  3. MQTT gateway compiling error
4 Posts 3 Posters 1.5k Views 3 Watching
  • G
    G
    George Whitehouse
    Gday,
    I am new here and just got delivery of some parts. I managed to build a simple motion sensor and load the sketch which I think works.
    I have built the MQTT gateway with a UNO & Ethernet W5100 + radio. When I try to upload the sketch (with just changing the IP) I get an error compiling on both the IDE & website via codebender plugin.
    Could someone point me in the right direction?
    I am intending to use it with openhab.
    Cheers,
    George
    I
      You have to install the sketch from your local IDE. As it uses SOFT_SPI which isn't possible to enable on codebender at the moment.
      ewaldsreefE 1 Reply Last reply
        ewaldsreefE
        ewaldsreefE
        ewaldsreef
        @hek is there a recommended ide to make best use of the files? The arduino ide does not like the way the files are layer out. I plan on really getting into this I have no problem downloading a new program to make things easier. I am learning but am by no means a programmer. I relay heavily on the examples and copy /paste. Thanks for any help.
        • G
          G
          George Whitehouse
          Thanks for that, I uploaded the sketch.
          It did note, "WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'" Is this a problem?
          After uploading I am having trouble finding the MQTT broker. It does not seem to connect to the netgear router on the IP I set, 192, 168, 0, 100. The IP range is ok.
          I built it inline with the instructions and there are flashing lights on the W5100. Could someone point me in the right direction?
          Cheers,
          George
