  3. Slim Node Si7021 sensor example
137 Posts 18 Posters 98.3k Views 20 Watching
  • rsachocR
    rsachocR
    rsachoc
    wrote on last edited by rsachoc
    #41
    Some of my tips (noob alert) that I've gathered in my travels so far for this temp Slim node
    1. Burn the bootloader onto the ATMega328 first! (here is a guide for Arduino as ISP)
    2. Check the capacitor polarity before you solder it (the 4.7uF electrolytic capacitor, the others don't matter)
    3. I prefer using strips for the Atmega (see here) as you'll have more clearance for the capacitors which sit underneath (there is a caveat to this however, in that if you're not sure if you've got/burnt a bootloader onto the ATMega, using strips there is no going back, whereas with the chip socket, you can remove the ATMega). Update I think, for me anyway, if you're confident that the ATMega has been bootloaded successfully, I still prefer strips, however if you're unsure what you can do is use the socket and just sit it higher in it's position to get a decent clearance.
    4. The bill of materials (BOM) is here and also helps with figuring out which pieces go where
    5. Solder the capacitors, wires for Si7021 (with si7021 attached) and FTDI pins to the board first, then the strips + AtMega328p (see below), then the NRF last to the board. I found that the FTDI pins facing straight up were best for the box I was going to put it in
    6. Solder the strips to the ATMega first, then to the board
    7. Check the size of the box/fitting you are going to mount this in before you do all the above!
    8. Check that you are putting the ATMega chip the right way on the board, the notch should be facing the pins for the FTDI.
    9. Check continuity of the pins from the ATMega to the board pins underneath, I found the ATMega to strips were the most difficult to solder, and after I tested continuity I found a single pin which didn't have connection, so I added some more solder to this pin.
    10. Don't forget the resistor at R1 (I soldered this to the underside of the board, less by choice and more by the fact that I forgot about it, but I guess the preference would be the same side as the capacitors)
    11. I strongly advise buying the 3.3v ready si7021 temp sensor (here) as the modification to the 5v version is quite difficult for a newbie (the components are quite small) and you'll probably mess it up like I did.
    General soldering tips
    12) Practice soldering first, some of the joins are a little challenging and it took me a few attempts to get the hang of it
    13) Get a decent size tip, my first was a bit large
    • rsachocR rsachoc
      GertSandersG
      GertSandersG
      GertSanders
      @rsachoc As a great man once said: "most bananas grow bent, and yet everyone loves them. There is nothing strange about the diversity of routes to success"
      • rsachocR
        rsachocR
        rsachoc
        Thanks all, I'm sure I will be adding to it, as I'm now trying to compile and upload the sketch. However, I'm getting the following error:
           #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
        exit status 1
        Error compiling.
        I'm using the W5100 MQTT gateway sketch (which I believe is on the development branch), so I'm not sure if that's what's causing the error? I've tried deleting the Arduino IDE, the mysensors development branch from my PC, and reinstalling and redownloading the mysensors dev branch, but the same thing happens?
        • rsachocR
          rsachocR
          rsachoc
          OK, so it seems that it was because I was using the dev branch that I'm getting that error. I switched over to stable and the sketch compiles, although I do get a warning.
          WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
          But I also can't upload the sketch above:
          avrdude: stk500_recv(): programmer is not responding
          avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x18
          I noted above that something needed to be changed in terms of the baud rate, mine is set at 115200 in myconfig.h and I can't seem to find a reference in mysensor.h
          m26872M 1 Reply Last reply
          • rsachocR rsachoc
            m26872M
            m26872M
            m26872
            #45
            @rsachoc I sorry, but there seems to be an error in the sketch in the first post. Baud rate should be 9600 everywhere if you use the common Slim Node fuses and bootloader. Upload (board.txt), MyConfig.h (not MySensor.h since v1.5), Debug-prints and Arduino IDE serial monitor.
            • rsachocR
              rsachocR
              rsachoc
              Thanks, I've updated the sketch that I downloaded, also myconfig.h so that should be good. What do I need to select in the Arduino IDE for board type? I searched in the slim node thread and didn't see a reference to any changes?
              • rsachocR rsachoc
                m26872M
                m26872M
                m26872
                @rsachoc No changes. It is that boards.txt entry you should use.
                • rsachocR
                  rsachocR
                  rsachoc
                  #48
                  Hmmm ok, that's what I thought...still no luck, I've modified the boards.txt with the text from the slim node thread, and now it still has the same error message.
                  To confirm, my FTDI adaptor is attached to the board pins as follows:
                  FTDI <-> board
                  GND <-> first pin (i.e bottom left of board when looking at board laying long side horizontal and NRF radio on the other side)
                  CTS <-> board marked GND
                  PWR <-> board marked VCC
                  TXO <-> next up i.e. 4th pin
                  RXI <-> next up i.e. 5th pin
                  DTR <-> next up i.e. last pin
                  Other than that, I guess it may be something wrong with the way I made the board? If so, what's the best way to troubleshoot? Could it be a bad bootloader flash? Is there a way to check if the ATMega has a bootloader?
                  edit in fact, it could be because I don't have the Si7021 connected? Could this be the reason a sketch is not uploading successfully? :worried:
                  • rsachocR rsachoc
                    FTDI <-> board
                    m26872M
                    m26872M
                    m26872
                    @rsachoc Start simple. Try on a board without nRF and sensors. Remove everything in the sketch and make it to just print "Hello world" back to serial monitor.
                    • rsachocR
                      rsachocR
                      rsachoc
                      Thanks, I haven't actually built a new node, but have been double checking everything on my current node. One thing I wanted to confirm, the 4.7uf capacitor, does the negative leg have to be on the corner of the board, as this is the way I have it currently? I think looking at the board layout in the main slim node thread, it should be the positive leg on the corner and the negative leg on the side of the board (the short side of the board)?
                      • rsachocR rsachoc
                        m26872M
                        m26872M
                        m26872
                        @rsachoc I don't have it in front of me rigth now... but, there should be an arc and a super-small "+"-sign next to the positive pad. Maybe it just look like a dot.
                        • rsachocR
                          rsachocR
                          rsachoc
                          #52
                          Ok so that may be the problem then! Let me solder it the right way and see if that helps otherwise I'm going to create a bare bones slim mode as suggested
                          edit to confirm the positive leg of the capacitor goes to the positive marked plus sign hole on the board?
                          • rsachocR
                            rsachocR
                            rsachoc
                            OK so I changed the polarity of the 4.7uf capacitor and I'm still receiving the same error. So I built a barebones one without sensor and without NRF. I am still getting the same error when uploading the sketch via the FTDI adaptor. I tried uploading a sketch to a Sensebender I have and it worked fine, so that rules out the FTDI adaptor.
                            Some pics in case someone can spot something obvious.
                            http://i.imgur.com/1SV0qO2.jpg
                            http://i.imgur.com/mUp87hB.jpg
                            http://i.imgur.com/oCqcDpo.jpg
                            So I can only think that it must be related to the ATMega bootloader? In the how to burn a bootloader thread, I received the following when trying to burn the bootloader, so I assumed it uploaded correctly?
                            C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/bin/avrdude -CC:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0x05:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
                            avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
                                     Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
                                     Copyright (c) 2007-2009 Joerg Wunsch
                                     System wide configuration file is "C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf"
                                     Using Port                    : COM5
                                     Using Programmer              : stk500v1
                                     Overriding Baud Rate          : 19200
                                     AVR Part                      : ATmega328P
                                     Chip Erase delay              : 9000 us
                                     PAGEL                         : PD7
                                     BS2                           : PC2
                                     RESET disposition             : dedicated
                                     RETRY pulse                   : SCK
                                     serial program mode           : yes
                                     parallel program mode         : yes
                                     Timeout                       : 200
                                     StabDelay                     : 100
                                     CmdexeDelay                   : 25
                                     SyncLoops                     : 32
                                     ByteDelay                     : 0
                                     PollIndex                     : 3
                                     PollValue                     : 0x53
                                     Memory Detail                 :
                                                              Block Poll               Page                       Polled
                                       Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
                                       eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
                                       flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
                                       lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                       hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                       efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                       lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
                                       calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
                                       signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
                                     Programmer Type : STK500
                                     Description     : Atmel STK500 Version 1.x firmware
                                     Hardware Version: 2
                                     Firmware Version: 1.18
                                     Topcard         : Unknown
                                     Vtarget         : 0.0 V
                                     Varef           : 0.0 V
                                     Oscillator      : Off
                                     SCK period      : 0.1 us
                            avrdude: AVR device initialized and ready to accept instructions
                            Reading | ################################################## | 100% 0.02s
                            avrdude: Device signature = 0x1e950f
                            avrdude: erasing chip
                            avrdude: reading input file "0x3F"
                            avrdude: writing lock (1 bytes):
                            Writing | ################################################## | 100% 0.01s
                            avrdude: 1 bytes of lock written
                            avrdude: verifying lock memory against 0x3F:
                            avrdude: load data lock data from input file 0x3F:
                            avrdude: input file 0x3F contains 1 bytes
                            avrdude: reading on-chip lock data:
                            C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/bin/avrdude -CC:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -b19200 -Uflash:w:C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:i -Ulock:w:0x0F:m
                            Reading | ################################################## | 100% 0.01s
                            avrdude: verifying ...
                            avrdude: 1 bytes of lock verified
                            avrdude: reading input file "0x05"
                            avrdude: writing efuse (1 bytes):
                            avrdude: 1 bytes of efuse written
                            avrdude: verifying efuse memory against 0x05:
                            avrdude: load data efuse data from input file 0x05:
                            avrdude: input file 0x05 contains 1 bytes
                            avrdude: reading on-chip efuse data:
                            avrdude: 1 bytes of efuse verified
                            avrdude: reading input file "0xDE"
                            avrdude: writing hfuse (1 bytes):
                            avrdude: 1 bytes of hfuse written
                            avrdude: verifying hfuse memory against 0xDE:
                            avrdude: load data hfuse data from input file 0xDE:
                            avrdude: input file 0xDE contains 1 bytes
                            avrdude: reading on-chip hfuse data:
                            avrdude: 1 bytes of hfuse verified
                            avrdude: reading input file "0xFF"
                            avrdude: writing lfuse (1 bytes):
                            avrdude: 1 bytes of lfuse written
                            avrdude: verifying lfuse memory against 0xFF:
                            avrdude: load data lfuse data from input file 0xFF:
                            avrdude: input file 0xFF contains 1 bytes
                            avrdude: reading on-chip lfuse data:
                            avrdude: 1 bytes of lfuse verified
                            avrdude done.  Thank you.
                                     Using Port                    : COM5
                                     PAGEL                         : PD7
                                     BS2                           : PC2
                                     RETRY pulse                   : SCK
                                     Timeout                       : 200
                                     StabDelay                     : 100
                                     CmdexeDelay                   : 25
                                     SyncLoops                     : 32
                                     ByteDelay                     : 0
                                     PollIndex                     : 3
                                     PollValue                     : 0x53
                                     Memory Detail                 :
                                     Hardware Version: 2
                                     Topcard         : Unknown
                                     Vtarget         : 0.0 V
                                     Varef           : 0.0 V
                                     Oscillator      : Off
                                     SCK period      : 0.1 us
                            avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
                                     To disable this feature, specify the -D option.
                            avrdude: reading input file "C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex"
                            avrdude: writing flash (32768 bytes):
                            Writing | ################################################## | 100% 0.00s
                            avrdude: 32768 bytes of flash written
                            avrdude: verifying flash memory against C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:
                            avrdude: load data flash data from input file C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex:
                            avrdude: input file C:\Users\James\Desktop\RPi Openhab\arduino-1.6.7-windows\hardware\arduino\avr/bootloaders/optiboot/optiboot_atmega328.hex contains 32768 bytes
                            avrdude: reading on-chip flash data:
                            Reading | ################################################## | 100% -0.00s
                            avrdude: 32768 bytes of flash verified
                            avrdude: reading input file "0x0F"
                            Writing | ################################################## | 100% 0.02s
                            avrdude: verifying lock memory against 0x0F:
                            avrdude: load data lock data from input file 0x0F:
                            avrdude: input file 0x0F contains 1 bytes
                            • rsachocR rsachoc
                                       Using Port                    : COM5
                                       PAGEL                         : PD7
                                       BS2                           : PC2
                                       RETRY pulse                   : SCK
                                       Timeout                       : 200
                                       StabDelay                     : 100
                                       CmdexeDelay                   : 25
                                       SyncLoops                     : 32
                                       ByteDelay                     : 0
                                       PollIndex                     : 3
                                       PollValue                     : 0x53
                                       Memory Detail                 :
                                       Hardware Version: 2
                                       Topcard         : Unknown
                                       Vtarget         : 0.0 V
                                       Varef           : 0.0 V
                                       Oscillator      : Off
                                       SCK period      : 0.1 us
                                       Using Port                    : COM5
                                       PAGEL                         : PD7
                                       BS2                           : PC2
                                       RETRY pulse                   : SCK
                                       Timeout                       : 200
                                       StabDelay                     : 100
                                       CmdexeDelay                   : 25
                                       SyncLoops                     : 32
                                       ByteDelay                     : 0
                                       PollIndex                     : 3
                                       PollValue                     : 0x53
                                       Memory Detail                 :
                                       Hardware Version: 2
                                       Topcard         : Unknown
                                       Vtarget         : 0.0 V
                                       Varef           : 0.0 V
                                       Oscillator      : Off
                                       SCK period      : 0.1 us
                              m26872M
                              m26872M
                              m26872
                              @rsachoc Looks like you're missing the R1 resistor?
                              rsachocR 1 Reply Last reply
                              • m26872M m26872
                                rsachocR
                                rsachocR
                                rsachoc
                                @m26872 well that is probably it! I didn't even realise I needed that, oops! Sorry :disappointed: ! Let me try and get one (I think I have some already) and get soldering
                                • rsachocR rsachoc
                                  rsachocR
                                  rsachocR
                                  rsachoc
                                  It lives! Well the one node I created does at least! I'll troubleshoot it, but the problem was the R1 resistor, which I (noobishly) forgot about! But very pleased, and thanks to m26872 especially and everyone else who helped.
                                  I've updated the lessons learn post too!
                                  • rsachocR
                                    rsachocR
                                    rsachoc
                                    I just received my non-3.3v Si7021, and have now updated the lessons learnt post, as this board is tiny and I managed to mess up the soldering completely. Ordered the 3.3 ready version now, another month wait...
                                    • carlierdC carlierd
                                      @ar91 Please find the code I used in 3 different nodes. The good thing with the playground lib is that there is error message if dialog with DHT22 failed.
                                      /* Temperature, humidity and luminosity measurements.                                 */
                                      /* Version     : 1.1.6        */
                                      /* Date        : 10/01/2016                                                           */
                                      /* Modified by : David Carlier                                                        */
                                      /*                            RST |             |  A5                                 */
                                      /*                            RX  |             |  A4                                 */
                                      /*                            TX  |   ARDUINO   |  A3                                 */
                                      /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
                                      /*            DHT22 --------- D3  |             |  A1                                 */
                                      /*            Power --------- D4  | ATMEGA 328p |  A0 --------- Light dep. resistor   */
                                      /*              +3v --------- VCC |             | GND --------- GND                   */
                                      /*              GND --------- GND |  8MHz int.  | REF                                 */
                                      /*                            OSC |             | VCC --------- +3v                   */
                                      /*                            OSC |             | D13 --------- RFM69 (SCK)           */
                                      /*                            D5  |             | D12 --------- RFM69 (MISO)          */
                                      /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
                                      /*                            D7  |             | D10 --------- RFM69 (NSS)           */
                                      /*                            D8  |             |  D9                                 */
                                      /* Power = Vcc for LDR.                                                               */
                                      /* +3v = 2*AA        */
                                      #include <dht.h>
                                      #include <MyTransportRFM69.h>
                                      #include <MySigningAtsha204Soft.h>
                                      #define CHILD_ID_HUM 0
                                      #define CHILD_ID_TEMP 1
                                      #define CHILD_ID_LIGHT 2
                                      #define CHILD_ID_VOLTAGE 3
                                      #define LIGHT_SENSOR_ANALOG_PIN 0
                                      #define POWER_PIN 4
                                      //unsigned long SLEEP_TIME = 850000; // Sleep time between reads (in milliseconds) (close to 15')
                                      unsigned long SLEEP_TIME = 275000; // Sleep time between reads (in milliseconds) (close to 5')
                                      //Construct MySensors library
                                      MySigningAtsha204Soft signer;
                                      MyHwATMega328 hw;
                                      MyTransportRFM69 transport;
                                      MySensor gw(transport, hw, signer);
                                      dht DHT;
                                      MyMessage msgLum(CHILD_ID_LIGHT, V_LEVEL);
                                      MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
                                      /* Initialization        */
                                        //Get time (for setup duration)
                                        #ifdef DEBUG
                                          unsigned long startTime = millis();
                                        //Start MySensors
                                        gw.begin();
                                        //Send the Sketch Version Information to the Gateway
                                        gw.sendSketchInfo("GHAS sensor", "1.1.5");
                                        //Register all sensors to gw (they will be created as child devices)
                                        gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
                                        gw.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
                                        //Delay for DHT22
                                        delay(1500);
                                        //Print setup debug
                                        #ifdef DEBUG
                                          int duration = millis() - startTime;
                                          Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
                                      /* Main loop        */
                                        //Get time (for a complete loop)
                                        #ifdef DEBUG
                                        //Power on
                                        powerOnPeripherals();
                                        //Get DHT22 data
                                        int dht22Result = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
                                        switch (dht22Result)
                                          case DHTLIB_OK:
                                                      //Serial.println("OK,\t");
                                                      break;
                                          case DHTLIB_ERROR_CHECKSUM:
                                                      #ifdef DEBUG
                                                        Serial.println("Checksum error,\t");
                                                      break;
                                          case DHTLIB_ERROR_TIMEOUT:
                                                      #ifdef DEBUG
                                                        Serial.println("Time out error,\t");
                                                      break;
                                          case DHTLIB_ERROR_CONNECT:
                                                      #ifdef DEBUG
                                                        Serial.println("Connect error,\t");
                                                      break;
                                          case DHTLIB_ERROR_ACK_L:
                                                      #ifdef DEBUG
                                                        Serial.println("Ack Low error,\t");
                                                      break;
                                          case DHTLIB_ERROR_ACK_H:
                                                      #ifdef DEBUG
                                                        Serial.println("Ack High error,\t");
                                                      break;
                                          default:
                                                      #ifdef DEBUG
                                                        Serial.println("Unknown error,\t");
                                                      break;
                                        //Get temperature and humidity
                                        float temperature = 0;
                                        float humidity = 0;
                                        if (dht22Result == DHTLIB_OK)
                                          temperature = DHT.temperature;
                                          humidity = DHT.humidity;
                                        //Get power before luminosity to use real voltage
                                        float realVoltage = getVoltage() / 100.0;
                                        int batteryPcnt = realVoltage * 100 / 3.0;
                                        if (batteryPcnt > 100) {batteryPcnt = 100;}
                                        int lux = computeIlluminance(realVoltage);
                                        //Power off
                                        powerOffPeripherals();
                                        //Send data to gateway
                                        gw.send(msgLum.set(lux));
                                        gw.send(msgVolt.set(realVoltage, 2));
                                        //Print debug
                                        #ifdef DEBUG
                                          Serial.print(temperature, 1);
                                          Serial.print(" degC");
                                          Serial.print("   ");
                                          Serial.print(humidity, 1);
                                          Serial.print(" %");
                                          Serial.print("   ");
                                          Serial.print(lux);
                                          Serial.print(" lx");
                                          Serial.print("   ");
                                          Serial.print(realVoltage);
                                          Serial.print(" v");
                                          Serial.print("   ");
                                          Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
                                          Serial.flush();
                                        //Sleep
                                        gw.sleep(SLEEP_TIME);
                                      /* Allows to compute illuminance (in LUX) from LIGHT_SENSOR_ANALOG_PIN.               */
                                      int computeIlluminance(float realVoltage)
                                        //Get luminosity
                                        int luminosity = analogRead(LIGHT_SENSOR_ANALOG_PIN);
                                        //Calculating the voltage in the input of the ADC
                                        double voltage = realVoltage * ((double)luminosity / 1024.0);
                                        //Calculating the resistance of the photoresistor in the voltage divider
                                        double resistance = (10.0 * realVoltage) / voltage - 10.0;
                                        //Calculating the intensity of light in lux and return it
                                        int illuminance = 255.84 * pow(resistance, -10/9);
                                        return illuminance;
                                      /* Allows to get the real Vcc (return value * 100).                                   */
                                      int getVoltage()
                                        const long InternalReferenceVoltage = 1056L;
                                        ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
                                        delay(50);  // Let mux settle a little to get a more stable A/D conversion
                                        //Start a conversion
                                        ADCSRA |= _BV( ADSC );
                                        //Wait for it to complete
                                        while (((ADCSRA & (1<<ADSC)) != 0));
                                        //Scale the value
                                        int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
                                        return result;
                                      /* Allows to power ON peripherals.                                                    */
                                      void powerOnPeripherals()
                                        //Power-up
                                        pinMode (POWER_PIN, OUTPUT);
                                        digitalWrite (POWER_PIN, HIGH);
                                        delay(1);
                                      /* Allows to power OFF peripherals.                                                   */
                                      void powerOffPeripherals()
                                        //Power off
                                        digitalWrite (HUMIDITY_SENSOR_DIGITAL_PIN, LOW);
                                        digitalWrite (POWER_PIN, LOW);
                                        pinMode (HUMIDITY_SENSOR_DIGITAL_PIN, INPUT);
                                        pinMode (POWER_PIN, INPUT);
                                      Hope it helps !
                                      David.
                                      siodS
                                      siodS
                                      siod
                                      /*                            RST |             |  A5                                 */
                                      /*                            RX  |             |  A4                                 */
                                      /*                            D8  |             |  D9                                 */
                                      /* +3v = 2*AA        */
                                      #include <dht.h>
                                      #define POWER_PIN 4
                                      MyHwATMega328 hw;
                                      dht DHT;
                                        #ifdef DEBUG
                                        //Start MySensors
                                        gw.begin();
                                        //Delay for DHT22
                                        delay(1500);
                                        //Print setup debug
                                        #ifdef DEBUG
                                      /* Main loop        */
                                        #ifdef DEBUG
                                        //Power on
                                        //Get DHT22 data
                                          case DHTLIB_OK:
                                                      break;
                                                      #ifdef DEBUG
                                                      break;
                                                      #ifdef DEBUG
                                                      break;
                                                      #ifdef DEBUG
                                                      break;
                                                      #ifdef DEBUG
                                                      break;
                                                      #ifdef DEBUG
                                                      break;
                                          default:
                                                      #ifdef DEBUG
                                                      break;
                                        float humidity = 0;
                                        //Power off
                                        //Print debug
                                        #ifdef DEBUG
                                          Serial.print("   ");
                                          Serial.print(" %");
                                          Serial.print("   ");
                                          Serial.print(lux);
                                          Serial.print("   ");
                                          Serial.print(" v");
                                          Serial.print("   ");
                                          Serial.flush();
                                        //Sleep
                                        //Get luminosity
                                        return illuminance;
                                      int getVoltage()
                                        //Scale the value
                                        return result;
                                        //Power-up
                                        delay(1);
                                        //Power off
                                      Hope it helps !
                                      David.
                                      So the DHT22 works at 1MHz with 2 AAs and your code you´ve posted? No physical differnces?
                                      still learning...
                                      • rsachocR
                                        rsachocR
                                        rsachoc
                                        So I think I've finally got everything up and running! This is what I'm getting at the serial monitor in the IDE:
                                        Serial started
                                        Voltage: 3359 mV
                                        send: 132-132-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                                        send: 132-132-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
                                        send: 132-132-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                        read: 0-0-132 s=255,c=3,t=15,pt=0,l=2,sg=0:
                                        sensor started, id=132, parent=0, distance=1
                                        send: 132-132-0-0 s=255,c=3,t=11,pt=0,l=15,sg=0,st=ok:EgTmpHumBat5min
                                        send: 132-132-0-0 s=255,c=3,t=12,pt=0,l=10,sg=0,st=ok:1.0 151106
                                        send: 132-132-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                                        send: 132-132-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=ok:
                                        Node and 2 children presented.
                                        What I'm trying to figure out is where the temp and humidity reading are so I can get them into MQTT/OpenHab. Looking at the output, I can't see which one is the temp, humidity or battery level?
                                        • rsachocR rsachoc
                                          Serial started
                                          Voltage: 3359 mV
                                          m26872M
                                          m26872M
                                          m26872
                                          @rsachoc Is that all you get? Please also set sleep_time to 15000 for debug, if you haven't already done it.
