  3. PH Probe code
PH Probe code
6 Posts 3 Posters 2.4k Views 3 Watching
  • S
    stingone
    Re: Mysensors P.H et E.C prob
    Hi everyone. I try to read my ph probe values from my arduino. However the files above are not working. I also used the test code however this is not incorporated in the mysensor files. can anyone supply the correct ino file?
    • S
      stingone
      Just found is however this one is based upon 3.3v im using 5v.
      0_1455210318592_PH_Probe_v1.1.ino.ino
      • S
        szybki946
        UWAGA: Błędny folder .ci w bibliotece 'MySensors'
        UWAGA: Błędny folder .mystools w bibliotece 'MySensors'
        1455210318534-ph_probe_v1.1.ino:8:22: error: MySensor.h: No such file or directory
        compilation terminated.
        exit status 1
        • S szybki946
          exit status 1
          @szybki946 the sketch was developed for MySensors 1.x. You'll need to convert it to MySensors 2.x if you want to use it with the newest version of the MySensors library (or download MySensors 1.x)
          Instructions for conversion are available at https://forum.mysensors.org/topic/4276/converting-a-sketch-from-1-5-x-to-2-0-x
          S 1 Reply Last reply
          • S
            szybki946
            This post is deleted!
              szybki946
              I'm not a programmer, I can not fix it
