  3. Domoticz
  4. [SOLVED] Domoticz will no longer get my motion sensor value.
3 Posts 2 Posters 2.3k Views 1 Watching
  • ErrKE
    ErrKE
    ErrK
    wrote on last edited by ErrK
    Hi.
    Using mysensors api version 1.6.0-beta.
    I just updated my Domoticz to version 2.4312 and now my motions sensor don't change value when it shuld.
    In serial monitor i can see that my node send the update when i trigger a motion.
    send: 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:21.0
    send: 2-2-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:29.0
    send: 2-2-0-0 s=2,c=1,t=16,pt=0,l=1,sg=0,st=ok:1
    send: 2-2-0-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:20.0
    send: 2-2-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:28.0
    send: 2-2-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:27.0
    send: 2-2-0-0 s=0,c=1,t=1,pt=7,l=5,sg=0,st=ok:24.0
    But in Domoticz nothing is happening.
    I have a node with both Humidity and motion sensor it worked before the update so i think the something has changed in Domoticz.
    Any one have the same problem?
    • sundberg84S
      Do you recieve anything in the gateway? If you only send 1 (unchanged) then the status wont be updated in Domoticz.
      I had a problem when I updated that my off delay timer stopped working so I had to send both 1 (on) and 0 (off). I reported this but nothing happened. So if you are using the off delay timer in Domoticz this might be the problem...
      • ErrKE
        ErrKE
        ErrK
        I can see it in my gateway.
        I only send 1 from my node and then use a timer in Domoticz.
        Thanks @sundberg84 i will try to change to send 1 and 0.
        I have change my node and you was right. When you send both 1 and 0 then it worked.
