  3. Slim Node Si7021 sensor example
137 Posts 18 Posters 98.3k Views 20 Watching
  • clempatC clempat
    So sad I still not getting it working with the slim node :( !!! Always same result either with internal 1mhz or 8mhz...
    m26872M
    m26872M
    m26872
    @clempat Make it with external 8MHz then ? Then it should be like a Pro Mini 3.3V.
    clempatC 1 Reply Last reply
    • m26872M m26872
      clempatC
      clempatC
      clempat
      @m26872 I will give a try and let you know... Thanks.
      • miljumeM
        miljumeM
        miljume
        Hello
        I also have big problems with getting the node to send temp and hum values
        It starts up and presents itself to the GW but then nothing happens
        I have tested the SI721 module with a simple arduino code and then it reads and prints both values just fine
        My code is below, in practice its a version of Sensebender Micro code. I have changed the force transmit value to 1
        Exactly as @clempat I have tried both 1MHz optiboot and 8MHz internal oscillator without any success
        * Version 1.0 - Thomas Bowman MC8rch
        * Default sensor sketch for Sensebender Micro module
        * Act as a temperature / humidity sensor by default.
        * If A0 is held low while powering on, it will enter testmode, which verifies all on-board peripherals
        * Battery voltage is as battery percentage (Internal message), and optionally as a sensor value (See defines below)
        * Version 1.3 - Thomas Bowman MC8rch
        * Improved transmission logic, eliminating spurious transmissions (when temperatuere / humidity fluctuates 1 up and down between measurements)
        * Added OTA boot mode, need to hold A1 low while applying power. (uses slightly more power as it's waiting for bootloader messages)
        * Version 1.4 - Thomas Bowman MC8rch
        * Corrected division in the code deciding whether to transmit or not, that resulted in generating an integer. Now it's generating floats as expected.
        * Simplified detection for OTA bootloader, now detecting if MY_OTA_FIRMWARE_FEATURE is defined. If this is defined sensebender automaticly waits 300mS after each transmission
        * Moved Battery status messages, so they are transmitted together with normal sensor updates (but only every 60th minute)
        // Define a static node address, remove if you want auto address assignment
        //#deine MY_NODE_ID 3
        #include <Wire.h>
        #include <SI7021-master\SI7021.h>
        #include <RunningAverage.h>
        // Uncomment the line below, to transmit battery voltage as a normal sensor value
        #define BATT_SENSOR    199
        #define RELEASE "1.4"
        #define AVERAGES 2
        // Child sensor ID's
        #define CHILD_ID_TEMP  1
        #define CHILD_ID_HUM   2
        // How many milli seconds between each measurement
        #define MEASURE_INTERVAL 60000
        // FORCE_TRANSMIT_INTERVAL, this number of times of wakeup, the sensor is forced to report all values to the controller
        #define FORCE_TRANSMIT_INTERVAL 1
        // When MEASURE_INTERVAL is 60000 and FORCE_TRANSMIT_INTERVAL is 30, we force a transmission every 30 minutes.
        // Between the forced transmissions a tranmission will only occur if the measured value differs from the previous measurement
        // HUMI_TRANSMIT_THRESHOLD tells how much the humidity should have changed since last time it was transmitted. Likewise with
        // TEMP_TRANSMIT_THRESHOLD for temperature threshold.
        #define HUMI_TRANSMIT_THRESHOLD 0.5
        #define TEMP_TRANSMIT_THRESHOLD 0.5
        SI7021 humiditySensor;
        // Sensor messages
        #ifdef BATT_SENSOR
        MyMessage msgBatt(BATT_SENSOR, V_VOLTAGE);
        // Global settings
        int measureCount = 0;
        int sendBattery = 0;
        boolean isMetric = true;
        boolean highfreq = true;
        boolean transmission_occured = false;
        // Storage of old measurements
        float lastTemperature = -100;
        int lastHumidity = -100;
        long lastBattery = -100;
        RunningAverage raHum(AVERAGES);
        * Setup code
        	Serial.begin(9600);
        	Serial.print(F("Sensebender Micro FW "));
        	Serial.print(RELEASE);
        	Serial.flush();
        	humiditySensor.begin();
        	Serial.flush();
        	Serial.println(F(" - Online!"));
        	isMetric = getConfig().isMetric;
        	Serial.print(F("isMetric: ")); Serial.println(isMetric);
        	raHum.clear();
        	sendTempHumidityMeasurements(false);
        	sendBattLevel(false);
        void presentation() {
        	sendSketchInfo("TempHum", RELEASE);
        	present(CHILD_ID_HUM, S_HUM);
        #ifdef BATT_SENSOR
        	present(BATT_SENSOR, S_POWER);
        *  Main loop function
        	measureCount++;
        	sendBattery++;
        	bool forceTransmit = false;
        	if (measureCount > FORCE_TRANSMIT_INTERVAL) { // force a transmission
        		forceTransmit = true;
        		measureCount = 0;
        	/*  if (sendBattery > 60)
        	sendBattLevel(forceTransmit); // Not needed to send battery info that often
        	sendBattery = 0;
        	sleep(MEASURE_INTERVAL);
        * Sends temperature and humidity from Si7021 sensor
        * Parameters
        * - force : Forces transmission of a value (even if it's the same as previous measurement)
        void sendTempHumidityMeasurements(bool force)
        	bool tx = force;
        	si7021_env data = humiditySensor.getHumidityAndTemperature();
        	raHum.addValue(data.humidityPercent);
        	float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0);
        	float diffHum = abs(lastHumidity - raHum.getAverage());
        	Serial.print(F("TempDiff :"));Serial.println(diffTemp);
        	Serial.print(F("HumDiff  :"));Serial.println(diffHum);
        	if (isnan(diffHum)) tx = true;
        	if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
        	if (diffHum > HUMI_TRANSMIT_THRESHOLD) tx = true;
        	if (tx) {
        		measureCount = 0;
        		float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
        		int humidity = data.humidityPercent;
        		Serial.print("T: ");Serial.println(temperature);
        		Serial.print("H: ");Serial.println(humidity);
        		send(msgHum.set(humidity));
        		lastTemperature = temperature;
        		lastHumidity = humidity;
        		transmission_occured = true;
        		if (sendBattery > 60) {
        			sendBattLevel(true); // Not needed to send battery info that often
        			sendBattery = 0;
        * Sends battery information (battery percentage)
        * Parameters
        void sendBattLevel(bool force)
        	if (force) lastBattery = -1;
        	long vcc = readVcc();
        	if (vcc != lastBattery) {
        		lastBattery = vcc;
        #ifdef BATT_SENSOR
        		float send_voltage = float(vcc) / 1000.0f;
        		send(msgBatt.set(send_voltage, 3));
        		// Calculate percentage
        		vcc = vcc - 1900; // subtract 1.9V from vcc, as this is the lowest voltage we will operate at
        		long percent = vcc / 14.0;
        		sendBatteryLevel(percent);
        * Internal battery ADC measuring
        long readVcc() {
        #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
        	ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
        #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
        	ADMUX = _BV(MUX5) | _BV(MUX0);
        #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
        	ADcdMUX = _BV(MUX3) | _BV(MUX2);
        #else
        	while (bit_is_set(ADCSRA, ADSC)); // measuring
        	uint8_t low = ADCL; // must read ADCL first - it then locks ADCH
        	long result = (high << 8) | low;
        • m26872M
          m26872M
          m26872
          It would be interesting if someone with issues also tried older versions of libs for Si7021 and/or MySensors.
          • W
            W
            wergeld
            So, after a few months of 2 nodes up and running using the HTU21D sensor I have come the conclusion that the HTU21D is no good for where I live. Lately it has been getting cooler outside (down to mid 50s F) but humidity is still high. As the evening progresses the humidity gets to 100% and the node no longer sends data. This happens around 6pm every day (about half and hour after sunset). It then comes back online at about 10 am the next day. The node that I have inside does not have this issue (same shipment of arduino, pcb, and HTU21D sensors and the same arduino code). Both running off of fresh AAs. May need to upgrade to the SI7021 for outside node.
            Here is the graph showing last 7 days. As you can see it flatlines (literally!) at 100% humidity!
            All good times with the learning!
            m26872M 1 Reply Last reply
            • W wergeld
              m26872M
              m26872M
              m26872
              @wergeld Relative humidity at 100% during night sounds very realistic to me. Are you confusing it with the "absolute humidity"? Or is your concern that the "force transmit" isn't working?
              • bjacobseB
                bjacobseB
                bjacobse
                Mine does the same, but it's also very humid at night - I think this is normal behavoir
                • W
                  W
                  wergeld
                  @m26872 & @bjacobse - Yes, 100% humidity is normal here. Good old Florida! My concern is that the node stops reporting. Possibly due to condensation shorting out something. During the summer here we also hit 100% humidity but it is also a lot hotter (high 90s). Now, I think that the cooler temps are forcing a dew point that is allowing water to condense on the node. Then during the morning it drys out and resumes transmitting. I would like to find a way to stop this.
                  • W wergeld
                    m26872M
                    m26872M
                    m26872
                    @wergeld
                    https://forum.mysensors.org/topic/1560/how-to-protect-your-outdoor-sensor
                    W 1 Reply Last reply
                    • m26872M m26872
                      @wergeld
                      W
                      W
                      wergeld
                      @m26872 I have looked at a lot of those links. I am leaning towards covering my node in non-reactive glue. This will seal all contacts. The only part that would be difficult would be the actual teeny tiny sensor chip on the HTU21D. Hopefully any condensation there can be minimal. The next step would be to make sure the battery case is sealed as well (although I do not think this will be much of an issue).
                      • bjacobseB
                        bjacobseB
                        bjacobse
                        Do you have some battery saving stuff in your code, so you maybe wakeup check temp + humidity, and if they are same value as previous, then go back to sleep - no need to use battery usage to send same values again, this can cause your sensor to not report values
                        • bjacobseB bjacobse
                          W
                          W
                          wergeld
                          @bjacobse Yes, I am checking the values and if the same as last transmission I abort and go back to sleep. If, however, it has been 3 hours since last transmission I force it to send.
                          • E
                            E
                            Eawo
                            wrote on last edited by Eawo
                            #133
                            I've done 6 nodes off this sensor. Do I have to change something else then node id? Also I'm using the 1mhz bootloader with bud rate 9200 should I change that in the sketch?
                            Seems like I only get the temprature and humidity once on first start up...
                            Edit:
                            I think my problem is that I haven't changed the bud rate in mysensors.h file. I've just reinstalled everything now and I don't know how to get si7021 installed the right way. I installed the package inside arduino but it doesn't work.
                            I such a noob sorry guys
                            • E
                              E
                              Eawo
                              I have problem to get my sensors to work. Thay start up and shows a not so accurate value sometimes and thay report once or twice but then never again. I thought it was because buad rate was wrong in the MyConfig.H file. Now i changed that and i tried a few different codes and librarys. Nothing seems to work.
                              So my question is which code and library should i use?
                              I got the slim node and sensor as in the first post.
                              Im running 1mhz optiboot bootloader from the slim node thread
                              And i updated mysensors to 2.1.
                              • E Eawo
                                m26872M
                                m26872M
                                m26872
                                @Eawo Sorry for a late reply. Please post your sketch to begin with.
                                Do you have v2.1 for both gateway and sensors?
                                "#define MY_BAUD_RATE 9600" should be before the "include MySensors.h" and that should be all regarding baud rate setting. No need to mess with MyConfig.h in v2.x.
                                A lot of the SlimNode example codes are still in v1.x unfortunately. So please look at more recent post above in this thread instead for v2.x.
                                To verify the Si7021 you should use a clean Arduino+Si7021 setup with the only hw/sw needed for that, i.e. no radio or MySensors-library. Si7021-example sketches generally comes with the lib.
                                • E
                                  E
                                  Eawo
                                  Ok i redid everything from skratch and now i got it working atleast with 1 node havnt tried the other yet.
                                  I used the code miljume did link the only line i changed was
                                  to
                                  #include <SI7021.h>
                                  It is working but it shows up as 2 nodes in domoticz
                                  1401 0 TempHum Temp + Humidity WTGR800 20.9 C, 35 % 2017-01-19 17:59:05
                                  1400 0 TempHum Temp + Humidity WTGR800 20.7 C, 34 % 2017-01-19 17:59:05
                                  anyone know why?
                                  also this does report every 60sec will this be short battery life?
                                  miljumeM 1 Reply Last reply
                                  • E Eawo
                                    to
                                    #include <SI7021.h>
                                    anyone know why?
                                    miljumeM
                                    miljumeM
                                    miljume
                                    @Eawo Domoticz groups sensors after the order you present them in, see: https://forum.mysensors.org/topic/5132/ds18b20-ans-sht31-d-show-up-as-combined-sensors-on-domoticz/15
                                    I send every 5 minutes and check the value before so that I only send if the value has changed
                                    I have been running my sensor for nearly 2 months now and battery level has only decreased 1-2%
                                    Make sure you use 1 MHz bootloader
