MySensors Raspberry port suggestions
@alexsh1 There is a bug with --my-controller-ip-address, I'm not sure if it's your case, but try to avoid it.
I tried Domoticz here and everything seems fine:
MySensors Gateway with LAN interface Version: 2.0.1-beta (Setup)I recommend you to start from scratch, re-download the gateway from here:
https://github.com/marceloaqno/MySensors/tree/dev-raspberrypi@marceloaqno OK, this must be the reason. I have tried the serial setup and it worked with a little tweak:
/dev/ttyUSB20 -> /dev/ttyMySensorsGatewayFor whatever reason Domoticz did not see ttyMySensorsGateway so I had to create ttyUSB20
Domoticz seems to only look for ttyUSB* interfaces. One easy trick is to run ./configure with this option so you don't have to worry with symlinking
./configure --my-serial-pty=/dev/ttyUSBMySensorsGatewayBTW @marceloaqno , what does the option --my-serial-is-pty exactly do?
So far I've been running the gateway in ethernet mode for a little while and it's working flawlessly, thanks a lot for this port. -
Exallent fix! Thanks
@marceloaqno I can confirm that the Ethernet GW works fine without --my-controller-ip-address
MAny thanks for your port and help!@alexsh1 said:
I can confirm that the Ethernet GW works fine without --my-controller-ip-addressJust a guess, I see on your previous post that you used --my-controller-ip-address=127,0,0,1 it may have been a typo here, but did you try with --my-controller-ip-address=127.0.0.1? (dots instead of commas in the IP)?
Good to know then, thanks!
BTW, I am using a nice adapter for nrf24l01+ LNA+PA designed by @GertSanders :
https://www.openhardware.io/view/17/Raspberry-Pi2-GPIO-interface-for-NRF24L01Works nicely with this port and RPi 3.
Same, I had one Pi with GertSanders adapter and now switched to the SMD versions to fit nicely in my case.
https://www.openhardware.io/view/105/MySRaspiGW
https://www.openhardware.io/view/116/MySRaspiGW-PALNAInterestingly the regular one is working better than the PA+LNA version since moved to 2.0, at least in term of sending commands. Receiving is fine. Compiling with --my-rf24-pa-level=RF24_PA_LOW helps a lot. It seems 2.0 is really more power hungry, any hope to optimize this?
Which remind me of one thing, sorry to bother you again @marceloaqno (how) is the --my-rf24-irq-pin=<PIN> working?
I installed wiringpi to get rid of the wiringPiISR: Can't find gpio program but I'm not sure if it's supposed to do anything in the long term.
I was thinking updating the design of my PCB to link BCM 24 (pin 18) to the IRQ pin of the radio module but it's unclear to me if the IRQ will ever actually be used on the gateway. -
Those are cool adapters, I need to build one for me.
@emc2 It's no bother at all!
Using nrf24 IRQ pin can give you more throughput and less chance of losing messages. It makes more sense to use if you have many sensors or need to transfer binary data (https://forum.mysensors.org/topic/3594/solar-powered-observation-nesting-box-network/).--my-serial-is-pty will simulate a serial port and create a symbolic link to it instead of using a real one.
@marceloaqno Thanks for the heads up.
I'm totally happy with the ethernet version, but as it seems @hek is in the process of writing guides on https://www.mysensors.org/build/raspberry I did a few tests.If I understood correctly (and it seems to work), to "replace" the 1.x serial gateway with the new one running the following command should work as is (/dev/ttyUSBMySensorsGateway can be renamed to /dev/ttyMySensorsGateway to be exactly as in 1.x or /dev/ttyUSB20 to bypass the symlink step)
./configure --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSBMySensorsGateway --my-rf24-pa-level=RF24_PA_LOW--my-rf24-pa-level=RF24_PA_LOW can be omitted, especially if not using a PA+LNA module, but it seems 2.0 is really more power hungry than 1.4.
If you are interested by the SMD ones, PM me your address and I will happily send you something!
@marceloaqno The mechanism for assigning the pty serial port the specified group ownership doesn't appear to be working. The pty port is always created with root:root ownership. Can you (or anyone else) confirm whether this is working for you? I'm on a Raspberry Pi 2 running Raspian Jessie. Thanks.
@emc2 I appreciate the offer for the adapter, but my country's post is a little complicated (to say the least).
@hawk_2050 /dev/ttyUSBMySensorsGateway (or any other parameter you pass to --my-serial-pty) is a symbolic link:
$ ls -lah /dev/ttyMySensorsGateway lrwxrwxrwx 1 root root 10 Sep 16 12:39 /dev/ttyMySensorsGateway -> /dev/pts/2In this case it is pointing to /dev/pts/2 but can vary, and it's the one who holds the specified group ownership.
@marceloaqno Up to you. I don't mind giving it a shot, if I send you the pcb alone it will fit in a regular letter and should not even have to go through customs etc. Worst case scenario it won't reach you.
@ericvdb That's right. I hope to add support for RFM69, Serial and software signing very soon.
To use, clone the raspberryPi port for MySensors 2.0:
git clone https://github.com/marceloaqno/MySensors.git cd MySensorsTo configure it, take a look at the options available within configure:
./configure --helpFor other options, you may have to edit the sample file example_linux/mysGateway.cpp, and uncoment what you need.
Once done, run:
make sudo make installTo run the gateway you need to be root or use sudo:
sudo msyGateway -hFor wiring, follow this guide:
https://forum.mysensors.org/topic/2437/step-by-step-procedure-to-connect-the-nrf24l01-to-the-gpio-pins-and-use-the-raspberry-as-a-serial-gateway-mysensors-1-x@marceloaqno , I assume your link for the wiring pinout behind the link is for Raspi 1 A+ with 26 pin header? Or for which version?
I'd like to try this with raspi 2 B, would you have instructions how to wire it?
Raspi2:
Raspi1:
@ikkeT yes, these are the default pins.
(SCK = 23, MISO = 21, MOSI = 19, CS = 24, CE = 22) -
Yahooo! It works, finally. I bet my problem was Raspi1 all along. I never realized the pinouts in github were for raspi with 40 pins, b+/2/3. Thanks!
@ikkeT it should also work for Raspi1, I got one running fine here.
