySwitch and 3 motions around the same Arduino Pro.
    The 3 Binary are working perfectly, but on the 3 motions, they are always at '1' value, despite I move them.
    Do you know if there is a limit of the number of sensors per Ardino Pro?
    Or simply I did mistakes on the script:
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
    #include <Bounce2.h>
    #define CHILD_ID_1 101 // ID 1
    #define CHILD_ID_2 102 // ID 2
    #define CHILD_ID_3 103 // ID 3
    #define CHILD_ID_4 104 // ID 4
    #define CHILD_ID_5 105 // ID 5
    #define CHILD_ID_6 106 // ID 6
    #define BUTTON_PIN_1  3  // Arduino Digital I/O pin for button/reed switch
    #define BUTTON_PIN_2  4  // Arduino Digital I/O pin for button/reed switch
    #define BUTTON_PIN_3  5  // Arduino Digital I/O pin for button/reed switch
    #define BUTTON_PIN_4  6  // Arduino Digital I/O pin for button/reed switch
    #define BUTTON_PIN_5  7  // Arduino Digital I/O pin for button/reed switch
    #define BUTTON_PIN_6  8  // Arduino Digital I/O pin for button/reed switch
    Bounce debouncer1 = Bounce();
    Bounce debouncer2 = Bounce();
    Bounce debouncer3 = Bounce();
    Bounce debouncer4 = Bounce();
    Bounce debouncer5 = Bounce();
    Bounce debouncer6 = Bounce();
    int oldValue1=-1;
    int oldValue2=-1;
    int oldValue3=-1;
    int oldValue4=-1;
    int oldValue5=-1;
    int oldValue6=-1;
    MyMessage msg1(CHILD_ID_1,V_TRIPPED);
    MyMessage msg2(CHILD_ID_2,V_TRIPPED);
    MyMessage msg3(CHILD_ID_3,V_TRIPPED);
    MyMessage msg4(CHILD_ID_4,V_TRIPPED);
    MyMessage msg5(CHILD_ID_5,V_TRIPPED);
    MyMessage msg6(CHILD_ID_6,V_TRIPPED);
      gw.begin();
      // Setup the button
      pinMode(BUTTON_PIN_1,INPUT);
      pinMode(BUTTON_PIN_2,INPUT);
      pinMode(BUTTON_PIN_3,INPUT);
      pinMode(BUTTON_PIN_4,INPUT);
      pinMode(BUTTON_PIN_5,INPUT);
      pinMode(BUTTON_PIN_6,INPUT);
      // Activate internal pull-up
      digitalWrite(BUTTON_PIN_1,HIGH);
      digitalWrite(BUTTON_PIN_2,HIGH);
      digitalWrite(BUTTON_PIN_3,HIGH);
      digitalWrite(BUTTON_PIN_4,LOW);
      digitalWrite(BUTTON_PIN_5,LOW);
      digitalWrite(BUTTON_PIN_6,LOW);
      debouncer1.attach(BUTTON_PIN_1);
      debouncer1.interval(5);
      debouncer2.attach(BUTTON_PIN_2);
      debouncer2.interval(5);
      debouncer3.attach(BUTTON_PIN_3);
      debouncer3.interval(5);
      debouncer4.attach(BUTTON_PIN_4);
      debouncer4.interval(5);
      debouncer5.attach(BUTTON_PIN_5);
      debouncer5.interval(5);
      debouncer6.attach(BUTTON_PIN_6);
      debouncer6.interval(5);
      gw.present(CHILD_ID_1, S_DOOR);
      gw.present(CHILD_ID_2, S_DOOR);
      gw.present(CHILD_ID_3, S_DOOR);
      gw.present(CHILD_ID_4, S_MOTION);
      gw.present(CHILD_ID_5, S_MOTION);
      gw.present(CHILD_ID_6, S_MOTION);
      debouncer1.update();
      // Get the update value
      int value1 = debouncer1.read();
      if (value1 != oldValue1) {
         // Send in the new value
         gw.send(msg1.set(value1==HIGH ? 1 : 0));
         oldValue1 = value1;
      debouncer2.update();
      int value2 = debouncer2.read();
      if (value2 != oldValue2) {
         gw.send(msg2.set(value2==HIGH ? 1 : 0));
         oldValue2 = value2;
      debouncer3.update();
      int value3 = debouncer3.read();
      if (value3 != oldValue3) {
         gw.send(msg3.set(value3==HIGH ? 1 : 0));
         oldValue3 = value3;
      debouncer4.update();
      int value4 = debouncer4.read();
      if (value4 != oldValue4) {
         gw.send(msg4.set(value4==HIGH ? 1 : 0));
         oldValue4 = value4;
      debouncer5.update();
      int value5 = debouncer5.read();
      if (value5 != oldValue5) {
         gw.send(msg5.set(value5==HIGH ? 1 : 0));
         oldValue5 = value5;
      debouncer6.update();
      int value6 = debouncer6.read();
      if (value6 != oldValue6) {
         gw.send(msg6.set(value6==HIGH ? 1 : 0));
         oldValue6 = value6;
    Thanks for your support!
    • S
      Samuel235
      As far as I know of, there is no software limitation to the maximum sensor count per node. However I may be wrong so don't quote me on this, lets get some responses from more experienced guys around here.
      MySensors 2.1.1
        255 is the maximum per node. (0-254)
        • S
          Samuel235
          Of course it is,
          "A MySensor radio network can consist of up to 254 different radio nodes and each radio node can report data for 254 attached child sensors. This means that you can, in theory, manage data for up to 64516 sensors in a single radio network. If this isn't enough, you can create another parallel radio network on a different channel and there are 126 available channels."
          The above was an extract from the getting started page.
          Thank you for correcting me.
          MySensors 2.1.1
