  3. New nrf24l01+ smd
New nrf24l01+ smd
39 Posts 9 Posters 21.0k Views 9 Watching
  • AWIA AWI
    @alexsh1 don't mount it in the wrong direction...
    alexsh1A
    alexsh1A
    alexsh1
    @AWI you mean nrf24l01+? I have to check what the best fit is given I'll have a few wires
    AWIA 1 Reply Last reply
    • alexsh1A alexsh1
      AWIA
      AWIA
      AWI
      @alexsh1 this is what I did. Mount it in the same direction as the original
      alexsh1A 1 Reply Last reply
      • YveauxY Yveaux
        @alexsh1 those pliers seem to be the wrong size.... :smirk:
        alexsh1A
        alexsh1A
        alexsh1
        @Yveaux are these much better now? ;)))
        YveauxY 1 Reply Last reply
        • AWIA AWI
          alexsh1A
          alexsh1A
          alexsh1
          @AWI Now I see what you mean! Thanks for heads up - really appreciated it. This is the first time I'm dealing with this transceiver in SMD
          • alexsh1A alexsh1
            YveauxY
            YveauxY
            @alexsh1 much less of a challenge :satisfied:
            • alexsh1A alexsh1
              @GertSanders said:
              This board one is a one-trick pony. It is based on @m26872's concept of a very narrow board, but in my case I just need it to handle 2 magnetic switches.
              This is what I was looking for as I need a small board for a reed switch. Please keep us posted about your testing
              GertSandersG
              GertSandersG
              GertSanders
              @alexsh1 My very narrow board was built and tested today. It works fine, I posted info on the hardware forum.
              I must say I feel pity for this sliver of plastic and metal ...
              • GertSandersG GertSanders
                alexsh1A
                alexsh1A
                alexsh1
                Excellent! I ordered your narrow board a few days ago as I thought it would be very useful.
                One thing I can tell for sure - cutters are really well built. They are made in Japan and electrostatic safe. Most important they are not big as the ones I had before.
                • SweebeeS
                  SweebeeS
                  Sweebee
                  ordered the pro mini shields and I'm not disappointed :) As small as you can get:
                  • SweebeeS Sweebee
                    YveauxY
                    YveauxY
                    @Sweebee Very nice indeed!
                    I'm very surprised btw that you're using 2xAA to power the PIR. Will it work reliably (no false detections), even when the batteries are running out?
                    I use 2xAA to power Pro Mini + nRF and an extra AA to power the PIR. This way the supply to the PIR will stay > 3V over time.
                    SweebeeS 1 Reply Last reply
                    • YveauxY Yveaux
                      SweebeeS
                      SweebeeS
                      Sweebee
                      @Yveaux the pirs work fine if you only have interrupts with CHANGE. I don't use a sleep timer. If you wake it up every minute or so its unreliable yes. but only with interrupts from the pir it works fine. I have 10 pirs like this. Oldest one is from march 2015 and still running.
                      YveauxY alexsh1A 2 Replies Last reply
                      • SweebeeS Sweebee
                        YveauxY
                        YveauxY
                        @Sweebee Consider yourself lucky then! I have the same issues decribed here when powering using 2xAA.
                        I ditched the step-up converter as it introduces too much noise and reduces battery life. The 3xAA solution seems to work reliably though.
                        • SweebeeS Sweebee
                          alexsh1A
                          alexsh1A
                          alexsh1
                          @Sweebee
                          You have an excellent setup - I ordered those adapter as well at oshpark.
                          @Yveaux has got a point - I have been struggle to build a reliable PIR on 2xAA batteries. I have just started building it now. 1 year battery life and counting is impressive.
                          @Sweebee Would you care to share your code? Maybe there is anything there which gives us some clues though I believe this is more a hardware issue.
                          • alexsh1A alexsh1
                            @Sweebee
                            YveauxY
                            YveauxY
                            Agree. Apparently @Sweebee made modifications to the PIR (mainly to move some capacitors, judging from the photos) but maybe you did some more to improve battery life/stability?
                            • SweebeeS
                              SweebeeS
                              Sweebee
                              I removed the left capacitor since it's not needed in 3.3v hack. And I moved the right one because otherwise it didn't fit into the case.
                              My sketch:
                              #include <readVcc.h>
                              // ********** CONFIG **********************************
                                  #define NODE_ID AUTO          // ID of node
                                  #define CHILD_ID 1            // ID of sensor
                                  #define PIR_PIN 3             // Pin connected to the PIR
                                  #define MIN_V 2000            // empty voltage (0%)
                                  #define MAX_V 3200            // full voltage (100%)
                              MySensor node;
                              int oldBatteryPcnt;
                              int sentValue;
                              int forceSend = 0;
                                node.begin(NULL, NODE_ID, false);
                                node.sendSketchInfo("PIR Sensor", "1.2");
                                node.present(CHILD_ID, S_MOTION);
                                pinMode(PIR_PIN, INPUT);
                                digitalWrite(PIR_PIN, HIGH);
                                // Get PIR
                                int value = digitalRead(PIR_PIN); // Get value of PIR
                                if (value != sentValue) { // If status of PIR has changed
                                  resend(msg.set(value), 5); // Send PIR status to gateway
                                  sentValue = value;
                                // Send batterylevel
                                sendBattery();
                                // Sleep until something happens with the sensor
                                node.sleep(PIR_PIN-2, CHANGE);
                              // FUNCTIONS
                              void sendBattery() // Send battery percentage to GW
                                forceSend++;
                                int batteryPcnt = min(map(readVcc(), MIN_V, MAX_V, 0, 100), 100); // Get VCC and convert to percentage
                                if (batteryPcnt != oldBatteryPcnt || forceSend >= 20) { // If battery percentage has changed
                                  node.sendBatteryLevel(batteryPcnt); // Send battery percentage to gateway
                                  oldBatteryPcnt = batteryPcnt;
                                  forceSend = 0;
                              void resend(MyMessage &msg, int repeats) // Resend messages if not received by GW
                                int repeat = 0;
                                int repeatDelay = 0;
                                boolean ack = false;
                                while ((ack == false) and (repeat < repeats)) {
                                  if (node.send(msg)) {
                                    ack = true;
                                  } else {
                                    ack = false;
                                    repeatDelay += 100;
                                  repeat++;
                                  delay(repeatDelay);
                              YveauxY M 2 Replies Last reply
                              • SweebeeS Sweebee
                                My sketch:
                                MySensor node;
                                int oldBatteryPcnt;
                                int sentValue;
                                int forceSend = 0;
                                  // Get PIR
                                    sentValue = value;
                                  sendBattery();
                                // FUNCTIONS
                                  forceSend++;
                                    forceSend = 0;
                                  int repeat = 0;
                                      ack = true;
                                    } else {
                                      ack = false;
                                      repeatDelay += 100;
                                    repeat++;
                                    delay(repeatDelay);
                                YveauxY
                                YveauxY
                                #35
                                @Sweebee Only real difference I see compared to my sketch is that I'm using a timeout when sleeping, so the watchdog stays enabled while sleeping.
                                According to the datasheet, the AtMega power consumption is roughly 4.7uA vs 0.6uA in powerdown mode with/without watchdog enabled:
                                This is a significant difference, but when including the PIR & nRF in the total power consumption it is only a small part.
                                • SweebeeS Sweebee
                                  My sketch:
                                  MySensor node;
                                  int oldBatteryPcnt;
                                  int sentValue;
                                  int forceSend = 0;
                                    // Get PIR
                                      sentValue = value;
                                    sendBattery();
                                  // FUNCTIONS
                                    forceSend++;
                                      forceSend = 0;
                                    int repeat = 0;
                                        ack = true;
                                      } else {
                                        ack = false;
                                        repeatDelay += 100;
                                      repeat++;
                                      delay(repeatDelay);
                                  Maciej Kulawik
                                  @Sweebee I see in the sketch, that you are enabling internal pull-up on PIR input. This means, that if PIR is not detecting movement and its output is set to zero, this pull-up resistor consumes 60uA (in the best case).
                                  • M Maciej Kulawik
                                    SweebeeS
                                    SweebeeS
                                    Sweebee
                                    @Maciej-Kulawik in my calculations it is 6uA. The pirs use around 15-20 uA in sleep.
                                    M 1 Reply Last reply
                                    • SweebeeS Sweebee
                                      Maciej Kulawik
                                      @Sweebee Depending on value of these pull-up resistors. I have read that they have about 50k, so with vcc=3v you will get 60u.
                                      • M Maciej Kulawik
                                        SweebeeS
                                        SweebeeS
                                        Sweebee
                                        @Maciej-Kulawik removed the pull-up and they are all working fine :) Don't know why i have added it, in one of my oldest sketches i havent enabled it.
