  3. Home Assistant
  4. Any plan to implement Ethernet GW?
69 Posts 5 Posters 26.0k Views 6 Watching
  • Andrew SanjanwalaA
    Andrew SanjanwalaA
    Andrew Sanjanwala
    @martinhjelmare
    Though I'm eager to try, I can't actually launch the Ethernet Gateway branch in a Windows environment. The best error I can provide is the generic failed to create process on calling hass. Platform is Windows Home Server 2011 running Python 3.5.1. All previous and current release branches of home assistant launch without error.
    Any thoughts or other steps I can take to debug it further?
    • D drock1985
      @martinhjelmare
      Haven't had any issues with the sensors I have on my Dev unit; so far so good.
      Are you thinking of releasing the ethernet GW code in this weeks update?
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      @drock1985
      Good to hear. Have you tried connecting more than one node to the gateway at the same time?
      Unfortunately I don't think it will make this release, cause I won't have time until Sunday, and the release might be finished before that. I will add some updates this weekend that you are welcome to try. After that we should be ready for release.
      • Andrew SanjanwalaA Andrew Sanjanwala
        @martinhjelmare
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        @Andrew-Sanjanwala
        My experience with python on Windows is very limited. How do you normally start home assistant?
          Andrew SanjanwalaA
          Andrew Sanjanwala
          @martinhjelmare
          I typically launch either using hass or hass --open-ui from an administrative powershell session. No-go in either of these two cases.
            @martinhjelmare
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            @Andrew-Sanjanwala
            Did you install directly from my github branch using pip?
              Andrew SanjanwalaA
              Andrew Sanjanwala
              Alright, false alarm. Root issue in my case was a faulty environment and/or operator that resulted in binaries being compiled for the wrong platform.
              Once corrected, it compiled and launched your branch and connected to the gateway without incident. Next up is experimenting with the nodes and actuators. I'll see if the persistence file can be written to.
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @Andrew-Sanjanwala
                :thumbsup:
                • Dave DanD
                  Dave DanD
                  Dave Dan
                  Hey @martinhjelmare,
                  I've been able to do some tests this time.
                  From a Sensoring standpoint (retreive information from sensors to show in dashboard) works perfetly fine.
                  I found the issue that I was referring before.
                  Let's say you have already included a number of nodes and everything is working but for any reason you want to reset and start again. My logic was to remove the MSPersistance.json file, create a new one and the system will reconfigure again.
                  What I'm seeing is that if you do that the system enters in a limbo situation where no nodes are added but those that were beforer are not added either. you can't see them in the dashboard nor in the Developers Tools section.
                  Next step is to start testing relays, dimmers, etc.
                  Let me know if you need more detils on the scenario.
                  thanks!
                  • Dave DanD Dave Dan
                    thanks!
                    martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    Can you describe more in detail how you did this? Do you have an example persistence file before and after your modifications?
                    • Dave DanD
                      Dave DanD
                      Dave Dan
                      Sure!
                      the persistence once I've added some nodes looks like this:
                      {"104": {"sketch_version": "1.0", "children": {"0": {"id": 0, "values": {"1": "38.0"}, "type": 7}, "1": {"id": 1, "values": {"0": "22.0"}, "type": 6}, "2": {"id": 2, "values": {"23": "34"}, "type": 16}, "3": {"id": 3, "values": {"16": "0"}, "type": 1}}, "battery_level": 0, "sensor_id": 104, "type": 17, "sketch_name": "dyaSensor (HTLM)"}, "106": {"sketch_version": "1.0", "children": {"0": {"id": 0, "values": {"1": "37.0"}, "type": 7}, "1": {"id": 1, "values": {"0": "22.0"}, "type": 6}, "2": {"id": 2, "values": {"23": "5"}, "type": 16}, "3": {"id": 3, "values": {"16": "0"}, "type": 1}}, "battery_level": 9, "sensor_id": 106, "type": 17, "sketch_name": "dyaSensor (HTLM)"}, "156": {"sketch_version": null, "children": {}, "battery_level": 0, "sensor_id": 156, "type": 17, "sketch_name": null}, "101": {"sketch_version": "1.2", "children": {"0": {"id": 0, "values": {"1": "34.0"}, "type": 7}, "1": {"id": 1, "values": {"0": "21.0"}, "type": 6}, "2": {"id": 2, "values": {}, "type": 16}, "3": {"id": 3, "values": {"16": "0"}, "type": 1}}, "battery_level": 0, "sensor_id": 101, "type": 17, "sketch_name": "dyaSensor (HTLM) v1.2"}, "102": {"sketch_version": "1.0", "children": {"0": {"id": 0, "values": {"1": "36.0"}, "type": 7}, "1": {"id": 1, "values": {"0": "18.0"}, "type": 6}, "2": {"id": 2, "values": {"23": "69"}, "type": 16}, "3": {"id": 3, "values": {"16": "0"}, "type": 1}}, "battery_level": 2, "sensor_id": 102, "type": 17, "sketch_name": "dyaSensor (HTLM)"}}
                      after my modification (meaning, clear everything) looks this way:
                        Sure!
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        @Dave-Dan
                        Did you do it like this?
                        1. Stop hass.
                        2. Remove old persistence file.
                        3. Create new persistence file with the same name and path, containing an empty JSON object, "{}".
                        4. Start hass.
                        5. Start node. Result: Messages are coming in to gateway, but node sensors are not added to entities nor shown in GUI.
                        • Dave DanD
                          Dave DanD
                          Dave Dan
                          wrote on last edited by Dave Dan
                          #52
                          Exactly that.
                          maybe something to do with the fact that those items are already included in the DB (for history, etc) and the system can't add them again? (just guessing)
                          One more thing.
                          If I move the file and create a new one instead of deleting it. And after trying to add the items again I stop everything and restore the backup everything works again.
                            Exactly that.
                            One more thing.
                            martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            @Dave-Dan
                            I don't know yet, but I'll try to reproduce this and figure it out. Thanks for this report, and taking your time to test this.
                            I haven't had time to push my latest commits, that I had planned. I want to just test them quickly on my side before I push. But since you experience this problem, I think it's best to troubleshoot this first, before I push any new commits.
                            I'll post back here, once I have more info.
                            • Dave DanD
                              Dave DanD
                              Dave Dan
                              hey @martinhjelmare,
                              would it be possible to have an updated compilation with the 0.16 versión? I think the one you have above is 0.15 still (or older, right?)
                              I'd like to do more testing and integrate other items (for example the new Vera integration) with MySensors actuations, etc.
                              thanks in advance.
                                thanks in advance.
                                martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                @Dave-Dan
                                I'd like to investigate the issue you reported before I push any new commits or rebase off dev. Sorry to keep you waiting.
                                • Dave DanD
                                  Dave DanD
                                  Dave Dan
                                  ahh, ok, makes sense.
                                  no problem at all! :)
                                  • D
                                    D
                                    drock1985
                                    @Dave-Dan
                                    out of curiosity, did you try a different name for the persistence file after deleting your first one, or did you use the same name?
                                    My Projects
                                    2 Door Chime Sensor
                                    Washing Machine Monitor
                                    • Dave DanD
                                      Dave DanD
                                      Dave Dan
                                      hey @drock1985,
                                      No I didn't test that before, but I just did with the same results :(
                                      I can see in the log how messages are arriving to HA (see below). It's just I can't see them either in the group I created for them or in the Developer Tools.
                                      16-03-31 09:42:37 DEBUG (Thread-20) [mysensors.mysensors] Received 101;1;1;0;0;20.0
                                      16-03-31 09:42:37 DEBUG (Thread-20) [mysensors.mysensors] Received 101;0;1;0;1;36.0
                                      16-03-31 09:42:37 DEBUG (Thread-20) [mysensors.mysensors] Received 101;3;1;0;16;0
                                      If I go back and restore the previous file I can see them on both the group and the Developer Tools section.
                                      @martinhjelmare, hope this helps as well ... is is there any specific test you want me to perform please let me know.
                                        @Dave-Dan
                                        1. Stop hass.
                                        4. Start hass.
                                        martinhjelmareM
                                        martinhjelmareM
                                        martinhjelmare
                                        @Dave-Dan
                                        I finally had some time to test this again. Sorry for the long delay.
                                        I followed the steps here:
                                        @martinhjelmare said:
                                        @Dave-Dan
                                        1. Stop hass.
                                        4. Start hass.
                                        but I'm not able to reproduce your experienced problem. On my end, the node and sensor are added ok. Do you have any more clues what might be different on your end?
                                        HA config:
                                        mysensors:
                                          gateways:
                                            - device: '192.168.1.18'
                                              persistence_file: '/home/martin/.homeassistant/mysensors3.json'
                                              tcp_port: 5003
                                          debug: true
                                          persistence: true
                                          version: '1.5'
                                          optimistic: false
                                        console log:
                                        configuration.yaml  home-assistant.db  home-assistant.log  known_devices.yaml  lib  mysensors3.json
                                        martin@martin-nuc:~/.homeassistant$ cat mysensors3.json
                                        {"1": {"children": {"1": {"values": {"40": "ffffff", "2": "0", "3": "0"}, "id": 1, "type": 26}}, "sketch_version": "1.1", "sketch_name": "DimmableLED", "battery_level": 0, "sensor_id": 1, "type": 17}}
                                        martin@martin-nuc:~/.homeassistant$ rm mysensors3.json
                                        martin@martin-nuc:~/.homeassistant$ ls
                                        martin@martin-nuc:~/.homeassistant$ atom .
                                        {"1": {"battery_level": 0, "sensor_id": 1, "sketch_name": "DimmableLED", "children": {"1": {"values": {"40": "ffffff", "2": "0", "3": "0"}, "id": 1, "type": 26}}, "sketch_version": "1.1", "type": 17}}
                                        sensor serial log:
                                        send: 1-1-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                                        send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
                                        send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                        read: 0-0-1 s=255,c=3,t=15,pt=2,l=2,sg=0:0
                                        read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                        sensor started, id=1, parent=0, distance=1
                                        send: 1-1-0-0 s=1,c=0,t=26,pt=0,l=0,sg=0,st=ok:
                                        send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:DimmableLED
                                        send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                                        send: 1-1-0-0 s=1,c=2,t=3,pt=0,l=0,sg=0,st=ok:
                                        send: 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
                                        send: 1-1-0-0 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:0
                                        send: 1-1-0-0 s=1,c=1,t=40,pt=0,l=6,sg=0,st=ok:ffffff
                                        read: 0-0-1 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                                        Changing level to 100, from 0
                                        send: 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
                                        send: 1-1-0-0 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:100
                                        read: 0-0-1 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                                        Changing level to 0, from 100
                                        hass log:
                                        16-04-10 14:23:01 INFO (Thread-8) [mysensors.mysensors] Trying to connect to ('192.168.1.18', 5003)
                                        16-04-10 14:23:01 INFO (Thread-21) [homeassistant.core] Timer:starting
                                        16-04-10 14:23:01 INFO (Thread-8) [mysensors.mysensors] Connected to ('192.168.1.18', 5003)
                                        16-04-10 14:23:03 INFO (Thread-23) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                                        16-04-10 14:23:03 INFO (Thread-24) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -
                                        16-04-10 14:23:30 INFO (Thread-3) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.69, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>, new_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.66, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>>
                                        16-04-10 14:24:30 INFO (Thread-2) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.66, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>, new_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.6, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>>
                                        16-04-10 14:25:30 INFO (Thread-16) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.6, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>, new_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.54, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>>
                                        16-04-10 14:25:41 INFO (Thread-25) [homeassistant.components.http] "GET /static/frontend-833d09737fec24f9219efae87c5bfd2a.html HTTP/1.1" 200 -
                                        16-04-10 14:25:42 INFO (Thread-26) [homeassistant.components.http] "GET /static/favicon.ico HTTP/1.1" 200 -
                                        16-04-10 14:25:42 INFO (Thread-27) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -
                                        16-04-10 14:25:42 INFO (Thread-28) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                                        16-04-10 14:25:53 INFO (Thread-8) [homeassistant.components.mysensors] No sketch_name: node 1
                                        16-04-10 14:25:55 INFO (Thread-8) [homeassistant.components.mysensors] No sketch_name: node 1
                                        16-04-10 14:25:59 INFO (Thread-8) [homeassistant.components.mysensors] Adding new devices: <Entity DimmableLED 1.1: off>
                                        16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=None, new_state=<state light.dimmableled_11=unavailable; friendly_name=DimmableLED 1.1 @ 14:25:59 10-04-2016>>
                                        16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=None, new_state=<state group.all_lights=unknown; hidden=True, entity_id=[], auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>>
                                        16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=unknown; hidden=True, entity_id=[], auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>, new_state=None>
                                        16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=None, new_state=<state group.all_lights=unknown; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>>
                                        16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=unavailable; friendly_name=DimmableLED 1.1 @ 14:25:59 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>>
                                        16-04-10 14:25:59 INFO (Thread-17) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=unknown; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>, new_state=<state group.all_lights=off; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>>
                                        16-04-10 14:25:59 INFO (Thread-23) [homeassistant.components.api] Found broken event stream to 127.0.0.1, cleaning up
                                        16-04-10 14:26:19 INFO (Thread-29) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_on, domain=homeassistant, service_data=entity_id=light.dimmableled_11, service_call_id=140012061724232-1>
                                        16-04-10 14:26:19 INFO (Thread-15) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_on, domain=light, service_data=entity_id=['light.dimmableled_11'], service_call_id=140012061724232-2>
                                        16-04-10 14:26:19 INFO (Thread-9) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-2>
                                        16-04-10 14:26:19 INFO (Thread-15) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-1>
                                        16-04-10 14:26:19 INFO (Thread-29) [homeassistant.components.http] "POST /api/services/homeassistant/turn_on HTTP/1.1" 200 -
                                        16-04-10 14:26:21 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=on, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>>
                                        16-04-10 14:26:22 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=off; V_STATUS=on, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>, new_state=<state light.dimmableled_11=on; V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, rgb_color=[255, 255, 255], child_id=1, V_STATUS=on, brightness=255, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, node_id=1 @ 14:26:22 10-04-2016>>
                                        16-04-10 14:26:22 INFO (Thread-7) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=off; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>, new_state=<state group.all_lights=on; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:26:22 10-04-2016>>
                                        16-04-10 14:26:26 INFO (Thread-30) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_off, domain=homeassistant, service_data=entity_id=light.dimmableled_11, service_call_id=140012061724232-3>
                                        16-04-10 14:26:26 INFO (Thread-6) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_off, domain=light, service_data=entity_id=['light.dimmableled_11'], service_call_id=140012061724232-4>
                                        16-04-10 14:26:26 INFO (Thread-13) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-4>
                                        16-04-10 14:26:26 INFO (Thread-6) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-3>
                                        16-04-10 14:26:26 INFO (Thread-30) [homeassistant.components.http] "POST /api/services/homeassistant/turn_off HTTP/1.1" 200 -
                                        16-04-10 14:26:27 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=on; V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, rgb_color=[255, 255, 255], child_id=1, V_STATUS=on, brightness=255, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, node_id=1 @ 14:26:22 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:26:27 10-04-2016>>
                                        16-04-10 14:26:27 INFO (Thread-18) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=on; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:26:22 10-04-2016>, new_state=<state group.all_lights=off; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:26:27 10-04-2016>>
                                        16-04-10 14:26:28 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:26:27 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:26:27 10-04-2016>>
                                        • Dave DanD
                                          Dave DanD
                                          Dave Dan
                                          hey Martin.
                                          Sorry, I've been traveling for a while.
                                          So I just rebuilt my environment and I can't repro the issue anymore.
                                          If you can't either and no one else is experiencing this I think we can close this down. My environment might be the only thing that is creating the issue.
                                          If the issue happen again I can update with the new information.
