  3. Humidity Sensor Sketch too big for Arduino ProMini?
8 Posts 4 Posters 4.0k Views 4 Watching
    Martien Wijnands
    I bought a couple of 3.3v , 8Mhz Arduino clones;
    http://www.aliexpress.com/item/Pro-Mini-ATmega168-3-3V-8MHz-Compatible-for-Arduino-ProMini/32579105597.html
    When I try to upload the humiditysensor.ino from the samples folder, I get the error, sketch too big.
    Sketch uses 19,568 bytes (136%) of program storage space. Maximum is 14,336 bytes.
    Global variables use 655 bytes (63%) of dynamic memory, leaving 369 bytes for local variables. Maximum is 1,024 bytes.
    Have I bought the wrong boards, or can I perhaps clean the code?
    Thanks in advance!
    • F
      F
      flopp
      wrote on last edited by flopp
      That ATMega is 16k
      If you thought that you bought a ATmega with 32k then Yes you bought wrong
        Martien Wijnands
        So it's too small?
        • F
          F
          flopp
          Maximum is 16000, with 14336 left i guess that bootloader is using the rest
          • BartEB
            BartEB
            BartE
            @Martien-Wijnands yes make sure you have an ATmega326 on your board
            Like these
            or from the MySensors store 10 Pcs
              Martien Wijnands
              So, no possibility to strip down THE code? I will order the 328, but shipping takes a while :(
              F 1 Reply Last reply
              • M Martien Wijnands
                F
                F
                flopp
                @Martien-Wijnands
                What is your code?
                  Try commenting out all Serial.println. By doing that, I got the sketch from
                  Sketch uses 14,350 bytes (100%) of program storage space. Maximum is 14,336 bytes.
                  to
                  Sketch uses 12,920 bytes (90%) of program storage space. Maximum is 14,336 bytes.
                  Troubleshooting without the debug output will be a real pain though.
                  You can also try the development branch of MySensors. It consumes less flash space than 1.5.
