  3. sending string via nrf and the other receivers making trouble - why?
8 Posts 3 Posters 3.3k Views 2 Watching
  • choffmannC
    choffmannC
    choffmann
    ich have configured an arduino nano via nrf24L01+ and a LED-Stripe. My Idea is to send a LEDNumber and a HEX-Code for the color to set the LED to Color xy...
    I use FHEM and a own Perl-Method to convert the HEX Code to an Splittable string. This i send via Network-GW to my arduino as String.
    At this moment where the code is sending other receivers like Temp-Sensors sending 12502°C as Temperatur...
    I dont find the problem.
    Can somebody help?
    The sendet code via FHEM is:
    set <NAME> status7 0-0-255
    #include <EEPROM.h>
    #include <MyTransportNRF24.h>
    #include <MyHwATMega328.h>
    #include <RemoteReceiver.h>
    #include <RemoteTransmitter.h>
    #include <InterruptChain.h>
    #include "FastLED.h"
    #define DATA_PIN 3
    #define CLOCK_PIN 13
    #define NUM_LEDS 19
    CRGB leds[NUM_LEDS];
    #define NUMBER_OF_OUTLETS 99
    #define SN "LEDRahmenEG"
    #define SV "1.6"
    const byte SC_CHILD_ID = 0 ;
    //unsigned long receivedCode = 0 ;
    MyMessage scene_on(SC_CHILD_ID, V_LEVEL);
    MyMessage scene_off(SC_CHILD_ID, V_LEVEL);
      Serial.begin(115200);
      gw.begin(incomingMessage);
      gw.sendSketchInfo(SN, SV);
      FastLED.addLeds<NEOPIXEL, DATA_PIN>(leds, NUM_LEDS);
      //TEST
      //leds[9].g=1;
      //leds[9].b=255;
      //leds[10].r=255;
      //leds[11].b=255;
      //FastLED.show();
      //  Create a child device for each outlet
      for (int sensor = 1; sensor <= NUMBER_OF_OUTLETS; sensor++) {
        gw.present(sensor, S_LIGHT);
        delay(2);
      gw.process();
    String getValue(String data, char separator, int index) {
      int found = 0;
      int strIndex[] = {0, -1};
      int maxIndex = data.length() - 1;
      for (int i = 0; i <= maxIndex && found <= index; i++) {
        if (data.charAt(i) == separator || i == maxIndex) {
          found++;
          strIndex[0] = strIndex[1] + 1;
          strIndex[1] = (i == maxIndex) ? i + 1 : i;
      return found > index ? data.substring(strIndex[0], strIndex[1]) : "";
    //command has been received from gateway
      Serial.println(message.sensor);
      Serial.println(".......");
      Serial.println(message.getInt());
        Serial.print("LED ID #: ");
        Serial.print("Color: ");
        Serial.println(message.getString());
        //receive String like 125-255-111 call getValue and split
        //.toInt() convert the String Number to int and would be assigned to the LED
        leds[message.sensor].r = getValue(message.getString(), '-', 0).toInt();
        leds[message.sensor].g = getValue(message.getString(), '-', 1).toInt();
        leds[message.sensor].b = getValue(message.getString(), '-', 2).toInt();
        FastLED.show();
        if (message.sensor == 99) {
          for (int i = 0; i < NUM_LEDS; ++i) {
            leds[i].r = getValue(message.getString(), '-', 0).toInt();
            leds[i].g = getValue(message.getString(), '-', 1).toInt();
            leds[i].b = getValue(message.getString(), '-', 2).toInt();
            FastLED.show();
      delay(50);
    The Serial-Monitor shows
    • message.sensor = 7
    • message.getString() = 0-0-255enEG
    Why is there "enEG" at the end?
    Christian
      Make sure to run the latest version in master branch.
      • choffmannC
        choffmannC
        choffmann
        Sorry,
        what did you mean with that?
        what is a master branch?
          1.5.4 is the latest version on the master branch (on github).
          https://github.com/mysensors/Arduino/releases
          • choffmannC
            choffmannC
            choffmann
            OK,
            my Mysensors version is 1.5.3 i will update it.
            Do i have to update my Gateway too?
            In the link they talk about issues with the Getters in version 1.5.4. is this what you think that could be the problem?!
            m26872M 1 Reply Last reply
            • choffmannC choffmann
              OK,
              m26872M
              m26872M
              m26872
              @choffmann I would be very happy if you didn't mind to also share some of your FHEM code....?
              • choffmannC
                choffmannC
                choffmann
                i hope that i can update my arduino tomorrow, so that i can test if this will work....
                The FHEM code you want:
                The Devices:
                define LEDRahmen MYSENSORS_DEVICE 102 ... autmatic including des Reading/Devices
                define LEDRahmenSwitch dummy -- for setting LED and Color manually
                define LEDRahmenSwitchNotify notify LEDRahmenSwitch.* { sendLEDColor($EVTPART0, $EVTPART1) }
                and the 99_myUtils.pm Mehtods:
                (NEW: i have changed the Method from send String like 0-255-0 to 000-255-000 - see Method "changeLengthTo" )
                sub sendLEDColor($$){
                  my ($stat,$val) = @_;
                  my $tmp;
                  $tmp .= changeLengthTo(hexstr_to_signed32int(substr($val,0,2)),3);
                  $tmp .= "-";
                  $tmp .= changeLengthTo(hexstr_to_signed32int(substr($val,2,2)),3);
                  $tmp .= "-";
                  $tmp .= changeLengthTo(hexstr_to_signed32int(substr($val,4,6)),3);
                  #my $m = hexstr_to_signed32int($tmp);
                  #Log 1, "MeinE Testmethode";
                  #Log 1, $;
                  fhem("set LEDRahmen status".$stat." ".$tmp."");
                sub changeLengthTo($$){
                  my($str,$toLength) = @_;
                  my $tmpstr;
                  for(my $i = (length($str)+1); $i <= $toLength; $i++){
                    $tmpstr.= "0";
                  return $tmpstr.$str;
                sub hexstr_to_signed32int($) {
                    my ($hexstr) = @_;
                    die "Invalid hex string: $hexstr"
                        if $hexstr !~ /^[0-9A-Fa-f]{1,8}$/;
                    my $num = hex($hexstr);
                    return $num >> 31 ? $num - 2 ** 32 : $num;
                  The Devices:
                    my $tmp;
                    $tmp .= "-";
                    $tmp .= "-";
                    #Log 1, $;
                    my $tmpstr;
                      $tmpstr.= "0";
                      my ($hexstr) = @_;
                  m26872M
                  m26872M
                  m26872
                  @choffmann Thanks a lot! Please let us know you if the update solved your issue.
