  3. Sensebender Micro + button
sensebendersensebender micbutton
27 Posts 5 Posters 13.6k Views 8 Watching
  • Pierre PP
    Pierre PP
    Pierre P
    oh...:no_mouth:
    Just need to say use "2" decimals in the message and it's ok...
    The compilation work !
    I'll try this afternoon the difference between #define BATT_SENSOR 199 and //#define BATT_SENSOR 199
    Thanks for your help !
    No quote, no forum notification (else, the mail box ring every minutes !). Thanks, and have a very good MySensors day !
    • Pierre PP
      Pierre PP
      Pierre P
      Voltage is not good (it's a new 3Vcc button cell) and batterie pourcentage is at 76%
      The battery voltage is not just minus 0.3V...
      • tbowmoT
        tbowmoT
        tbowmo
        @Pierre-P
        The measurement method is not accurate at all. It relies on an internal reference that can vary in value between boards (I can't remember the accuracy of it at the moment)
        If you don't want the battery voltage, then uncomment the #define for BATT_SENSOR in the top of the sketch, and move the float siVolt = vcc/1000; to be within the #ifdef BATT_SENSOR like:
        #ifdef BATT_SENSOR
            float siVolt = vcc / 1000;
            gw.send(msgBatt.set(siVolt, 2));
        Now it should compile, and send battery percentage as the standard sensebender sketch.
        • Pierre PP
          Pierre PP
          Pierre P
          I personaly think that it's quite good. When powered by FTDI, it found 3.00V.
          And I have only add the "//" to BATT_SENSOR and it work good.
          (you inverted the thing in the message just above).
          Thanks again for you help.
          Now i work very good and very fast. I just have to check for adding an antenna to the controller.
          • tbowmoT
            tbowmoT
            tbowmo
            @Pierre-P
            The FTDI probably supplies the board with 3.3V and not 3V..
            • alexsh1A
              alexsh1A
              alexsh1
              @Pierre-P How do you find the battery life please? I am planning to fit Sensebender with nrf24l01+ SMD and CR2032, but I wonder how long the battery is going to survive? Appreciate if depends on your sketch, but given one is conservative (i.e. no need to send temp/hum every 30-60 sec, but probably every 5-10mins or so), what's your estimate please?
              • Pierre PP
                Pierre PP
                Pierre P
                I can't tell you for the moment, I haven't check the real voltage of the CR2032 at the beginning. I'll try to make two mesure between 30 days.
                But my sketch is 1800000ms or 30min sleeping (if no-one press the button). Because it's a redundant information, my Jeedom controler have a meteo plugin who's working good. (i'll use it for the mini-night-temperature to have a message if there is glass on my car's windows).
                • Pierre PP Pierre P
                  If I undefine: //#define BATT_SENSOR 199
                  it's working.
                  But your code still not 100% so we have to find why.
                  But... but, i think i'm making a mistake: yes i plan to use 3volts power. But, i don't want it as a sensor ! I wan't it as a battery level like the very first SensebenderMicro sketch. So... I have to undefine BATT_SENSOR ? And i will not have it set to 3Vcc=100% ?
                  iotcrazyI
                  iotcrazyI
                  iotcrazy
                  @Pierre-P you controller image looks great . What controller is it ?
                  Pierre PP 1 Reply Last reply
                  • iotcrazyI iotcrazy
                    Pierre PP
                    Pierre PP
                    Pierre P
                    @iotcrazy It is Jeedom, you can find some information here: http://www.mysensors.org/controller/jeedom
                    It use an RPI2 if you ant to make it yourself, and a major version will come during the week !
                    • alexsh1A
                      alexsh1A
                      alexsh1
                      @martinhjelmare Any idea why siVolt is reporting values rounding up to either 2V or 3V in Domoticz? All I'd like to have is something like 2.9V
                      • alexsh1A alexsh1
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        #24
                        @alexsh1
                        How are you calculating and sending it? Did you change to float? There was a bug in my original sketch.
                        Make sure at least one of the operands is a float in the division.
                        float siVolt = vcc / 1000.0;
                        alexsh1A 1 Reply Last reply
                          @alexsh1
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @martinhjelmare
                          Yes, it is declared as float
                            if (force) lastBattery = -1;
                            long vcc = readVcc();
                            if (vcc != lastBattery) {
                              lastBattery = vcc;
                          #ifdef BATT_SENSOR
                          It is reported as either 2.000V (battery) or 3.000V (USB) in Domoticz
                          Changing siVolt to int or changing 2 in set does not change anything.
                          • alexsh1A alexsh1
                            @martinhjelmare
                                lastBattery = vcc;
                            #ifdef BATT_SENSOR
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            You should change 1000 to 1000.0, i.e. a float. Float math will be used if any of the operands is a float.
                            https://www.arduino.cc/en/Reference/Arithmetic
                            • alexsh1A
                              alexsh1A
                              alexsh1
                              @martinhjelmare Stupid me! Thanks for bringing this up - these issues are so simple, but very easy to overlook. I was about to start pulling my hair out....
