  3. Domoticz
  4. MQTT and Mysensors gateway All in one
12 Posts 5 Posters 6.1k Views 2 Watching
  • D
    D
    Dylano
    Best ..
    I want to build myself battery powered . I wanted to use the ESP 6288 , but has suffered from battery drain.
    Now I'm going to try mysensors .
    I would like to make an all in one gateway, mysensors and MQTT [ I do not know what it all is, but if I still start . :-) ]
    I have an Arduino envisioned as a gateway.
    Could it be one gateway for both protocols ?
    Can anyone help me on the road as a start ?
    Because when I read, it seems like the mysensors gateway , both supported?
    Thanks advance !!
    Domoticz, with a lot of working hardware, include mysensors :-)
    OpenPLI, RuneAudio, Solarmeter, etc......
    Not a great builder of software and hardware, more a user...
    Only i try to do my best :-(
    • sundberg84S
      Hi Dylano!
      If you are going to use Domoticz controller mqtt is not officially supported: http://www.mysensors.org/controller/domoticz
      You can read this thread: http://forum.mysensors.org/topic/2698/anyone-has-the-setup-domoticz-mqtt-broker-mysensors-up-n-running, http://forum.mysensors.org/topic/1968/domoticz-and-mqtt-connections.
      If you are new to MySensors i would read [Getting started].(http://www.mysensors.org/about/) and http://www.mysensors.org/controller/
      Good luck!
      • D
        D
        Dylano
        Thanks...
        I gonna try it.. [ and read... :-) ]
        Only i think it should work in Domoticz...
        But i try to start with my sensors..
        And then mqtt
        • dakkyD
          dakkyD
          dakky
          this will probably not work: domoticz is waiting for mqtt messages not matching the mqtt messages delivered by mysensors. When using domotitz ethernet or serial gateway is preferable
          Controller: Raspberry Pi 2 :: Openhab2 :: with @TimO MySensors Binding
          Gateway: Arduino MEGA 2560 R3 :: W5100 :: Ethernet GW
          Software: MySensors 2.0development
          • D
            D
            Dylano
            So i must make a gw for my sensors....[ uno is the best option? ]
            And make a gateway for MQTT?
            • dakkyD
              dakkyD
              dakky
              there is only one gateway in your network.
              you should proceed the following way:
              1. decide which controller to use
              2. build gateway, which fits to your controller
              3. build the nodes
              • D
                D
                Dylano
                Sorry, for my stupids...
                My controller is Domoticz...
                I want to build a gateway for mysensors and mqtt
                What should i make....
                I prefer 1 hardware for the 2 protocols
                Or is the best option to make 2 different gateways?
                • sundberg84S
                  You can use several gateways in Domoticz (for different protocols), just add them in hardware.
                  You need to code/create a mqtt gateway for Domoticz since this doesnt excist what i know of.
                  I think thought using two gateways for MySensors paralell might be hard... dont know if anyone done that but I guess you will recieve the message twice if you have two MySensors gateways to same controller.
                    It is possible to have several gateways; Just alter channel or base radio ir (for nrf). But one each node should only be "connected" to one gateway.
                    • D
                      D
                      Dylano
                      I think thought using two gateways for MySensors paralell might be hard... dont know if anyone done that but I guess you will recieve the message twice if you have two MySensors gateways to same controller.```
                      Do you have a how to?
                        Just set ret frequency/base-id in MyConfig.h before compiling gw/sensors.
                        • mountainmanM
                          mountainmanM
                          mountainman
                          Is it possible to use the same sensors with both ethernet and MQTT? I am currently using the ethernet gateway with vera but I would like to try MQTT/OpenHab. I would like to see the same sensors in both environments. Is the possible use the mutt gateway with vera?
                          Thanks in advance.
