  3. Sensebender Micro + button
sensebendersensebender micbutton
27 Posts 5 Posters 13.4k Views 8 Watching
  • Pierre PP Pierre P
    If I undefine: //#define BATT_SENSOR 199
    it's working.
    But your code still not 100% so we have to find why.
    But... but, i think i'm making a mistake: yes i plan to use 3volts power. But, i don't want it as a sensor ! I wan't it as a battery level like the very first SensebenderMicro sketch. So... I have to undefine BATT_SENSOR ? And i will not have it set to 3Vcc=100% ?
    iotcrazyI
    iotcrazyI
    iotcrazy
    @Pierre-P you controller image looks great . What controller is it ?
    Pierre PP 1 Reply Last reply
    • iotcrazyI iotcrazy
      Pierre PP
      Pierre PP
      Pierre P
      @iotcrazy It is Jeedom, you can find some information here: http://www.mysensors.org/controller/jeedom
      It use an RPI2 if you ant to make it yourself, and a major version will come during the week !
      No quote, no forum notification (else, the mail box ring every minutes !). Thanks, and have a very good MySensors day !
      • alexsh1A
        alexsh1A
        alexsh1
        @martinhjelmare Any idea why siVolt is reporting values rounding up to either 2V or 3V in Domoticz? All I'd like to have is something like 2.9V
        • alexsh1A alexsh1
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          #24
          @alexsh1
          How are you calculating and sending it? Did you change to float? There was a bug in my original sketch.
          Make sure at least one of the operands is a float in the division.
          float siVolt = vcc / 1000.0;
          alexsh1A 1 Reply Last reply
            @alexsh1
            alexsh1A
            alexsh1A
            alexsh1
            @martinhjelmare
            Yes, it is declared as float
            void sendBattLevel(bool force)
              if (force) lastBattery = -1;
              long vcc = readVcc();
              if (vcc != lastBattery) {
                lastBattery = vcc;
              float siVolt = vcc / 1000;
            #ifdef BATT_SENSOR
                gw.send(msgBatt.set(siVolt, 2));
            It is reported as either 2.000V (battery) or 3.000V (USB) in Domoticz
            Changing siVolt to int or changing 2 in set does not change anything.
            • alexsh1A alexsh1
              @martinhjelmare
                  lastBattery = vcc;
              #ifdef BATT_SENSOR
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              You should change 1000 to 1000.0, i.e. a float. Float math will be used if any of the operands is a float.
              https://www.arduino.cc/en/Reference/Arithmetic
              • alexsh1A
                alexsh1A
                alexsh1
                @martinhjelmare Stupid me! Thanks for bringing this up - these issues are so simple, but very easy to overlook. I was about to start pulling my hair out....
