  3. Chinese Solar Lipo powered PIR led lamp.
42 Posts 9 Posters 32.6k Views 19 Watching
  • soifS
    soifS
    soif
    wrote on last edited by soif
    @gyro
    Keep up the good work debugging this chinese box !
    This box is a really good value for money box to build mysensors projects ( at least box + lipo + solar panel).
    If your investigations let us to also use the built in Charger / PIR / LEDS , it would just be amazing.
    Please keep us in touch ! ;-)
    gyroG 1 Reply Last reply
    • soifS soif
      @gyro
      gyroG
      gyroG
      gyro
      wrote on last edited by gyro
      @soif , @GertSanders
      some progress was made, but i need an hardware advice.
      This is the part of schematic that drives the LEDs.
      First the battery is not connected directly (as here in schematic) but over protection IC logic.
      Question 1:
      Current circuit works as follows:
      • When solar cell voltage is higher than 0.7V , LED is OFF (sort off day/night sensor).
      • When solar voltage is lower than 0,7V, LED is shining with low intensity
      What is the the correct way to connect arduino pin D1 to take control over above described default behavior? (disconnect the line at SW4 and remove R9 -1Mohm)?
      Question 2:
      Which voltage measurement technique (internal reference or reference to regulated Vcc voltage) should i use to meassure Lipo voltage?
      What are correct/recommended resistor value for optimal battery utilization.
      Should this reference be used: https://github.com/rlogiacco/BatterySense
      Would make sense to measure also solar cell voltage?
      Question 3:
      Is arduino pin D2 connect properly? It control two level LED intensity:
      pin HIGH - LED glows with HIGH intensity (between led+ and led- is ~4V) pin LOW LED glows with LOW intensity (between led+ and led- is ~2,5V)
      Thanks for help and recommendations
      I have asked the same here, but no perfect answer jet:
      http://electronics.stackexchange.com/questions/218114/solar-battery-powered-leds-circuit-arduino-controlled
      • GertSandersG
        GertSandersG
        GertSanders
        @gyro
        Since you are using a atmega328p, it does make sense to measure the battery level and solar power level.
        If you make a node which does NOT sleep all the time, then monitoring both voltage levels is the starting point to make decisions.
        I'm guessing you want to add a node using the battery, so a node that sleeps until something needs to be done.
        In that case we need a trigger when the light is bright enough to switch off the leds, and dark enough to switch them on again.
        The trigger to wake up from sleep should be a voltage change on pin D2 or D3, and the voltage difference needs to be from below the lowest "HIGH" threshold to above the highest "LOW" threshold. Check the specification for the atmega328 you use, as this depends on the working voltage of the processor.
        The question I ask myself is what is the lowest voltage you get from the solar cell ? Looking at the circuit, they use the voltage of the solar cell to open the gate of a transistor, which then pulls the emitter voltage of a transistor to ground, which in turn switches off a second transistor with is feeding the battery current to the LEDs.
        Your question of the values of R2 and R11 is actually how to measure voltages over a resistor divider? You can choose any value of resistors, but their ratio is what is important.
        To calculate the resistor values:
        To measure at a maximum of 5V on an analog pin:
        R11 = R2 * (1 - voltage-ratio) / voltage-ratio
        To go from 6V to 5V the ratio = 5V / 6V = 0.83
        Take R2 as 1M Ohm, then R11 = 1M * (1 - 0.83) / 0.83 = 205K => a common value is 220K
        To check: voltage over R2 (which is the input voltage on the analog pin A0)
        V(A0) = Vinput * R2 / (R1 + R2) = 6V * 1M / (1M+220K) = 4.9 V
        • GertSandersG GertSanders
          @gyro
          gyroG
          gyroG
          gyro
          @GertSanders I think i managed to successfully connect arduino with solar lamp.
          My prototype is working, and has the following functions:
          1. Measure battery voltage (when charging it is alway 100% - makes sense)
          2. Measure solar voltage (can be omitted - but resistor should be there for a transistor to work properly)
          3. Solar power day/night trigger with transistor as a switch (can be used wake up arduino from sleep)
          4. PIR sensor (can be used wake up arduino from sleep)
          5. Lights on/off dimmed brightness
          6. Lights on/off high brightness ( original resistor R9 -1k was replaced with 4.7k - i think it draws to much current and sometimes hangs arduino)
          I will post the code later, but every part works with default "mysensor" examples
          How to connect and how to add elements see picture:
          GertSandersG siklosiS 2 Replies Last reply
          • gyroG gyro
            GertSandersG
            GertSandersG
            GertSanders
            @gyro
            Very nice work !!!!
            • D
              Dylano
              higher math for me...
              Great...
              Can you use the motion seperate from the liight?
              And can u use the light with a switch option? [ i will turn on the light when there is motion.. ]
              Or is the light switching only on lux?
              Domoticz, with a lot of working hardware, include mysensors :-)
              OpenPLI, RuneAudio, Solarmeter, etc......
              Not a great builder of software and hardware, more a user...
              Only i try to do my best :-(
              • D Dylano
                Great...
                gyroG
                gyroG
                gyro
                @GertSanders thanks, you have motivated my research
                @Dylano the purpose of this project was exactly what you have asked.
                The lamp is now mysensors aware.
                Every task can be operated separately.
                • When there is dark, the trigger is send, when the sun shines, the trigger is send. (transistor as switch). In scetch i use it as magnet switch part of code. When trigger is received (can wake up arduino), than you decide with controller what you want to do .
                • PIR acts as classic PIR sensor and can also be used as trigger. (can wake up arduino), than you decide with controller what you want to do.
                • The Lamp have two phases and can be controlled with controller (i control it over mqtt for now)
                • phase one is dimmed light (relay 1)
                • phase two is high bright light (relay 2)
                Below is code that works for now. I wil improve it in next few days
                // Enable debug prints
                #define MY_NODE_ID 11
                //unsigned long SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
                #define DIGITAL_INPUT_SENSOR 2   // The digital input you attached your motion sensor.  (Only 2 and 3 generates interrupt!)
                //#define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
                #define CHILD_ID 12   // Id of the sensor child
                boolean lastMotion = false;
                // Initialize motion message - start
                //trigger solar power day on/off -start
                #define CHILD_ID_SW 5
                #define BUTTON_PIN  5  // Arduino Digital I/O pin for button/reed switch
                Bounce debouncer = Bounce();
                int oldValue = -1;
                MyMessage SolarMsg(CHILD_ID_SW, V_TRIPPED);
                // trigger solar - end
                #define NUMBER_OF_RELAYS 2 // Total number of attached relays
                	//trigger solar power day on/off - start
                	// Setup the button
                	pinMode(BUTTON_PIN, INPUT);
                	// Activate internal pull-up
                	debouncer.attach(BUTTON_PIN);
                	debouncer.interval(5);
                	//trigger solar - end
                	for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
                		pinMode(pin, OUTPUT);
                		digitalWrite(pin, loadState(sensor) ? RELAY_ON : RELAY_OFF);
                	sendSketchInfo("Motion Sensor and light", "1.0");
                	present(CHILD_ID, S_MOTION);
                		present(sensor, S_LIGHT);
                		present(CHILD_ID_SW, S_DOOR);
                	// Read digital motion value
                	if (lastMotion != tripped) {
                		Serial.println(tripped);
                		lastMotion = tripped;
                		send(msg.set(tripped ? "1" : "0"));  // Send tripped value to gw
                	//sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                	debouncer.update();
                	// Get the update value
                	int value = debouncer.read();
                	if (value != oldValue) {
                		// Send in the new value
                		send(SolarMsg.set(value == HIGH ? 1 : 0));
                		oldValue = value;
                	//trigger solar power day on/off - stop
                		// Change relay state
                		digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
                		// Store state in eeprom
                • D
                  Dylano
                  mmm i ordered 1...
                  So i hope i gonna ix this...
                  It is looking higher mathematics
                  Will see... when i have time..
                  Thanks for the sketch!!!
                  Give it a try in a uno ...
                  • D
                    Dylano
                    guess what...
                    I do have a:
                    http://www.ebay.com/itm/161885080971?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
                    Exact the same board in of this light...
                    I think i going to try the make this work...
                    Only i do not understand exact the wiring of your example.
                    Will you please make a list of exact stuff to buy.
                    And make some more pictures, from the good places..
                    And a thing that i see.
                    You use D2 from the arduino.
                    Is that not a one for the radio?
                    • gyroG gyro
                      siklosiS
                      siklosiS
                      siklosi
                      @gyro is there a reason you used high/low intensity with resistor instead of PWM?
                      • siklosiS siklosi
                        gyroG
                        gyroG
                        gyro
                        @siklosi Resistor is used as transisistor base resistor. This was the best way to connect i could think off. But you need two output pins - 2 transistors are controlled.
                        first PIN - lights ON/OFF
                        second PIN - ligths bright ON/OFF
                        • D Dylano
                          mmm i ordered 1...
                          gyroG
                          gyroG
                          gyro
                          #22
                          @Dylano Great to hear that the light has the same board...please post a picture.
                          My light is still protoype connected together on protoboard - connected to arduino pro mini - i can post only a picture connected elements on protoboard for now.
                          I am trying to put all together in openhab now.
                          I will try to make a list of exact elements.
                          I have free D2 pin on arduino pro mini.
                          • readykalR
                            readykalR
                            readykal
                            As the easiest way to disable dimmed mode this lamp?
                            • korttomaK
                              korttomaK
                              korttoma
                              Got myself a similar PIR LED lamp. The functionality seems like it is the same but the circuit board is different.
                              3_1461237714861_WP_20160415_06_56_45_Pro.jpg 2_1461237714860_WP_20160415_06_31_16_Pro.jpg 1_1461237714860_WP_20160415_06_30_18_Pro.jpg 0_1461237714859_WP_20160415_06_24_35_Pro.jpg
                              • Tomas
                              • korttomaK korttoma
                                gyroG
                                gyroG
                                gyro
                                #25
                                @korttoma
                                Nice to see some interest in smart solar lamps :)
                                It looks like an updated version (at least i like it more from your pictures). Could you post an order link.
                                I think this one should be even easier to intercept with "mysensors", beacause i see only two transistors and circuit connectios are clearly visible.
                                so lets try to understand the circuit:
                                -U3 is probably battery protection circuit
                                • Q1 i think is voltage regulator HT33 - to power arduino wih 3.3V (meassure voltage)
                                • take a photo of PIR sensor from front side (is there any ic elements)?
                                • U1 - i would guess PIR sensor IC logic - leg 6 (count from dot on IC) should be output (meassure voltage - high 3,3 V when motion detected):
                                  -if it is output from PIR just remove R3 and IC ouput goes over resistor to you arduino input.
                                • the output goes over resistor to Q2
                                  -whats is left - you have to figure out what drives resistor Q1(J3y) :
                                • i gues its driven by solar cell, than collector is connected to resistor R10, resesitor is than connected over board to the other side.......
                                • korttomaK
                                  korttomaK
                                  korttoma
                                  I guess you meant U4 is the 3.3V regulator. I measured it to 3.3V and HT33 should be a regulator. Q1 and Q2 I think are transistors. U3 handles the solar charging. U1 is for the PIR but unfortunately there is no text on the chip. I will get you the link tomorrow but it is quite easy to find on aliexpress.
                                  • Tomas
                                    gyroG
                                    gyroG
                                    gyro
                                    @korttoma
                                    sorry my typo: you are correct
                                    • U4 - HT33 is voltage regulator
                                    • yes Q1 and Q2 are transistors
                                    • U1 - PIR out test - measure voltage between PIN 6 and R3 when PIR is OF and ON. I think this drives Q2 (high brightness / low brightnes)
                                    also take picture of other side of circuit board, beause i think Q1 is conected to R10 and
                                    then further on the other side
                                    • korttomaK
                                      korttomaK
                                      korttoma
                                      Here is the link to the one I got but it seems like the prize is allot higher now since I paid 23,84$ including shipping -> http://www.aliexpress.com/item/1-Set-1200-Lumens-46-pcs-LED-Solar-Power-Motion-Sensor-Lamp-Ultra-thin-PIR-Outdoor/32354254209.html
                                      Also it took like 10 weeks for it to arrive so maybe another seller would be a better fit.
                                      • Tomas
                                      • korttomaK
                                        korttomaK
                                        korttoma
                                        There is not much on the other side of the board, just a status LED, a button to turn it on and the PIR.
                                        • Tomas
                                          gyroG
                                          gyroG
                                          gyro
                                          @korttoma
                                          Are you sure that this light has two modes of operation or only one: when a person is present is activated for 15s and then switched off
