  2. Bug Reports
  3. [SOLVED] msg.getBool() issue related to string length
4 Posts 3 Posters 2.2k Views 3 Watching
  • BartEB
    BartEB
    BartE
    Playing around with my RGB controller, the module sometimes gets in a state in which i can not power off the lights.
    After sending a number of V_RGB message i'm sending a V_STATUS message with payload "0" which is not correct decoded by getBool()
    This is the logging:
    read: 0-0-9 s=1,c=1,t=2,pt=0,l=1,sg=0:0
    send: 9-9-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
    Message: 2
    Payload:
      getBool: 1
      getString: 01EBC6D600r
      getInt: 1
      getByte: 1
    Generated by this peace of code
    Serial.print("Message: ");
    Serial.println(message.type);
    Serial.println("Payload: ");
    Serial.print("  getBool: ");
    Serial.print("  getString: ");
    Serial.println(message.getString());
    Serial.print("  getInt: ");
    Serial.println(message.getInt());
    Serial.print("  getByte: ");
    Serial.println(message.getByte());
    It look that the payload length is not correctly used when decoding the message but correctly is displayed in the debug string
    I'm using MySensors version 1.5.3
    YveauxY 1 Reply Last reply
    • BartEB BartE
      Message: 2
      Payload:
        getBool: 1
        getInt: 1
        getByte: 1
      YveauxY
      YveauxY
      @BartE Update to 1.5.4. This is why 1.5.4 was released today ;-)
        wrote on last edited by hek
        Could you test the same on 1.5.4?
        https://github.com/mysensors/Arduino/releases/tag/1.5.4
        We had a regression that recently was fixed by @Anticimex .
        Edit: Damn, I didn't scroll down all the way to @Yveaux answer.. ;)
        • BartEB
          BartEB
          BartE
          @Yveaux and @hek bingo! That line in v 1.5.4 does solve the issue.
          Thx a lot for the support.
          Message: 2
          Payload:
            getBool: 0
            getString: 0
            getInt: 0
            getByte: 0
          OFF: Switch colors off
