  3. MySensors Raspberry port suggestions
96 Posts 14 Posters 64.5k Views 17 Watching
  • M marceloaqno
    @raptorjr Sorry, pseudo tty isn't supported. I will try to add it till the end of the day.
    raptorjrR
    raptorjrR
    raptorjr
    @marceloaqno
    What does the serial gateway do then? Can I use it as it is today with PiDomo and a RasberryPi? Or do I need to make a dedicated stand-alone serial gateway with a Arduino and a NRF?
      marceloaqno
      Code Contributor
      #42
      @raptorjr
      In the current state, serial gateway on RPi can only use a "real" serial port like /dev/ttyAMA0 (gpio pins) or (if an arduino is connected or a USB->Serial adapter) /dev/ttyACM0. To use PiDomo you will need to put an Arduino to the mix.
      raptorjrR 1 Reply Last reply
      • M marceloaqno
        @raptorjr
        raptorjrR
        raptorjrR
        raptorjr
        @marceloaqno
        Thank you. I'll have to wait for pseudo tty or for PiDome to get support for Ethernet gateway.
        M 1 Reply Last reply
        • raptorjrR raptorjr
          @marceloaqno
          marceloaqno
          Code Contributor
          @raptorjr
          I think PiDome also supports MQTT Gateway. Did you try that?
          • M marceloaqno
            @raptorjr
            raptorjrR
            raptorjrR
            raptorjr
            @marceloaqno
            I don't really understands what MQTT is and how to use it. But maybe I'll try that. Would like to see how PiDome works and if I like it better than Domoticz.
              @marceloaqno
              marceloaqno
              Code Contributor
              @raptorjr PiDome should work now (https://forum.mysensors.org/topic/2389/added-support-for-local-mysensors-rpi-direct-radio-connection).
              You need to add --my-serial-is-pty when running ./configure or uncomment the line #define MY_IS_SERIAL_PTY in mysGateway.cpp.
              raptorjrR 2 Replies Last reply
              • M marceloaqno
                raptorjrR
                raptorjrR
                raptorjr
                @marceloaqno
                Wow. That was fast work =)
                Trying it now and the /dev/ttyMySensorsGateway is created. Followed the guide in the link you provided. Everything goes great until the last step. I don't see the message "Gateway startup complete". So I don't know if I have any communication between PiDome and the gateway?
                I'll start reading forums and see if I can find a solution. Or if I missed something.
                • H
                  H
                  hawk_2050
                  @marceloaqno I've got the MysGateway configured and built to be an MQTT Gateway. I have a node (MySensors v2.01) sending temperature, humidity and voltage data to the Gateway. Looking at the stdout on the Raspberry Pi I can see that the information is being correctly received but there seems to be a problem with the published messages. I'm getting "send: Broken pipe" messages. I've copied and pasted some of the MysGateway stdout terminal output below. Do you have any insights on what might be going wrong?
                  Thanks very much
                  Sending message on topic: MyGW2out/0/255/0/0/18
                  TSF:MSG:READ,20-20-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  TSF:MSG:BC
                  TSF:MSG:FPAR REQ,ID=20
                  TSF:CHKUPL:OK
                  TSF:MSG:GWL OK
                  TSF:MSG:SEND,0-0-20-20,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  TSF:MSG:READ,20-20-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                  TSF:MSG:PINGED,ID=20,HP=1
                  TSF:MSG:SEND,0-0-20-20,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                  TSF:MSG:READ,20-20-0,s=255,c=3,t=12,pt=0,l=3,sg=0:0.5
                  Sending message on topic: MyGW2out/20/255/3/0/12
                  send: Broken pipe
                  Attempting MQTT connection...
                  MQTT connected
                  TSF:MSG:READ,20-20-0,s=2,c=0,t=23,pt=0,l=0,sg=0:
                  Sending message on topic: MyGW2out/20/2/0/0/23
                  TSF:MSG:READ,20-20-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                  TSF:MSG:SEND,0-0-20-20,s=255,c=3,t=27,pt=1,l=1,sg=0,ft=0,st=OK:1
                  TSF:MSG:READ,20-20-0,s=1,c=1,t=0,pt=7,l=5,sg=0:19.9
                  Sending message on topic: MyGW2out/20/1/1/0/0
                  send: Broken pipe
                  MQTT connected
                  TSF:MSG:READ,20-20-0,s=2,c=1,t=38,pt=7,l=5,sg=0:3319.0
                  Sending message on topic: MyGW2out/20/2/1/0/38
                  send: Broken pipe
                  MQTT connected
                  TSF:MSG:READ,20-20-0,s=0,c=1,t=1,pt=7,l=5,sg=0:58.6
                  Sending message on topic: MyGW2out/20/0/1/0/1
                  send: Broken pipe
                  MQTT connected
                  • b0rmannB
                    b0rmannB
                    b0rmann
                    feature request: logging via syslog (journald). or unbuffered debug output to stdio
                    • M marceloaqno
                      raptorjrR
                      raptorjrR
                      raptorjr
                      @marceloaqno
                      I think there may be a memory leak in the gateway. While using it as a ethernet gateway I loose about 100Mb every day, if my only node is turned on. After a few days I can't even login with SSH and need to remove the power to my Pi3 to reboot it.
                      If I turn off my node, memory usage is normal. So it seems to have something to to when messages is received/transmitted. Is there anything I can do to get more details where the problem could be?
                      I'm using the image from Domoticz where everything is installed, and have only added mysGateway.
                      b0rmannB 1 Reply Last reply
                        marceloaqno
                        Code Contributor
                        @raptorjr @hawk_2050 I'll check.
                        @b0rmann I'll do something about it.
                          @marceloaqno
                          b0rmannB
                          b0rmannB
                          b0rmann
                          @raptorjr
                          gateway running 8 days:
                          pi@pi:~$ ls -ld /proc/`pidof mysGateway`
                          dr-xr-xr-x 7 root root 0 Aug 30 22:40 /proc/3935
                          memory consumption (peak) - 22M
                          pi@pi:~$ cat /proc/`pidof mysGateway`/status
                          State:  S (sleeping)
                          Tgid:   3935
                          Ngid:   0
                          Pid:    3935
                          PPid:   1
                          TracerPid:      0
                          Uid:    0       0       0       0
                          Gid:    0       0       0       0
                          FDSize: 256
                          Groups:
                          NStgid: 3935
                          NSpid:  3935
                          NSpgid: 3935
                          NSsid:  3935
                          VmPeak:    22108 kB
                          VmSize:    22108 kB
                          VmLck:         0 kB
                          VmPin:         0 kB
                          VmHWM:      3088 kB
                          VmRSS:      3088 kB
                          VmData:      236 kB
                          VmStk:       136 kB
                          VmExe:        80 kB
                          VmLib:      4392 kB
                          VmPTE:        30 kB
                          VmPMD:         0 kB
                          VmSwap:        0 kB
                          Threads:        1
                          SigQ:   0/7339
                          SigPnd: 0000000000000000
                          ShdPnd: 0000000000000000
                          SigBlk: 0000000000000000
                          SigIgn: 0000000000001000
                          SigCgt: 0000000180004002
                          CapInh: 0000000000000000
                          CapPrm: 0000003fffffffff
                          CapEff: 0000003fffffffff
                          CapBnd: 0000003fffffffff
                          Seccomp:        0
                          Cpus_allowed:   f
                          Cpus_allowed_list:      0-3
                          Mems_allowed:   1
                          Mems_allowed_list:      0
                          voluntary_ctxt_switches:        71974874
                          nonvoluntary_ctxt_switches:     167964
                          • M marceloaqno
                            @b0rmann It should work now. Thank you for reporting this.
                            alexsh1A
                            alexsh1A
                            alexsh1
                            @marceloaqno Hi, could you please explain to me what the steps are to compile it for RPi3?
                            I went here - https://github.com/marceloaqno/Raspberry
                            Downloaded and tried to compile. The following error has come up:
                            pi@m:~/Raspberry-GW $ make all
                            make -C librf24-bcm
                            make[1]: Entering directory '/home/pi/Raspberry-GW/librf24-bcm'
                            cp utility/RPi/includes.h utility/includes.h
                            g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv7-a -mtune=arm1176jzf-s -c RF24.cpp
                            g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv7-a -mtune=arm1176jzf-s -c utility/RPi/spi.cpp
                            gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv7-a -mtune=arm1176jzf-s -c utility/RPi/bcm2835.c
                            g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv7-a -mtune=arm1176jzf-s -c utility/RPi/interrupt.c
                            g++ -shared -Wl,-soname,librf24-bcm.so.1 -pthread -Ofast -mfpu=vfp -mfloat-abi=hard -march=armv7-a -mtune=arm1176jzf-s -o librf24-bcm.so.1.0 RF24.o spi.o bcm2835.o interrupt.o
                            make[1]: Leaving directory '/home/pi/Raspberry-GW/librf24-bcm'
                            g++ -std=c++0x -g -Wall -Wextra -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -Ilibmysensors -Ilibrf24-bcm -pthread -DRASPBERRYPI_ARCH  -march=armv7-a -MMD -c -o src/Basic/PiGatewaySample.o src/Basic/PiGatewaySample.cpp
                            src/Basic/PiGatewaySample.cpp: In function ‘int main()’:
                            src/Basic/PiGatewaySample.cpp:63:15: error: ‘usleep’ was not declared in this scope
                               usleep(10000); // 10ms
                            Makefile:103: recipe for target 'src/Basic/PiGatewaySample.o' failed
                            make: *** [src/Basic/PiGatewaySample.o] Error 1
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              OK, I manage to install it finally.
                              However, again I have a problem:
                              ./configure --my-gateway=ethernet --my-rf24-channel=1 --my-rf24-pa-level=RF24_PA_MAX --my-controller-ip-address=127,0,0,1
                              when I start it I have the following in the log:
                              failed to bind
                              accept: Bad file descriptor
                                marceloaqno
                                Code Contributor
                                #55
                                Add some options to the gateway execution:
                                # ./examples_linux/mysGateway -h
                                Usage: mysGateway [options]
                                Options:
                                -h            Display a short summary of all program options.
                                -d            Enable debug.
                                -b            Become a daemon.
                                Debug is now disabled by default.
                                You can't run it as a linux daemon if debug is enabled.
                                When daemonized all messages will be print to syslog.
                                b0rmannB alexsh1A 2 Replies Last reply
                                • M marceloaqno
                                  Options:
                                  -d            Enable debug.
                                  -b            Become a daemon.
                                  b0rmannB
                                  b0rmannB
                                  b0rmann
                                  This post is deleted!
                                  • M marceloaqno
                                    Options:
                                    -d            Enable debug.
                                    -b            Become a daemon.
                                    alexsh1A
                                    alexsh1A
                                    alexsh1
                                    #57
                                    @marceloaqno Interesting. When I execute "mysGateway -h" I get the following:
                                    pi@m:~/MySensors/examples_linux $ mysGateway -h
                                    MCO:BGN:INIT GW,CP=RNNG---,VER=2.0.1-beta
                                    TSM:INIT
                                    Segmentation fault
                                    What does "Segmentation fault' mean please?
                                      marceloaqno
                                      Code Contributor
                                      @alexsh1 You must be root to run the gateway:
                                      $ sudo mysGateway
                                      It seems that you are not using the latest version, -h should have shown you the options list.
                                      alexsh1A 1 Reply Last reply
                                      • M marceloaqno
                                        $ sudo mysGateway
                                        alexsh1A
                                        alexsh1A
                                        alexsh1
                                        #59
                                        @marceloaqno I have the latest version (downloaded yesterday). Thanks very much for your help. I got the following:
                                        pi@m:~/MySensors/examples_linux $ sudo mysGateway -h
                                        TSM:INIT
                                        TSM:INIT:TSP OK
                                        TSM:INIT:GW MODE
                                        TSM:READY
                                        MCO:REG:NOT NEEDED
                                        MCO:BGN:STP
                                        MCO:BGN:INIT OK,ID=0,PAR=0,DIS=0,REG=1
                                        In Domoticz:
                                        2016-09-09 09:32:26.032 TCP: Reconnecting...
                                        2016-09-09 09:32:26.032 MySensors: connected to: 127.0.0.1:5003
                                        I added MySensors with LAN in Domoticz (port 5003), but here a problem. I can see the node and the GW communicating:
                                        GW:
                                        TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
                                        Client 0: 0;0;3;0;18;PING
                                        Starting sensor (RNNNA-, 2.0.0-beta)
                                        Radio init successful.
                                        req id
                                        send: 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,st=ok:
                                        req id
                                        req id
                                        req id
                                        Init complete, id=255, parent=0, distance=1
                                        requesting time
                                        req id
                                        requesting time
                                        req id
                                        requesting time
                                        req id
                                        requesting time
                                        req id
                                        requesting time
                                        req id
                                        The RF communication is fine, but I do not understand why Domoticz is not assigning ID.......
                                        EDIT: I can see in Domoticz in the Hardware section:
                                        MySensors Gateway with LAN interface
                                        Version: ? Setup
                                        Typically ? comes up when the controller is not recognised or not connected
                                        EDIT2:Deleted and started fresh. Unfortunately, now the log file is flooded with the following:
                                        mysGateway: Max number of ethernet clients reached.
                                        • alexsh1A alexsh1
                                          TSM:INIT
                                          TSM:INIT:TSP OK
                                          TSM:INIT:GW MODE
                                          TSM:READY
                                          MCO:REG:NOT NEEDED
                                          MCO:BGN:STP
                                          In Domoticz:
                                          GW:
                                          req id
                                          req id
                                          req id
                                          req id
                                          requesting time
                                          req id
                                          requesting time
                                          req id
                                          requesting time
                                          req id
                                          requesting time
                                          req id
                                          requesting time
                                          req id
                                          Version: ? Setup
                                          marceloaqno
                                          Code Contributor
                                          @alexsh1 There is a bug with --my-controller-ip-address, I'm not sure if it's your case, but try to avoid it.
                                          I tried Domoticz here and everything seems fine:
                                          Version: 2.0.1-beta (Setup)
                                          I recommend you to start from scratch, re-download the gateway from here:
                                          https://github.com/marceloaqno/MySensors/tree/dev-raspberrypi
