  3. 💬 jModule
💬 jModule
mysensorscontest2016
84 Posts 28 Posters 46.3k Views 24 Watching
  • Nca78N Nca78
    @Cliff-Karlsson said in 💬 jModule:
    @Nca78 is it possible to buy them somewhere?
    I'm not sure it's a good idea to share the dirtypcb link yet:
    • they are not tested
    • I don't even have all the scripts ready
    • they need a bit of documentation to be usable
    I will do my best to test them and share on openhardware.io next week.
    Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    @Nca78 Sorry for the nagging, but are you any closer to releasing it to dirtypcbs or similar?
    Nca78N 1 Reply Last reply
    • julissesJ julisses
      @dakipro
      The improvements:
      • 2 build options
      • no SMD elements (AMS1117 replaced by LE33 - TO92 package)
      • smaller size: the jModule and the jBoard
      • output pins in a one row
      ted
      wrote on last edited by ted
      #74
      @julisses
      Switching to TO92 elements is a great idea and will make soldering much easier to do. However, LE33 still has 0.5 mA supply current and will not be a good choice for battery powered sensors. The TO92 package will always be ON per spec sheet: http://www.st.com/content/ccc/resource/technical/document/datasheet/98/09/12/54/6e/d1/45/36/CD00000545.pdf/files/CD00000545.pdf/jcr:content/translations/en.CD00000545.pdf
      The modification I made previously used XC6206 regulator that only requires 1uA supply current. It works pretty well for my battery powered sensors. However, it does not offer a TO92 package. It will be great if someone can suggest an ultra-low supply current voltage regulator in TO92 package.
      AWIA 1 Reply Last reply
      • T ted
        @julisses
        AWIA
        AWIA
        AWI
        wrote on last edited by AWI
        #75
        @ted The lm-2936z could do the job (15 uA Q, 200mV drop-out ) or the mcp-1702 (2 uA Q, 525 mV drop-out). Both are significantly lower priced than the LE33 (at least where I get them ;-) )
          wrote on last edited by Nca78
          #76
          Yes but had some visitors during 3 weeks so progress was slow, I'll restart in 2 days and post something soon.
          @ted said in 💬 jModule:
          I would suggest MCP 1700 instead of 1702 as suggested by @AWI
          It has similar max current (250mA), ultra low quiescent current too (1.6uF) but the drop-out is way lower: below 0.2V which makes it much better for battery use especially if using 2*AA/AAA batteries. The limitation is the maximum input voltage (6V) but on battery it should not be a problem.
          But be careful MCP 1700 (like 1702) needs two 1uF capacitors at input and output, so it's not a drop-in replacement for LE33.
          Cliff KarlssonC 1 Reply Last reply
          • julissesJ
            julissesJ
            julisses
            jModule2 is ready :)
            • Nca78N Nca78
              Cliff KarlssonC
              Cliff KarlssonC
              Cliff Karlsson
              @Nca78
              Any progress with the n-module?
              Nca78N 2 Replies Last reply
                @Nca78
                @Nca78
                Sort of :) Made a temperature/humidity/light sensor and a door sensor.
                Both are very similar in size to assembled jModule, but include the sensors and CR2032 batteries. Still have to test the accelerometer child board and make scripts for it and I will put the openhardware.io page online.
                • D
                  DavidZH
                  Nice!
                  One question: do you have a mechanism to swap pins on the breakout boards? I know not all manufacturers use the same pinout for their I2C boards. Unfortunately...
                  • D DavidZH
                    Nice!
                    @DavidZH as you can see on the door sensor I made two connectors for "through hole" I2C that will fit most if not all of the sensors I know: si7021, OPT3001, MAX44009, BMP/BME 180/280, ...
                    Else you can always solder the matching pins and connect the others using a small wire from breakout board to the right hole in the next connectors row. For SMD si7021 (blue on the picture) I only know of 1 layout.
                    • D
                      DavidZH
                      Clear! I will take a deeper look into your board.
                        @Nca78
                        @Nca78
                        It's finally published for the main board, sensor shields will come soon.
                        https://forum.mysensors.org/topic/6876/nmodule
                        • DwaltD Dwalt
                          Ahh, I see now. The side facing pins are mapped as follows:
                          MCF
                          @Dwalt Thank you very much, now I understand better why the measurement of the voltage on input A0 was never good ..
