💬 jModule
Nice!
One question: do you have a mechanism to swap pins on the breakout boards? I know not all manufacturers use the same pinout for their I2C boards. Unfortunately...
@DavidZH as you can see on the door sensor I made two connectors for "through hole" I2C that will fit most if not all of the sensors I know: si7021, OPT3001, MAX44009, BMP/BME 180/280, ...
Else you can always solder the matching pins and connect the others using a small wire from breakout board to the right hole in the next connectors row. For SMD si7021 (blue on the picture) I only know of 1 layout. -
@Nca78
Any progress with the n-module?@Cliff-Karlsson said in 💬 jModule:
@Nca78
Any progress with the n-module?It's finally published for the main board, sensor shields will come soon.
https://forum.mysensors.org/topic/6876/nmodule -
