  3. [Tutorial] How to burn 1Mhz & 8Mhz bootloader using Arduino IDE 1.6.5-r5
86 Posts 20 Posters 119.4k Views 28 Watching
  • rsachocR rsachoc
    Hi there, and thanks for the tutorial. I'm trying this for the first time (the ATmega is going to be used in a slim temp node), and I'm receiving this message you mentioned:
    avrdude: Yikes! Invalid device signature.
    Double check connections and try again, or use -F to override
    You mention we should try the following:
    Maybe your chip is configured to run on an external crystal clock. I tested with two values and it succeeded. I used 10Mhz and 20Mhz as I didn't have 16 Mhz.
    Connect the crystal to pin 9 and 10
    Note: You won't need the crystal except for the first time as the new bootloader is configured to run on internal 1Mhz or 8Mhz.
    I don't quite follow what this means? Do I need a 10mhz, 16mhz or 20mhz crystal attached to the breadboard like you show in the video? If so, is that the only change I would need to make?
    FYI I'm using an Arduino clone (Buono uno r3, set at 5V)
    ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    @rsachoc Maybe I need to rephrase the sentence :)
    I meant that any crystal value will work. I didn't have 16Mhz, but I had the values 10Mhz and 20 Mhz. So I tested with 10 Mhz and I bypassed the error and didn't come again. I wanted to know further whether the crystal value is important or not. So I got another chip with preloaded arduino bootloader, and tested with 20Mhz. Also I succeeded. Thus I assume that you can use any value for this step .
    I am also using Uno clone and this is the only thing I did regarding this issue. I didn't even add capacitors to the crystal. Just put any value and test.
    rsachocR 1 Reply Last reply
    • ahmedadelhosniA ahmedadelhosni
      rsachocR
      rsachocR
      rsachoc
      @ahmedadelhosni thanks! I'm going to grab a 10mhz and 16mhz to test later this evening. Just to confirm from what you've said, I don't need the capacitors? I know in the youtube vid there were capacitors used?
      ahmedadelhosniA 2 Replies Last reply
      • rsachocR rsachoc
        ahmedadelhosniA
        ahmedadelhosniA
        ahmedadelhosni
        @rsachoc yes. I didn't also have caps and it worked :)
        • rsachocR rsachoc
          ahmedadelhosniA
          ahmedadelhosniA
          ahmedadelhosni
          wrote on last edited by ahmedadelhosni
          #24
          @rsachoc ofcourse if you have 16Mhz and capacitors like the reference video, that would be great. but if you were in a hurry and lazy to buy some, so just do it like so.
          Edit: 16* Mhz not 10 Mhz
            rsachocR
            rsachocR
            rsachoc
            @ahmedadelhosni I have some capacitors, but no crystals, so I'm picking a 10mhz and 16mhz up later today. I'll try with just the capacitors first and see how I go.
            Thanks!
            ahmedadelhosniA 1 Reply Last reply
            • rsachocR rsachoc
              Thanks!
              ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              @rsachoc edit: sorry I meant 16. Like the normal arduino board
              • rsachocR
                rsachocR
                rsachoc
                wrote on last edited by rsachoc
                #27
                C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/bin/avrdude -CC:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
                avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
                         Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                         Copyright (c) 2007-2009 Joerg Wunsch
                         System wide configuration file is "C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf"
                         Using Port                    : COM5
                         Using Programmer              : stk500v1
                         Overriding Baud Rate          : 19200
                         AVR Part                      : ATmega328P
                         Chip Erase delay              : 9000 us
                         PAGEL                         : PD7
                         BS2                           : PC2
                         RESET disposition             : dedicated
                         RETRY pulse                   : SCK
                         serial program mode           : yes
                         parallel program mode         : yes
                         Timeout                       : 200
                         StabDelay                     : 100
                         CmdexeDelay                   : 25
                         SyncLoops                     : 32
                         ByteDelay                     : 0
                         PollIndex                     : 3
                         PollValue                     : 0x53
                         Memory Detail                 :
                                                  Block Poll               Page                       Polled
                           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
                           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
                           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                         Programmer Type : STK500
                         Description     : Atmel STK500 Version 1.x firmware
                         Hardware Version: 2
                         Firmware Version: 1.18
                         Topcard         : Unknown
                         Vtarget         : 0.0 V
                         Varef           : 0.0 V
                         Oscillator      : Off
                         SCK period      : 0.1 us
                avrdude: AVR device initialized and ready to accept instructions
                Reading | ################################################## | 100% 0.02s
                avrdude: Device signature = 0x1e950f
                avrdude: erasing chip
                avrdude: reading input file "0x3F"
                avrdude: writing lock (1 bytes):
                Writing | ################################################## | 100% 0.01s
                avrdude: 1 bytes of lock written
                avrdude: verifying lock memory against 0x3F:
                avrdude: load data lock data from input file 0x3F:
                avrdude: input file 0x3F contains 1 bytes
                avrdude: reading on-chip lock data:
                C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/bin/avrdude -CC:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -Uflash:w:C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:i -Ulock:w:0x0F:m
                Reading | ################################################## | 100% 0.01s
                avrdude: verifying ...
                avrdude: 1 bytes of lock verified
                avrdude: reading input file "0x05"
                avrdude: writing efuse (1 bytes):
                avrdude: 1 bytes of efuse written
                avrdude: verifying efuse memory against 0x05:
                avrdude: load data efuse data from input file 0x05:
                avrdude: input file 0x05 contains 1 bytes
                avrdude: reading on-chip efuse data:
                avrdude: 1 bytes of efuse verified
                avrdude: reading input file "0xDE"
                avrdude: writing hfuse (1 bytes):
                avrdude: 1 bytes of hfuse written
                avrdude: verifying hfuse memory against 0xDE:
                avrdude: load data hfuse data from input file 0xDE:
                avrdude: input file 0xDE contains 1 bytes
                avrdude: reading on-chip hfuse data:
                avrdude: 1 bytes of hfuse verified
                avrdude: reading input file "0xFF"
                avrdude: writing lfuse (1 bytes):
                avrdude: 1 bytes of lfuse written
                avrdude: verifying lfuse memory against 0xFF:
                avrdude: load data lfuse data from input file 0xFF:
                avrdude: input file 0xFF contains 1 bytes
                avrdude: reading on-chip lfuse data:
                avrdude: 1 bytes of lfuse verified
                avrdude done.  Thank you.
                         Using Port                    : COM5
                         PAGEL                         : PD7
                         BS2                           : PC2
                         RETRY pulse                   : SCK
                         Timeout                       : 200
                         StabDelay                     : 100
                         CmdexeDelay                   : 25
                         SyncLoops                     : 32
                         ByteDelay                     : 0
                         PollIndex                     : 3
                         PollValue                     : 0x53
                         Memory Detail                 :
                         Hardware Version: 2
                         Topcard         : Unknown
                         Vtarget         : 0.0 V
                         Varef           : 0.0 V
                         Oscillator      : Off
                         SCK period      : 0.1 us
                avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
                         To disable this feature, specify the -D option.
                avrdude: reading input file "C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex"
                avrdude: writing flash (32768 bytes):
                Writing | ################################################## | 100% 0.00s
                avrdude: 32768 bytes of flash written
                avrdude: verifying flash memory against C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:
                avrdude: load data flash data from input file C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:
                avrdude: input file C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex contains 32768 bytes
                avrdude: reading on-chip flash data:
                Reading | ################################################## | 100% -0.00s
                avrdude: 32768 bytes of flash verified
                avrdude: reading input file "0x0F"
                Writing | ################################################## | 100% 0.02s
                avrdude: verifying lock memory against 0x0F:
                avrdude: load data lock data from input file 0x0F:
                avrdude: input file 0x0F contains 1 bytes
                Did I burn the bootloader successfully? The video indicates it should take longer, this literally took less than a second?
                • rsachocR rsachoc
                           Using Port                    : COM5
                           PAGEL                         : PD7
                           BS2                           : PC2
                           RETRY pulse                   : SCK
                           Timeout                       : 200
                           StabDelay                     : 100
                           CmdexeDelay                   : 25
                           SyncLoops                     : 32
                           ByteDelay                     : 0
                           PollIndex                     : 3
                           PollValue                     : 0x53
                           Memory Detail                 :
                           Hardware Version: 2
                           Topcard         : Unknown
                           Vtarget         : 0.0 V
                           Varef           : 0.0 V
                           Oscillator      : Off
                           SCK period      : 0.1 us
                           Using Port                    : COM5
                           PAGEL                         : PD7
                           BS2                           : PC2
                           RETRY pulse                   : SCK
                           Timeout                       : 200
                           StabDelay                     : 100
                           CmdexeDelay                   : 25
                           SyncLoops                     : 32
                           ByteDelay                     : 0
                           PollIndex                     : 3
                           PollValue                     : 0x53
                           Memory Detail                 :
                           Hardware Version: 2
                           Topcard         : Unknown
                           Vtarget         : 0.0 V
                           Varef           : 0.0 V
                           Oscillator      : Off
                           SCK period      : 0.1 us
                  ahmedadelhosniA
                  ahmedadelhosniA
                  ahmedadelhosni
                  @rsachoc I haven't burned a bootloader since I have did this topic, but I do remember that it took like 2 seconds. It was really fast.
                  You can try flashing the code to verify that it works well.
                    rsachocR
                    rsachocR
                    rsachoc
                    @ahmedadelhosni good idea, I hadn't thought of that. I'm going to have to build a slim temp node first, as my current chip is soldered to the board with no bootloader.
                    • L
                      L
                      LastSamurai
                      Hey guys, I have been building my own sensor nodes that should consume as little power as needed, so I burned a 1MHz bootloader with lower BOD settings which I found in the "slime 2AA battery node" thread (I guess this here is the same one).
                      I had some problem with the node afterwards, which I fixed by setting the baudrate of the mysensors library to 9600. It seems like that is needed (too), beside settings the upload speeds. Can you guys confirm that? If so I would suggest adding that to the (great) manual!
                      rsachocR ahmedadelhosniA 2 Replies Last reply
                      • L LastSamurai
                        rsachocR
                        rsachocR
                        rsachoc
                        #31
                        @LastSamurai I've been advised that setting the baud rate in myconfig.h is the correct way to get things working when uploading sketches to the slim node. Don't think it matters when burining the bootloader though.
                        • L LastSamurai
                          ahmedadelhosniA
                          ahmedadelhosniA
                          ahmedadelhosni
                          @LastSamurai I have faced this problem a couple of times but I don't remember how do I solve it. I just keep trying different solution. But I have to say thay I am using development branch and I don't redefine the baud rate if I don't wan't the serial debug.
                          • siodS
                            siodS
                            siod
                            wrote on last edited by siod
                            #33
                            thx for the tutorial. I perfomred every step you described, but I get errors when trying to upload a sketch:
                            And I also get this error message:
                            I tried to upload the 1MHz version
                            edit:
                            some more info form verbose mode output:
                            edit2:
                            Another problem: I could burn the bootloader on to one of my ATMega328 MCU´s but I needed to use a 16MHz Crystal when uploading for the first time. Now I can just burn and burn the bootloader again. Here ist the output:
                            But it is the only MCU that works, all the other give the "Yikes" error, also when 16MHz Crystal is connected:
                            Any explanation?
                            - bootloader burning problem solved by rebuilding the wiring.
                            - for some reason I could upload the sketch now, don´t ask me why. In the end I just reuploaded again and again...I hope I will be able to upload sketches to the next MCU´s as well
                            Sorry for asking so many questions, but after spending hours and hours of setting up a raspberry pi with openhab, MQTT Broker and MQTT Gateway I am so close to finishing my first standalone sensor and it´s not going any further, I could cry :cry:
                            still learning...
                            • D
                              D
                              drock1985
                              Maybe someone in here can help me. I can't seem to compile any sketches on my Arduino IDE and keep getting errors spit at me. I can burn the bootloader with no problem but not any sketches. Any advice/ideas please? I'm running out of things to try. :(
                              C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\derri\AppData\Local\Arduino15\packages" -hardware "F:\Users.New\Derrick\Documents\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\derri\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "F:\Users.New\Derrick\Documents\Arduino\libraries" -fqbn=MySensors:avr:apm96 -ide-version=10608 -build-path "C:\Users\derri\AppData\Local\Temp\build782cd686753c1d06c6f3cef0b1b5a173.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\derri\AppData\Local\Temp\untitled808982838.tmp\sketch_apr18a\sketch_apr18a.ino"
                              C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware "C:\Program Files (x86)\Arduino\hardware" -hardware "C:\Users\derri\AppData\Local\Arduino15\packages" -hardware "F:\Users.New\Derrick\Documents\Arduino\hardware" -tools "C:\Program Files (x86)\Arduino\tools-builder" -tools "C:\Program Files (x86)\Arduino\hardware\tools\avr" -tools "C:\Users\derri\AppData\Local\Arduino15\packages" -built-in-libraries "C:\Program Files (x86)\Arduino\libraries" -libraries "F:\Users.New\Derrick\Documents\Arduino\libraries" -fqbn=MySensors:avr:apm96 -ide-version=10608 -build-path "C:\Users\derri\AppData\Local\Temp\build782cd686753c1d06c6f3cef0b1b5a173.tmp" -warnings=none -prefs=build.warn_data_percentage=75 -verbose "C:\Users\derri\AppData\Local\Temp\untitled808982838.tmp\sketch_apr18a\sketch_apr18a.ino"
                              Board MySensors:avr:apm96 doesn't define a 'build.board' preference. Auto-set to: AVR_APM96
                              WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
                              Warning: platform.txt from core 'MySensors AVR based boards' contains deprecated recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{build.path}/{archive_file}" "{object_file}", automatically converted to recipe.ar.pattern="{compiler.path}{compiler.ar.cmd}" {compiler.ar.flags} {compiler.ar.extra_flags} "{archive_file_path}" "{object_file}". Consider upgrading this core.
                              "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++"  -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -DF_CPU=1000000L -DARDUINO=10608 -DARDUINO_AVR_APM96 -DARDUINO_ARCH_AVR         "-IF:\Users.New\Derrick\Documents\Arduino\hardware\MySensors\avr\cores\arduino" "-IF:\Users.New\Derrick\Documents\Arduino\hardware\MySensors\avr\variants\standard" "C:\Users\derri\AppData\Local\Temp\build782cd686753c1d06c6f3cef0b1b5a173.tmp\sketch\sketch_apr18a.ino.cpp" -o "nul"
                              "C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++"  -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics  -w -x c++ -E -CC -DF_CPU=1000000L -DARDUINO=10608 -DARDUINO_AVR_APM96 -DARDUINO_ARCH_AVR         "-IF:\Users.New\Derrick\Documents\Arduino\hardware\MySensors\avr\cores\arduino" "-IF:\Users.New\Derrick\Documents\Arduino\hardware\MySensors\avr\variants\standard" "C:\Users\derri\AppData\Local\Temp\build782cd686753c1d06c6f3cef0b1b5a173.tmp\sketch\sketch_apr18a.ino.cpp" -o "C:\Users\derri\AppData\Local\Temp\build782cd686753c1d06c6f3cef0b1b5a173.tmp\preproc\ctags_target_for_gcc_minus_e.cpp"
                              C:\Users\derri\AppData\Local\Temp\build782cd686753c1d06c6f3cef0b1b5a173.tmp\sketch\sketch_apr18a.ino.cpp:1:21: fatal error: Arduino.h: No such file or directory
                               #include <Arduino.h>
                              compilation terminated.
                              exit status 1
                              Error compiling for board APM Optiboot internal 1MHz noBOD 9600baud.
                              My Projects
                              2 Door Chime Sensor
                              Washing Machine Monitor
                              • sundberg84S
                                @drock1985 - please dont crosspost, see forum guidelines.
                                • J
                                  J
                                  jacikaas
                                  Could someone help me and give info what I'm doing wrong or have an idea whats happening.
                                  I use this tutorial and burn 1Mhz on Atmega328. After that I'm trying to upload sketch with FTDI and test Atmega in two ways:
                                  1. When I connect power supply 2xAA batteries (new ones)
                                  2. When I connect power supply 5V from FTDI.
                                  When I trying to upload sketch with 2xAA batteries, Atmega comes unresponsive and I get:
                                  avrdude: stk500_recv(): programmer is not responding
                                  avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xe3
                                  When I trying to upload sketch with 5V from FTDI - everything ok, example works (blink or ASCII table example).
                                  When sketch is uploaded with 5V and then I try to connect 2xAA bateries - its not working again. When I open serial monitor from arduino IDE I see blank window or few times there was strange character.
                                  I checked few times boards.txt file with fuse setting, and there is set "apm96.bootloader.extended_fuses=0x07" wich means BOD disabled. So it seems should be like that.
                                  I was trying to do all steps with different Atmega328 and also trying same steps when I burn 8Mhz bootloader. Got same result.
                                  Please give me some shots what I could test else here, becose I'm out of ideas. I'm trying to run My Slim 2AA Battery Node.
                                  Thank You! Any help would be very useful.
                                  • J jacikaas
                                    GertSandersG
                                    GertSandersG
                                    GertSanders
                                    @jacikaas
                                    From the symptoms you describe, it seems the BOD is still set at the original 4.3V.
                                    There is an Arduino sketch which allows an Arduino do check which fuses are set on another processor:
                                    http://www.gammon.com.au/forum/?id=11633
                                    This will allow you to be certain that the fuse settings on the slim node are correct.
                                    The boards.txt file is just a settings file, so better to check the fuse settings on the processor itself.
                                    J 1 Reply Last reply
                                    • GertSandersG GertSanders
                                      @jacikaas
                                      J
                                      J
                                      jacikaas
                                      @GertSanders
                                      Thank You for reply! I got the results:
                                      Atmega chip detector.
                                      Written by Nick Gammon.
                                      Version 1.18
                                      Compiled on May  9 2016 at 11:25:03 with Arduino IDE 10605.
                                      Attempting to enter ICSP programming mode ...
                                      Entered programming mode OK.
                                      Signature = 0x1E 0x95 0x0F
                                      Processor = ATmega328P
                                      Flash memory size = 32768 bytes.
                                      LFuse = 0x62
                                      HFuse = 0xDE
                                      EFuse = 0xFF
                                      Lock byte = 0xEF
                                      Clock calibration = 0xA0
                                      Bootloader in use: Yes
                                      EEPROM preserved through erase: No
                                      Watchdog timer always on: No
                                      Bootloader is 512 bytes starting at 7E00
                                      Bootloader:
                                      7E00: 0x11 0x24 0x84 0xB7 0x14 0xBE 0x81 0xFF 0xE6 0xD0 0x85 0xE0 0x80 0x93 0x81 0x00
                                      7E10: 0x82 0xE0 0x80 0x93 0xC0 0x00 0x88 0xE1 0x80 0x93 0xC1 0x00 0x86 0xE0 0x80 0x93
                                      7E20: 0xC2 0x00 0x8C 0xE0 0x80 0x93 0xC4 0x00 0x8E 0xE0 0xBF 0xD0 0x25 0x9A 0x86 0xE0
                                      7E30: 0x23 0xEC 0x3F 0xEF 0x91 0xE0 0x30 0x93 0x85 0x00 0x20 0x93 0x84 0x00 0x96 0xBB
                                      7E40: 0xB0 0x9B 0xFE 0xCF 0x1D 0x9A 0xA8 0x95 0x81 0x50 0xA9 0xF7 0xEE 0x24 0xFF 0x24
                                      7E50: 0xAA 0x24 0xA3 0x94 0xB5 0xE0 0xCB 0x2E 0xA1 0xE1 0xBA 0x2E 0xF3 0xE0 0xDF 0x2E
                                      7E60: 0x98 0xD0 0x81 0x34 0x61 0xF4 0x95 0xD0 0x08 0x2F 0xA5 0xD0 0x02 0x38 0x29 0xF1
                                      7E70: 0x01 0x38 0x11 0xF4 0x85 0xE0 0x01 0xC0 0x83 0xE0 0x83 0xD0 0x7F 0xC0 0x82 0x34
                                      7E80: 0x11 0xF4 0x84 0xE1 0x03 0xC0 0x85 0x34 0x19 0xF4 0x85 0xE0 0x9C 0xD0 0x76 0xC0
                                      7E90: 0x85 0x35 0x79 0xF4 0x7E 0xD0 0xE8 0x2E 0xFF 0x24 0x7B 0xD0 0x08 0x2F 0x10 0xE0
                                      7EA0: 0x10 0x2F 0x00 0x27 0x0E 0x29 0x1F 0x29 0x00 0x0F 0x11 0x1F 0x84 0xD0 0x78 0x01
                                      7EB0: 0x65 0xC0 0x86 0x35 0x21 0xF4 0x84 0xE0 0x86 0xD0 0x80 0xE0 0xDE 0xCF 0x84 0x36
                                      7EC0: 0x09 0xF0 0x40 0xC0 0x66 0xD0 0x65 0xD0 0x08 0x2F 0x63 0xD0 0x80 0xE0 0xE8 0x16
                                      7ED0: 0x80 0xE7 0xF8 0x06 0x18 0xF4 0xF7 0x01 0xD7 0xBE 0xE8 0x95 0xC0 0xE0 0xD1 0xE0
                                      7EE0: 0x58 0xD0 0x89 0x93 0x0C 0x17 0xE1 0xF7 0xF0 0xE0 0xEF 0x16 0xF0 0xE7 0xFF 0x06
                                      7EF0: 0x18 0xF0 0xF7 0x01 0xD7 0xBE 0xE8 0x95 0x5E 0xD0 0x07 0xB6 0x00 0xFC 0xFD 0xCF
                                      7F00: 0xA7 0x01 0xA0 0xE0 0xB1 0xE0 0x2C 0x91 0x30 0xE0 0x11 0x96 0x8C 0x91 0x11 0x97
                                      7F10: 0x90 0xE0 0x98 0x2F 0x88 0x27 0x82 0x2B 0x93 0x2B 0x12 0x96 0xFA 0x01 0x0C 0x01
                                      7F20: 0xA7 0xBE 0xE8 0x95 0x11 0x24 0x4E 0x5F 0x5F 0x4F 0xF1 0xE0 0xA0 0x38 0xBF 0x07
                                      7F30: 0x51 0xF7 0xF7 0x01 0xC7 0xBE 0xE8 0x95 0x07 0xB6 0x00 0xFC 0xFD 0xCF 0xB7 0xBE
                                      7F40: 0xE8 0x95 0x1C 0xC0 0x84 0x37 0x61 0xF4 0x24 0xD0 0x23 0xD0 0x08 0x2F 0x21 0xD0
                                      7F50: 0x32 0xD0 0xF7 0x01 0x85 0x91 0x7F 0x01 0x14 0xD0 0x01 0x50 0xD1 0xF7 0x0E 0xC0
                                      7F60: 0x85 0x37 0x39 0xF4 0x28 0xD0 0x8E 0xE1 0x0C 0xD0 0x85 0xE9 0x0A 0xD0 0x8F 0xE0
                                      7F70: 0x84 0xCF 0x81 0x35 0x11 0xF4 0x88 0xE0 0x18 0xD0 0x1D 0xD0 0x80 0xE1 0x01 0xD0
                                      7F80: 0x6F 0xCF 0x98 0x2F 0x80 0x91 0xC0 0x00 0x85 0xFF 0xFC 0xCF 0x90 0x93 0xC6 0x00
                                      7F90: 0x08 0x95 0x80 0x91 0xC0 0x00 0x87 0xFF 0xFC 0xCF 0x80 0x91 0xC0 0x00 0x84 0xFD
                                      7FA0: 0x01 0xC0 0xA8 0x95 0x80 0x91 0xC6 0x00 0x08 0x95 0xE0 0xE6 0xF0 0xE0 0x98 0xE1
                                      7FB0: 0x90 0x83 0x80 0x83 0x08 0x95 0xED 0xDF 0x80 0x32 0x19 0xF0 0x88 0xE0 0xF5 0xDF
                                      7FC0: 0xFF 0xCF 0x84 0xE1 0xDE 0xCF 0x1F 0x93 0x18 0x2F 0xE3 0xDF 0x11 0x50 0xE9 0xF7
                                      7FD0: 0xF2 0xDF 0x1F 0x91 0x08 0x95 0x28 0x2E 0x80 0xE0 0xE7 0xDF 0xEE 0x27 0xFF 0x27
                                      7FE0: 0x09 0x94 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF
                                      7FF0: 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0xFF 0x00 0x05
                                      MD5 sum of bootloader = 0xFD 0x26 0x6D 0xCC 0x38 0xDB 0xDF 0xB3 0x19 0xC2 0x21 0x79 0xBD 0x24 0x58 0x72
                                      Bootloader MD5 sum not known.
                                      First 256 bytes of program memory:
                                      0: 0x0C 0x94 0x5C 0x00 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00
                                      10: 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00
                                      20: 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00
                                      30: 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00
                                      40: 0x0C 0x94 0x88 0x00 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00
                                      50: 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00
                                      60: 0x0C 0x94 0x6E 0x00 0x0C 0x94 0x6E 0x00 0x00 0x00 0x00 0x08 0x00 0x02 0x01 0x00
                                      70: 0x00 0x03 0x04 0x07 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x01 0x02 0x04 0x08
                                      80: 0x10 0x20 0x40 0x80 0x01 0x02 0x04 0x08 0x10 0x20 0x01 0x02 0x04 0x08 0x10 0x20
                                      90: 0x04 0x04 0x04 0x04 0x04 0x04 0x04 0x04 0x02 0x02 0x02 0x02 0x02 0x02 0x03 0x03
                                      A0: 0x03 0x03 0x03 0x03 0x00 0x00 0x00 0x00 0x25 0x00 0x28 0x00 0x2B 0x00 0x00 0x00
                                      B0: 0x00 0x00 0x24 0x00 0x27 0x00 0x2A 0x00 0x11 0x24 0x1F 0xBE 0xCF 0xEF 0xD8 0xE0
                                      C0: 0xDE 0xBF 0xCD 0xBF 0x21 0xE0 0xA0 0xE0 0xB1 0xE0 0x01 0xC0 0x1D 0x92 0xA9 0x30
                                      D0: 0xB2 0x07 0xE1 0xF7 0x0E 0x94 0xEE 0x01 0x0C 0x94 0xFE 0x01 0x0C 0x94 0x00 0x00
                                      E0: 0x61 0xE0 0x8D 0xE0 0x0C 0x94 0x7E 0x01 0x61 0xE0 0x8D 0xE0 0x0E 0x94 0xB7 0x01
                                      F0: 0x68 0xEE 0x73 0xE0 0x80 0xE0 0x90 0xE0 0x0E 0x94 0xF5 0x00 0x60 0xE0 0x8D 0xE0
                                      Programming mode off.
                                      How I understand:
                                      LFuse = 0x62 this one ok
                                      HFuse = 0xDE this one ok too
                                      EFuse = 0xFF this one is not ok and thats why I get struggling, how I understand it should be 0x07
                                      Lock byte = 0xEF this one not ok too, am I right?
                                      Clock calibration = 0xA0 don't know is this one ok or not
                                      So what I should do differently for programming theese fuses?
                                      GertSandersG 4 Replies Last reply
                                      • J jacikaas
                                        @GertSanders
                                        Version 1.18
                                        LFuse = 0x62
                                        HFuse = 0xDE
                                        EFuse = 0xFF
                                        Lock byte = 0xEF
                                        Bootloader:
                                        How I understand:
                                        GertSandersG
                                        GertSandersG
                                        GertSanders
                                        @jacikaas
                                        Actually the fuse setting for EFuse is correct. In the boards.txt file only the least significant 7 bits are set (0x07), instead of all the bits (as in the result of Nic Gammon's sketch or the AVR Fuse Calculator).
                                        So 0xFF is correct.
                                        What else can be wrong ?
                                        Bad connection of the battery ?
                                        • J jacikaas
                                          @GertSanders
                                          Version 1.18
                                          LFuse = 0x62
                                          HFuse = 0xDE
                                          EFuse = 0xFF
                                          Lock byte = 0xEF
                                          Bootloader:
                                          How I understand:
                                          GertSandersG
                                          GertSandersG
                                          GertSanders
                                          @jacikaas
                                          What is the upload speed you are using now ? This is defined in the boards.txt file for each board selected.
                                          I found that if I burn the bootloader with 5V FTDI, and then try to upload sketches at 3V (with batteries connected), the internal oscillator runs at a slightly different speed.
                                          When you use higher upload speeds, this small difference can result in too high error rates.
                                          That is why I use 9600 baud to upload sketches for 1MHz mcu's.
                                          For 8MHz mcu's I use 38K4 baud, and for 16Mhz I can use 115K on Arduino Uno's, but I tend to use 56K on my 16Mhz nodes.
                                          Each time I use the approriate bootloader compiled for that clock speed.
