  3. Chinese Solar Lipo powered PIR led lamp.
42 Posts 9 Posters 32.5k Views 19 Watching
  • siklosiS siklosi
    @gyro is there a reason you used high/low intensity with resistor instead of PWM?
    gyroG
    gyroG
    gyro
    @siklosi Resistor is used as transisistor base resistor. This was the best way to connect i could think off. But you need two output pins - 2 transistors are controlled.
    first PIN - lights ON/OFF
    second PIN - ligths bright ON/OFF
    • D Dylano
      mmm i ordered 1...
      So i hope i gonna ix this...
      It is looking higher mathematics
      Will see... when i have time..
      Thanks for the sketch!!!
      Give it a try in a uno ...
      gyroG
      gyroG
      gyro
      wrote on last edited by gyro
      #22
      @Dylano Great to hear that the light has the same board...please post a picture.
      My light is still protoype connected together on protoboard - connected to arduino pro mini - i can post only a picture connected elements on protoboard for now.
      I am trying to put all together in openhab now.
      I will try to make a list of exact elements.
      I have free D2 pin on arduino pro mini.
      • readykalR
        readykalR
        readykal
        As the easiest way to disable dimmed mode this lamp?
        • korttomaK
          korttomaK
          korttoma
          Got myself a similar PIR LED lamp. The functionality seems like it is the same but the circuit board is different.
          3_1461237714861_WP_20160415_06_56_45_Pro.jpg 2_1461237714860_WP_20160415_06_31_16_Pro.jpg 1_1461237714860_WP_20160415_06_30_18_Pro.jpg 0_1461237714859_WP_20160415_06_24_35_Pro.jpg
          • Tomas
          gyroG 1 Reply Last reply
          • korttomaK korttoma
            gyroG
            gyroG
            gyro
            #25
            @korttoma
            Nice to see some interest in smart solar lamps :)
            It looks like an updated version (at least i like it more from your pictures). Could you post an order link.
            I think this one should be even easier to intercept with "mysensors", beacause i see only two transistors and circuit connectios are clearly visible.
            so lets try to understand the circuit:
            -U3 is probably battery protection circuit
            • Q1 i think is voltage regulator HT33 - to power arduino wih 3.3V (meassure voltage)
            • take a photo of PIR sensor from front side (is there any ic elements)?
            • U1 - i would guess PIR sensor IC logic - leg 6 (count from dot on IC) should be output (meassure voltage - high 3,3 V when motion detected):
              -if it is output from PIR just remove R3 and IC ouput goes over resistor to you arduino input.
            • the output goes over resistor to Q2
              -whats is left - you have to figure out what drives resistor Q1(J3y) :
            • i gues its driven by solar cell, than collector is connected to resistor R10, resesitor is than connected over board to the other side.......
            • korttomaK
              korttomaK
              korttoma
              I guess you meant U4 is the 3.3V regulator. I measured it to 3.3V and HT33 should be a regulator. Q1 and Q2 I think are transistors. U3 handles the solar charging. U1 is for the PIR but unfortunately there is no text on the chip. I will get you the link tomorrow but it is quite easy to find on aliexpress.
              • Tomas
                gyroG
                gyroG
                gyro
                @korttoma
                sorry my typo: you are correct
                • U4 - HT33 is voltage regulator
                • yes Q1 and Q2 are transistors
                • U1 - PIR out test - measure voltage between PIN 6 and R3 when PIR is OF and ON. I think this drives Q2 (high brightness / low brightnes)
                also take picture of other side of circuit board, beause i think Q1 is conected to R10 and
                then further on the other side
                • korttomaK
                  korttomaK
                  korttoma
                  Here is the link to the one I got but it seems like the prize is allot higher now since I paid 23,84$ including shipping -> http://www.aliexpress.com/item/1-Set-1200-Lumens-46-pcs-LED-Solar-Power-Motion-Sensor-Lamp-Ultra-thin-PIR-Outdoor/32354254209.html
                  Also it took like 10 weeks for it to arrive so maybe another seller would be a better fit.
                  • Tomas
                  • korttomaK
                    korttomaK
                    korttoma
                    There is not much on the other side of the board, just a status LED, a button to turn it on and the PIR.
                    • Tomas
                      gyroG
                      gyroG
                      gyro
                      @korttoma
                      Are you sure that this light has two modes of operation or only one: when a person is present is activated for 15s and then switched off
                      • korttomaK
                        korttomaK
                        korttoma
                        I'm sorry I did not test the device I just read the manual so I think that yes it has 2 modes for LED brightness.
                        • Tomas
                          gyroG
                          gyroG
                          gyro
                          @korttoma
                          Don't be sorry.I am not an circuits expert, I just try help you figure things out.
                          You wil have to test this lamp a little bit.
                          it looks that Q1 drives U1 active/not active when there is sun, but how/what turns on dimm lights in dark?
                          Did you measure U1 pin 6 when pir active/not active?
                          • korttomaK
                            korttomaK
                            korttoma
                            In the application I will use this one I actually do not care so much for the built in PIR and LED, I just see it as a smart enclosure with a solar battery power-supply built in. I will tap in to the 3.3V regulator to power a pro mini that has an external PIR and (LDR) Light sensor. In addition to this I would like to add voltage measurement for the battery. BTW, did you komplette your sketch? I would like to copy the battery voltage sensor part. I will look att figuring out the circuit later, it does not look to complicated.
                            • Tomas
                              gyroG
                              gyroG
                              gyro
                              @korttoma
                              I did try some battery measurement variants. The following code works best for me. I suggest that you first try the following sketch.
                              • measure the voltage with voltmeter on VCC pin and correct #define VREF value so it will be a close as possible to measured value before you integrate into case specific code
                              // define values for the battery measurement
                              #define R1 1e6
                              #define R2 330e3
                              #define VMIN 2.8
                              #define VMAX 4.2
                              #define ADC_PRECISION 1023
                              #define VREF 1.13
                              int oldBatteryPcnt = 0;
                              int batteryVoltage = 0;
                              int BATTERY_SENSE_PIN = 0;
                              int val = 0;
                                   analogReference(INTERNAL1V1);
                                #else
                                   analogReference(INTERNAL);
                                Serial.begin(9600);
                                 //float batteryPcnt = getBatteryPercentage();
                                //val = analogRead(BATTERY_SENSE_PIN);
                                //Serial.println(batteryVoltage);
                                float batteryVoltage = getBatteryPercentage();
                                float batteryV= batteryVoltage;
                                float batteryVmap = fabs(fmap(batteryV, 2.5, 4.2, 0.0, 1000.0));
                                int batteryPcnt = batteryVmap / 10;
                                if (batteryPcnt >= 100) {
                              	  batteryPcnt = 99;
                                 Serial.print("Battery voltage: ");
                                 Serial.print(batteryPcnt);
                                 Serial.println(" %");
                              delay(2000);
                                 /*if (oldBatteryPcnt != batteryPcnt) {
                                   // Power up radio after sleep
                                   //gw.sendBatteryLevel(batteryPcnt);
                                   oldBatteryPcnt = batteryPcnt;
                                // totally random test values
                              float getBatteryPercentage() {
                                // read analog pin value
                                int inputValue = analogRead(BATTERY_SENSE_PIN);
                                // calculate the max possible value and therefore the range and steps
                                float voltageDividerFactor = (R1 + R2) / R2;
                                float maxValue = voltageDividerFactor * VREF;
                                float voltsPerBit = maxValue / ADC_PRECISION;
                                float batteryVoltage = voltsPerBit * inputValue;
                                float batteryPercentage = ((batteryVoltage-VMIN)/(VMAX-VMIN))*100;
                                //int batteryPercentage = map(batteryVoltage, 0, maxValue, 0, 100);
                                //return batteryPercentage;
                                return batteryVoltage;
                              float fmap(float x, float in_min, float in_max, float out_min, float out_max) {
                              	return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
                              • korttomaK
                                korttomaK
                                korttoma
                                This means that you use A0 for measuring right?
                                #define R1 1e6
                                #define R2 330e3
                                And you have used 1Mohm and 330kohm for the resistors?
                                • Tomas
                                  #define R1 1e6
                                  #define R2 330e3
                                  gyroG
                                  gyroG
                                  gyro
                                  #36
                                  Hi @korttoma
                                  • yes battery sense is A0
                                  • yes R1 and R2 are resistors values to measure Lipo voltage
                                  • korttomaK
                                    korttomaK
                                    korttoma
                                    Thanks for the code and the additional info. Measuring the battery seems to work as expected but using the Internal reference seems to mess with the light level measurement LDR. Is it possible to use indifferent reference for different analog inputs? Or do I need to recalculate my LDR voltage divider?
                                    • Tomas
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      I managed to squeeze in a pro mini and radio that is now powered from the 3.3V available from the built in circuit board. It has battery voltage measurement, light level and a external PIR.
                                      • Tomas
                                        gyroG
                                        gyroG
                                        gyro
                                        #39
                                        @korttoma great that you maneged to connect it lamp..
                                        I don't know if analog reference is than set for all analog interfaces..
                                        Just one more thing you should adjust:
                                        I have figured out that I need to raise alarm for lower threshold for battery to higher than 3V (now is 2.5V!) because regulator voltage drop is ~250mV, and mini pro drops out at around 2.8V..
                                        But the whole concept now works fairly good
                                        • ranseyerR
                                          ranseyerR
                                          ranseyer
                                          wrote on last edited by ranseyer
                                          #40
                                          im waiting to my Chinese Lamps. So i ordered in the meantime one directly in Germany: TaoTronics Solar ...-16 LED (Model TT-HSL002)
                                          https://www.amazon.de/gp/product/B00REDHZMW
                                          As you can see there is very different PCB. Do you have a hint for me if modification makes Sense ?
                                          ed: now with external images:
                                          Greetings
