  3. MySensors network static or dinamic?
5 Posts 2 Posters 2.3k Views 1 Watching
    Mihai
    Please let me know if the MySensors network configuration is static or dynamic.
    I mean, if I install the Gateway and two nodes and they connect as following:
    Gateway(0) - Node (1) - Node (2) (1 is repeater for 2)
    Then I change something inside the network and move the Node2 closer to the Gateway, so the configuration have to become like this:
    Gateway(0) - Node (2) - Node (1) (2 is repeater for 1)
    The network will change itself or should I erase the EEPROM of the Gateway and nodes and upload again the sketches?
    J 1 Reply Last reply
    • M Mihai
      J
      J
      jkandasa
      @Mihai MySensors network is dynamic(MY_PARENT_NODE_ID should be AUTO). You can change your node at any time.
      If your node faces 5 transmission failures It will search new parent node
        Mihai
        Thank you for the answer! I setup my nodes ID static, because I have to manually declare them inside HomeAssistant. Is it ok if I start the node with ```
        gw.begin(incomingMessage, NODE_ID, true)
        or I must do it with
        gw.begin(incomingMessage, NODE_ID, true, AUTO)
        ? (is it by default AUTO from MyConfig.h ? )
        • M Mihai
          J
          J
          jkandasa
          @Mihai You can go with,
            Mihai
            Ok, thank you.
