  3. Slim Node Si7021 sensor example
137 Posts 18 Posters 98.3k Views 20 Watching
  • rollercontainerR
    rollercontainerR
    rollercontainer
    RTFM :-P
    https://www.silabs.com/Support Documents/TechnicalDocs/Si7021-A20.pdf
    Page 5
    • rsachocR
      rsachocR
      rsachoc
      Ok, so I messed up my previous sensor trying to solder the bridge (don't ask...) I have now (I think) soldered it and reconnected it, am now getting the following:
      Serial started
      Voltage: 3359 mV
      send: 132-132-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=fail:0
      send: 132-132-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=fail:1.5.4
      send: 132-132-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:0
      sensor started, id=132, parent=0, distance=1
      send: 132-132-0-0 s=255,c=3,t=11,pt=0,l=15,sg=0,st=fail:EgTmpHumBat5min
      send: 132-132-0-0 s=255,c=3,t=12,pt=0,l=10,sg=0,st=fail:1.0 151106
      send: 132-132-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=fail:
      find parent
      send: 132-132-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
      send: 132-132-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=fail:
      Node and 2 children presented.
      I'm going to try get everything on a breadboard, but now I see fails, what's that all about?
      PS will upload some pics of the soldered bridge...
      m26872M 1 Reply Last reply
      • rsachocR rsachoc
        Serial started
        Voltage: 3359 mV
        find parent
        m26872M
        m26872M
        m26872
        @rsachoc google "mysensors st fail"
        • L
          L
          LastSamurai
          I am currently trying to use that red 3.3v module too and it doesn't seem to work. I have the sketch from above running with the "normal" blue module where I remove the voltage converter so that it works at 3.3V without a problem.
          Then I switched to the red one (with these small 3 solderpads connected) and the scl/sda lines switched (the order is different form the blue one) but the program gets stuck at the same position as above (without the st=fail's though). So I assume that
          si7021_env data = humiditySensor.getHumidityAndTemperature();
          fails. Does anyone have one of these sensors up and running? Any ideas where the error is? Otherwise I guess I have to stick with the blue ones.
          • L LastSamurai
            GertSandersG
            GertSandersG
            GertSanders
            @LastSamurai
            The red ones are HTU21D and need another library (they are different from the SI7021).
            Use the Adafruit library for this module (look on their site for HTU21D).
            rsachocR 1 Reply Last reply
            • GertSandersG GertSanders
              @LastSamurai
              rsachocR
              rsachocR
              rsachoc
              @GertSanders hmmm I think I'm using that same one as @LastSamurai so I suspect that's the issue? It's the one linked in the first post
              I guess if that's the problem it should have been obvious to me, it even says HTU21D on mine! Silly me!
              • rsachocR rsachoc
                GertSandersG
                GertSandersG
                GertSanders
                @rsachoc
                Either one of these libraries will work with the HTU21D modules.
                Both modules do the same, but have different I2C adresses so you can actually use both at the same time (of you like to compare them), but you need different libraries to call each one.
                L 1 Reply Last reply
                  @rsachoc
                  L
                  L
                  LastSamurai
                  @GertSanders Thanks, I don't know why I didn't realize that ;)
                  I will try that out tomorrow.
                  • L LastSamurai
                    rsachocR
                    rsachocR
                    rsachoc
                    @LastSamurai I'm having a go as well at updating the .ino file with the different library, but I'm not a coder so I'm "having a hack" - if you have any luck could you post your code?
                    • rsachocR rsachoc
                      L
                      L
                      LastSamurai
                      wrote on last edited by LastSamurai
                      #90
                      @rsachoc Yes, I actually just tried it out and its working.
                      Here is my code for now (just for testing):
                      I basically just switched libraries
                      /* Sketch with Si7021 and battery monitoring.
                      by m26872, 20151109
                      Changed by LastSamurai
                      15052016
                      #include <Wire.h>
                      #include <SparkFunHTU21D.h>
                      #include <RunningAverage.h>
                      //#define DEBUG
                      #ifdef DEBUG
                      #define DEBUG_SERIAL(x) Serial.begin(x)
                      #define DEBUG_PRINT(x) Serial.print(x)
                      #else
                      #define NODE_ID 100             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                      #define CHILD_ID_TEMP 0
                      #define CHILD_ID_HUM 1
                      // #define SLEEP_TIME 15000 // 15s for DEBUG
                      #define SLEEP_TIME 300000   // 5 min
                      #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
                      #define BATTERY_REPORT_CYCLE 2016   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
                      #define VMIN 1900
                      #define VMAX 3300
                      #define HUMI_TRANSMIT_THRESHOLD 3.0  // THRESHOLD tells how much the value should have changed since last time it was transmitted.
                      #define TEMP_TRANSMIT_THRESHOLD 0.5
                      #define AVERAGES 2
                      int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
                      int measureCount = 0;
                      float lastTemperature = -100;
                      int lastHumidity = -100;
                      RunningAverage raHum(AVERAGES);
                      HTU21D humiditySensor;
                      MyMessage msgTemp(CHILD_ID_TEMP,V_TEMP); // Initialize temperature message
                      MyMessage msgHum(CHILD_ID_HUM,V_HUM);
                        DEBUG_SERIAL(9600);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                        DEBUG_PRINTLN("Serial started");
                        DEBUG_PRINT("Voltage: ");
                        DEBUG_PRINT(readVcc());
                        DEBUG_PRINTLN(" mV");
                        delay(500);
                        DEBUG_PRINT("Internal temp: ");
                        DEBUG_PRINT(GetInternalTemp()); // Probably not calibrated. Just to print something.
                        DEBUG_PRINTLN(" *C");
                        delay(500); // Allow time for radio if power useed as reset
                        gw.begin(NULL, NODE_ID);
                        gw.sendSketchInfo("TempHumTest2", "1.0 17052016");
                        gw.present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
                        DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
                        raHum.clear();
                        humiditySensor.begin();
                        measureCount ++;
                        batteryReportCounter ++;
                        bool forceTransmit = false;
                        if (measureCount > FORCE_TRANSMIT_CYCLE) {
                          forceTransmit = true;
                        // Read and print internal temp
                        float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
                        DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
                        // Check battery
                        if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
                          long batteryVolt = readVcc();
                          DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
                          uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
                          DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
                          batteryReportCounter = 0;
                        gw.sleep(SLEEP_TIME);
                      // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
                      // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
                      long readVcc() {
                        long result = (high<<8) | low;
                      // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
                      double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
                        unsigned int wADC;
                        double t;
                        // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
                        ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
                        ADCSRA |= _BV(ADEN);  // enable the ADC
                        delay(20);            // wait for voltages to become stable.
                        ADCSRA |= _BV(ADSC);  // Start the ADC
                        while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
                        wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
                        t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
                        return (t);   // The returned temperature in degrees Celcius.
                       * * Sends temperature and humidity from Si7021 sensor
                       * Parameters
                       * - force : Forces transmission of a value (even if it's the same as previous measurement)
                      void sendTempHumidityMeasurements(bool force) {
                        bool tx = force;
                        float temperature = humiditySensor.readTemperature();
                        DEBUG_PRINT("T: ");DEBUG_PRINTLN(temperature);
                        float diffTemp = abs(lastTemperature - temperature);
                        DEBUG_PRINT(F("TempDiff :"));DEBUG_PRINTLN(diffTemp);
                        if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
                          gw.send(msgTemp.set(temperature,1));
                          lastTemperature = temperature;
                          measureCount = 0;
                          DEBUG_PRINTLN("T sent!");
                        int humidity = humiditySensor.readHumidity();
                        DEBUG_PRINT("H: ");DEBUG_PRINTLN(humidity);
                        raHum.addValue(humidity);
                        humidity = raHum.getAverage();  // MA sample imply reasonable fast sample frequency
                        float diffHum = abs(lastHumidity - humidity);
                        DEBUG_PRINT(F("HumDiff  :"));DEBUG_PRINTLN(diffHum);
                        if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
                          gw.send(msgHum.set(humidity));
                          lastHumidity = humidity;
                          measureCount = 0;
                          DEBUG_PRINTLN("H sent!");
                      • L LastSamurai
                        by m26872, 20151109
                        15052016
                        #include <Wire.h>
                        //#define DEBUG
                        #ifdef DEBUG
                        #else
                        #define VMIN 1900
                        #define VMAX 3300
                        #define AVERAGES 2
                          delay(500);
                          raHum.clear();
                          measureCount ++;
                          // Check battery
                        long readVcc() {
                          unsigned int wADC;
                          double t;
                         * Parameters
                          bool tx = force;
                            measureCount = 0;
                            measureCount = 0;
                        rsachocR
                        rsachocR
                        rsachoc
                        @LastSamurai thanks, progress, I'm getting this now, which means it's working! Finally, a working node from a complete rookie like me!
                        Serial started
                        Voltage: 3389 mV
                        Internal temp: 266.00 *C
                        send: 100-100-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                        send: 100-100-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
                        send: 100-100-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                        read: 0-0-100 s=255,c=3,t=15,pt=0,l=2,sg=0:
                        sensor started, id=100, parent=0, distance=1
                        send: 100-100-0-0 s=255,c=3,t=11,pt=0,l=12,sg=0,st=fail:TempHumTest2
                        send: 100-100-0-0 s=255,c=3,t=12,pt=0,l=12,sg=0,st=fail:1.0 17052016
                        send: 100-100-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=fail:
                        send: 100-100-0-0 s=1,c=0,t=7,pt=0,l=0,sg=0,st=fail:
                        T: 998.00
                        TempDiff :1098.00
                        send: 100-100-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:998.0
                        T sent!
                        H: 118
                        HumDiff  :218.00
                        send: 100-100-0-0 s=1,c=1,t=1,pt=2,l=2,sg=0,st=ok:118
                        H sent!
                        Battery voltage: 3359 mV
                        Battery percent: 104 %
                        send: 100-100-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:104
                        I think that the readings are not accurate though, not sure why, but I'll have a go at figuring our why anyway!
                        • rsachocR rsachoc
                          Serial started
                          Voltage: 3389 mV
                          T: 998.00
                          TempDiff :1098.00
                          T sent!
                          H: 118
                          HumDiff  :218.00
                          H sent!
                          GertSandersG
                          GertSandersG
                          GertSanders
                          @rsachoc
                          Congrats !!!
                            @rsachoc
                            Congrats !!!
                            m26872M
                            m26872M
                            m26872
                            @GertSanders Thx a lot for your help! I had no clue about the HTU21D lib.
                            • badmannenB
                              badmannenB
                              badmannen
                              This post is deleted!
                              • siodS
                                siodS
                                siod
                                so with the correct library there is no need to solder those 3 spots together!?
                                still learning...
                                • siodS siod
                                  GertSandersG
                                  GertSandersG
                                  GertSanders
                                  @siod
                                  The "spots" are there to connect the pullup resistors to the SDA and SCL lines. This is always needed, regardless of the library of the board onto which you connect the sensor board does not provide pullup resistors itself. On a minimal board like the one in this thread, this is not the case, so the pull up resistors are needed.
                                  • siodS
                                    siodS
                                    siod
                                    wrote on last edited by siod
                                    #97
                                    ok, thanks for making it clear for me Gert!!
                                    update:
                                    finally found time to build my sensor and it seems to work fine, will do more testing but for now my results are:
                                    7.5 uA when sleeping, 15,3 mA when working (every 15 minutes for about 2seconds, but I think my cheap multimeter gives bad readings on those spikes, I guess it´s only around 1 mA)
                                    seems to be okay, isn´t it?
                                    edit:
                                    I have 2 reed switches attached. I recognized that I have +0,10 mA for each reed switch when activated. So when reed switches are both touching their counterpart I have a sleeping consumption of 0,20 mA. Why is that??
                                    still learning...
                                    • J
                                      J
                                      jacikaas
                                      wrote on last edited by jacikaas
                                      #98
                                      I'm trying to convert existing Si7021 sensor code from 1.5 to 2.0.0 library. I change the code and then I was getting an error which said:
                                      Si7021_sensor_MySensors_2.0.0:158: error: 'si7021_env' has no member named 'humidityPercent'
                                         int humidity = data.humidityPercent;
                                      exit status 1
                                      Then I chech the Si7021 library, and how I saw there wasn't member 'humidityPercent', but there was a member 'humidityBasisPoints'.
                                      So I change line from:
                                      ...to:
                                        int humidity = data.humidityBasisPoints;
                                      Then code compiles and I upload it to Slim Node Si7021. I leave sensor and today I checked it log on Domoticz. I have this:
                                      Temperature looks ok, but Humidity value jumping a lot, thats why I don't want to believe it is true.
                                      Could someone, who has a 2.0.0 library and Si7021 sensor chech is it same situation? Becose I have only one Si7021 sensor.
                                      Maybe someone could look also on the code and say if I convert it right?
                                      Converted code:
                                      by m26872, 20151109
                                      #define MY_NODE_ID 5             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
                                      #define MY_BAUD_RATE 115200
                                      #include <Wire.h>
                                      #include <SI7021.h>
                                      //#define DEBUG
                                      #ifdef DEBUG
                                      #else
                                      #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
                                      #define VMIN 1900
                                      #define VMAX 3300
                                      #define AVERAGES 2
                                      SI7021 humiditySensor;
                                        sendSketchInfo("EgTmpHumBat5min", "1.0 151106");
                                        DEBUG_SERIAL(115200);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                                        delay(500);
                                        raHum.clear();
                                        measureCount ++;
                                        // Check battery
                                        sleep(SLEEP_TIME);
                                      long readVcc() {
                                        unsigned int wADC;
                                        double t;
                                       * Parameters
                                        bool tx = force;
                                        float temperature = data.celsiusHundredths / 100.0;
                                          measureCount = 0;
                                          measureCount = 0;
                                      Thank You!
                                      AWIA 1 Reply Last reply
                                      • J jacikaas
                                        exit status 1
                                        ...to:
                                        Converted code:
                                        by m26872, 20151109
                                        #include <Wire.h>
                                        #include <SI7021.h>
                                        //#define DEBUG
                                        #ifdef DEBUG
                                        #else
                                        #define VMIN 1900
                                        #define VMAX 3300
                                        #define AVERAGES 2
                                          delay(500);
                                          raHum.clear();
                                          measureCount ++;
                                          // Check battery
                                          sleep(SLEEP_TIME);
                                        long readVcc() {
                                          unsigned int wADC;
                                          double t;
                                         * Parameters
                                          bool tx = force;
                                            measureCount = 0;
                                            measureCount = 0;
                                        Thank You!
                                        AWIA
                                        AWIA
                                        AWI
                                        @jacikaas where did you get the si7021 library? Take a look at the sensebender sketch for a good reference.
                                        J 1 Reply Last reply
                                        • AWIA AWI
                                          J
                                          J
                                          jacikaas
                                          @AWI
                                          I download Si7021 library from here: https://github.com/LowPowerLab/SI7021
                                          I was heard about Sensbender node, but never look deeper what is in it. I will look at it and try to understand whats in there. I just learning about all that stuff, so it will be good practice :blush:
