  3. Slim Node Si7021 sensor example
137 Posts 18 Posters 97.0k Views 20 Watching
  • A ar91
    @carlierd If you could share your code that will be great.
    carlierdC
    carlierdC
    carlierd
    @ar91 Please find the code I used in 3 different nodes. The good thing with the playground lib is that there is error message if dialog with DHT22 failed.
    /* Temperature, humidity and luminosity measurements.                                 */
    /* Version     : 1.1.6        */
    /* Date        : 10/01/2016                                                           */
    /* Modified by : David Carlier                                                        */
    /*                            RST |             |  A5                                 */
    /*                            RX  |             |  A4                                 */
    /*                            TX  |   ARDUINO   |  A3                                 */
    /*     RFM69 (DIO0) --------- D2  |     UNO     |  A2                                 */
    /*            DHT22 --------- D3  |             |  A1                                 */
    /*            Power --------- D4  | ATMEGA 328p |  A0 --------- Light dep. resistor   */
    /*              +3v --------- VCC |             | GND --------- GND                   */
    /*              GND --------- GND |  8MHz int.  | REF                                 */
    /*                            OSC |             | VCC --------- +3v                   */
    /*                            OSC |             | D13 --------- RFM69 (SCK)           */
    /*                            D5  |             | D12 --------- RFM69 (MISO)          */
    /*                            D6  |             | D11 --------- RFM69 (MOSI)          */
    /*                            D7  |             | D10 --------- RFM69 (NSS)           */
    /*                            D8  |             |  D9                                 */
    /* Power = Vcc for LDR.                                                               */
    /* +3v = 2*AA        */
    #include <dht.h>
    #include <MyTransportRFM69.h>
    #include <MySigningAtsha204Soft.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_LIGHT 2
    #define CHILD_ID_VOLTAGE 3
    #define LIGHT_SENSOR_ANALOG_PIN 0
    #define POWER_PIN 4
    //unsigned long SLEEP_TIME = 850000; // Sleep time between reads (in milliseconds) (close to 15')
    unsigned long SLEEP_TIME = 275000; // Sleep time between reads (in milliseconds) (close to 5')
    //Construct MySensors library
    MySigningAtsha204Soft signer;
    MyHwATMega328 hw;
    MyTransportRFM69 transport;
    MySensor gw(transport, hw, signer);
    dht DHT;
    MyMessage msgLum(CHILD_ID_LIGHT, V_LEVEL);
    MyMessage msgVolt(CHILD_ID_VOLTAGE, V_VOLTAGE);
    /* Initialization        */
      //Get time (for setup duration)
      #ifdef DEBUG
        unsigned long startTime = millis();
      //Start MySensors
      gw.begin();
      //Send the Sketch Version Information to the Gateway
      gw.sendSketchInfo("GHAS sensor", "1.1.5");
      //Register all sensors to gw (they will be created as child devices)
      gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
      gw.present(CHILD_ID_VOLTAGE, S_MULTIMETER);
      //Delay for DHT22
      delay(1500);
      //Print setup debug
      #ifdef DEBUG
        int duration = millis() - startTime;
        Serial.print("[Setup duration: "); Serial.print(duration, DEC); Serial.println(" ms]");
    /* Main loop        */
      //Get time (for a complete loop)
      #ifdef DEBUG
      //Power on
      powerOnPeripherals();
      //Get DHT22 data
      int dht22Result = DHT.read22(HUMIDITY_SENSOR_DIGITAL_PIN);
      switch (dht22Result)
        case DHTLIB_OK:
                    //Serial.println("OK,\t");
                    break;
        case DHTLIB_ERROR_CHECKSUM:
                    #ifdef DEBUG
                      Serial.println("Checksum error,\t");
                    break;
        case DHTLIB_ERROR_TIMEOUT:
                    #ifdef DEBUG
                      Serial.println("Time out error,\t");
                    break;
        case DHTLIB_ERROR_CONNECT:
                    #ifdef DEBUG
                      Serial.println("Connect error,\t");
                    break;
        case DHTLIB_ERROR_ACK_L:
                    #ifdef DEBUG
                      Serial.println("Ack Low error,\t");
                    break;
        case DHTLIB_ERROR_ACK_H:
                    #ifdef DEBUG
                      Serial.println("Ack High error,\t");
                    break;
        default:
                    #ifdef DEBUG
                      Serial.println("Unknown error,\t");
                    break;
      //Get temperature and humidity
      float temperature = 0;
      float humidity = 0;
      if (dht22Result == DHTLIB_OK)
        temperature = DHT.temperature;
        humidity = DHT.humidity;
      //Get power before luminosity to use real voltage
      float realVoltage = getVoltage() / 100.0;
      int batteryPcnt = realVoltage * 100 / 3.0;
      if (batteryPcnt > 100) {batteryPcnt = 100;}
      int lux = computeIlluminance(realVoltage);
      //Power off
      powerOffPeripherals();
      //Send data to gateway
      gw.send(msgLum.set(lux));
      gw.send(msgVolt.set(realVoltage, 2));
      //Print debug
      #ifdef DEBUG
        Serial.print(temperature, 1);
        Serial.print(" degC");
        Serial.print("   ");
        Serial.print(humidity, 1);
        Serial.print(" %");
        Serial.print("   ");
        Serial.print(lux);
        Serial.print(" lx");
        Serial.print("   ");
        Serial.print(realVoltage);
        Serial.print(" v");
        Serial.print("   ");
        Serial.print("["); Serial.print(duration, DEC); Serial.println(" ms]");
        Serial.flush();
      //Sleep
      gw.sleep(SLEEP_TIME);
    /* Allows to compute illuminance (in LUX) from LIGHT_SENSOR_ANALOG_PIN.               */
    int computeIlluminance(float realVoltage)
      //Get luminosity
      int luminosity = analogRead(LIGHT_SENSOR_ANALOG_PIN);
      //Calculating the voltage in the input of the ADC
      double voltage = realVoltage * ((double)luminosity / 1024.0);
      //Calculating the resistance of the photoresistor in the voltage divider
      double resistance = (10.0 * realVoltage) / voltage - 10.0;
      //Calculating the intensity of light in lux and return it
      int illuminance = 255.84 * pow(resistance, -10/9);
      return illuminance;
    /* Allows to get the real Vcc (return value * 100).                                   */
    int getVoltage()
      const long InternalReferenceVoltage = 1056L;
      ADMUX = (0<<REFS1) | (1<<REFS0) | (0<<ADLAR) | (1<<MUX3) | (1<<MUX2) | (1<<MUX1) | (0<<MUX0);
      delay(50);  // Let mux settle a little to get a more stable A/D conversion
      //Start a conversion
      ADCSRA |= _BV( ADSC );
      //Wait for it to complete
      while (((ADCSRA & (1<<ADSC)) != 0));
      //Scale the value
      int result = (((InternalReferenceVoltage * 1023L) / ADC) + 5L) / 10L;
      return result;
    /* Allows to power ON peripherals.                                                    */
    void powerOnPeripherals()
      //Power-up
      pinMode (POWER_PIN, OUTPUT);
      digitalWrite (POWER_PIN, HIGH);
      delay(1);
    /* Allows to power OFF peripherals.                                                   */
    void powerOffPeripherals()
      //Power off
      digitalWrite (HUMIDITY_SENSOR_DIGITAL_PIN, LOW);
      digitalWrite (POWER_PIN, LOW);
      pinMode (HUMIDITY_SENSOR_DIGITAL_PIN, INPUT);
      pinMode (POWER_PIN, INPUT);
    Hope it helps !
    David.
    A siodS 3 Replies Last reply
    • carlierdC carlierd
      /*                            RST |             |  A5                                 */
      /*                            RX  |             |  A4                                 */
      /*                            D8  |             |  D9                                 */
      /* +3v = 2*AA        */
      #include <dht.h>
      #define POWER_PIN 4
      MyHwATMega328 hw;
      dht DHT;
        #ifdef DEBUG
        //Start MySensors
        gw.begin();
        //Delay for DHT22
        delay(1500);
        //Print setup debug
        #ifdef DEBUG
      /* Main loop        */
        #ifdef DEBUG
        //Power on
        //Get DHT22 data
          case DHTLIB_OK:
                      break;
                      #ifdef DEBUG
                      break;
                      #ifdef DEBUG
                      break;
                      #ifdef DEBUG
                      break;
                      #ifdef DEBUG
                      break;
                      #ifdef DEBUG
                      break;
          default:
                      #ifdef DEBUG
                      break;
        float humidity = 0;
        //Power off
        //Print debug
        #ifdef DEBUG
          Serial.print("   ");
          Serial.print(" %");
          Serial.print("   ");
          Serial.print(lux);
          Serial.print("   ");
          Serial.print(" v");
          Serial.print("   ");
          Serial.flush();
        //Sleep
        //Get luminosity
        return illuminance;
      int getVoltage()
        //Scale the value
        return result;
        //Power-up
        delay(1);
        //Power off
      Hope it helps !
      David.
      A
      A
      ar91
      @carlierd Thank you very much. I really like your comment on the top :+1:
      • rsachocR
        rsachocR
        rsachoc
        Progress!
        http://imgur.com/zRvXvrN
        http://imgur.com/KpB7daz
        A question though. To get to this point, I copied the pictures posted above, but where do I now add these resistors?
        http://imgur.com/6mKJcgE
        Also, if I want to add a 2AA battery cage, where do I connect the red and black wires to?
        Thanks! And sorry for the newb questions!
        m26872M 1 Reply Last reply
        • GertSandersG
          GertSandersG
          GertSanders
          @rsachoc What you show are not resistors, they look like capacitors. 104 means 100nF (I think). Can you measure their value ?
            /*                            RST |             |  A5                                 */
            /*                            RX  |             |  A4                                 */
            /*                            D8  |             |  D9                                 */
            /* +3v = 2*AA        */
            #include <dht.h>
            #define POWER_PIN 4
            MyHwATMega328 hw;
            dht DHT;
              #ifdef DEBUG
              //Start MySensors
              gw.begin();
              //Delay for DHT22
              delay(1500);
              //Print setup debug
              #ifdef DEBUG
            /* Main loop        */
              #ifdef DEBUG
              //Power on
              //Get DHT22 data
                case DHTLIB_OK:
                            break;
                            #ifdef DEBUG
                            break;
                            #ifdef DEBUG
                            break;
                            #ifdef DEBUG
                            break;
                            #ifdef DEBUG
                            break;
                            #ifdef DEBUG
                            break;
                default:
                            #ifdef DEBUG
                            break;
              float humidity = 0;
              //Power off
              //Print debug
              #ifdef DEBUG
                Serial.print("   ");
                Serial.print(" %");
                Serial.print("   ");
                Serial.print(lux);
                Serial.print("   ");
                Serial.print(" v");
                Serial.print("   ");
                Serial.flush();
              //Sleep
              //Get luminosity
              return illuminance;
            int getVoltage()
              //Scale the value
              return result;
              //Power-up
              delay(1);
              //Power off
            Hope it helps !
            David.
            A
            A
            ar91
            @carlierd Are you running your Atmega at 1Mhz, Because I tried to use your sketch and i am getting "Checksum Error".
            carlierdC 1 Reply Last reply
            • rsachocR
              rsachocR
              rsachoc
              wrote on last edited by rsachoc
              #26
              @GertSanders indeed they are capacitors (silly me) - apparently they are 0.1uf - the black one I have already soldered is 4.7uf
              • A ar91
                carlierdC
                carlierdC
                carlierd
                No, I am working at 8 MHz (internal). Perhaps your DHT is out of order ? You try with another one ?
                David.
                • rsachocR
                  rsachocR
                  rsachoc
                  Bump, can anyone advise on how I got about finding out where I need to solder the resistors on? So far I've just soldered the 4.7uf capacitor, as can be seen from the pics. But I'm struggling to find out where I need to solder the other capacitor's I have (from the BOM).
                  • rsachocR rsachoc
                    m26872M
                    m26872M
                    m26872
                    @rsachoc C1,C2,C3 are clearly marked at top layer silkscreen. You'll see them in the middle of the uC socket if you look at your 2nd picture in you last post above. C5 is visible next to the 4.7u cap, in the 3rd picture of my first post in this thread.
                    • rsachocR rsachoc
                      Progress!
                      m26872M
                      m26872M
                      m26872
                      First picture in first post of this thread should be enough. Connect (+) to Vcc and (-) to Gnd.
                      • rsachocR
                        rsachocR
                        rsachoc
                        Thanks, apologies, I really should have looked at my board, I was searching for the answer in the main slim node thread and I think i was looking at older boards and couldn't for the life of me find where C3 is!
                        • rsachocR rsachoc
                          m26872M
                          m26872M
                          m26872
                          @rsachoc I'm sorry, I know I need to update those old pictures.
                          rsachocR 1 Reply Last reply
                          • m26872M m26872
                            rsachocR
                            rsachocR
                            rsachoc
                            @m26872 no problem, not your fault at all, mine for being a newbie. So much so that my first attempt resulted in me soldering the capacitor to the wrong hole, so I've had to abandon my first attempt. You live, you learn, next time I'll double check.
                            • rsachocR rsachoc
                              m26872M
                              m26872M
                              m26872
                              @rsachoc Yes. Double check polarity of the 4.7uF cap.
                              • rsachocR
                                rsachocR
                                rsachoc
                                Hi all, again.
                                I have now successfully built (I think) the slim node, but without the 7021 temp sensor. Because this is the most expensive part of the device and because I find desoldering a challenge, but mainly because I'm waiting for it to arrive from China, can I try and upload the bootloader and sketch without the sensor attached?
                                If so, I had a couple questions from reading through this thread and the slim node thread. Firstly, uploading the bootloader, can this be done with the FTDI adaptor or do I need to follow the bit described in the slim node thread and attempt it using AVR studio? Secondly, once that is done, is it just a matter of uploading the sketch provided above?
                                Also, I wanted to confirm a few things on attaching the si7021 temp sensor. From what I can see, SOA (SDA) on the si7021 goes to A4 and SCL goes to A5. Also, GND goes to GND on the board (rightmost set on pins bottom right when FTDI is at the top) and VIN goes to VCC (just next to GND on the board)?
                                Thanks in advance.
                                • rsachocR rsachoc
                                  Hi all, again.
                                  Thanks in advance.
                                  m26872M
                                  m26872M
                                  m26872
                                  #36
                                  Yes, you should be able to get far without the sensor. Send something over MySensors net and view debug prints. Or make some simple sensor like a reed switch.
                                  Yes, Avr Studio or Uno as ISP.
                                  Yes, but if you don't connect a Si7021 I would go for some other simple test sketch to avoid any Si7021 library startup issues.
                                  Yes.
                                  • rsachocR
                                    rsachocR
                                    rsachoc
                                    #37
                                    Folks, a word of caution, for people that are attempting this for the first time, please burn the bootloader before you solder everything, as silly me, I built the entire thing (without the si7021) and now I'll need to bin it because the ATMega is soldered to the board and I've no way to load the bootloader soldered to the board!
                                    Ah, the life of a newbie :grin:
                                    I think what I'll do is once I've actually got a working board, I'll do a newbie writeup so that people don't make the same mistakes as me.
                                      First Attempt In Learning :-) A writeup would be awesome.
                                      • rsachocR rsachoc
                                        m26872M
                                        m26872M
                                        m26872
                                        @rsachoc Why don't you just solder some wires to pins you need ? The "in cicuit serial programming" concept would let you do it with almost anything attached.
                                        • m26872M m26872
                                          rsachocR
                                          rsachocR
                                          rsachoc
                                          I might as well attempt that! I'm waiting for a breadboard, so I'll try and attempt it when that arrives.
