  3. Home Assistant
  4. Any plan to implement Ethernet GW?
69 Posts 5 Posters 26.0k Views 6 Watching
  • D drock1985
    Ugh, forgot to run the checkout command. palm smacks head
    Booting now, will report back in a minute if it is working or not.
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @drock1985
    Don't forget to use the correct ip address of your gateway in your network.
    • D
      D
      drock1985
      wrote on last edited by drock1985
      #22
      @martinhjelmare
      It works! Found my motion sensor with ease. Will start adding lights now shortly
      Thanks again, loving this.
      EDIT: Quick question: To autostart this, would I just use the normal Home-Assistant instructions in the virtualenv, or is there another method to do it?
      My Projects
      2 Door Chime Sensor
      Washing Machine Monitor
      • D drock1985
        @martinhjelmare
        martinhjelmareM
        martinhjelmareM
        martinhjelmare
        #23
        @drock1985
        :thumbsup:
        When you have time, can you run git log and tell me the top commit message, so I know which version you are using.
        Regarding autostart, no I don't think you can use the normal instructions together with the virtualenv. You could write a script, that changes to the virtualenv and starts hass, and run that script at login or similar.
        If you don't have another production install of home assistant on the computer, you can skip the virtualenv alltogether and just do:
        pip3 install --user "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
        or if you want to install as root:
        sudo pip3 install "https://github.com/MartinHjelmare/home-assistant/archive/mysensors-tcp-gateway.zip"
        This way you should be able to autostart the usual way, per instructions on the web.
        But then if you want to test an update from me, you have to make sure you uninstall everything correctly and manually remove ~/.homeassistant/lib before you install again.
        Dave DanD 1 Reply Last reply
        • D
          D
          drock1985
          @martinhjelmare
          Here is the info you requested:
          commit d07f8097a6186611371b8bc918fcb0d436bb39ba
          Author: MartinHjelmare <marhje52@kth.se>
          Date:   Sat Feb 27 04:55:38 2016 +0100
              Add mysensors tcp ethernet gateway
              * Replace CONF_PORT with CONF_DEVICE and ATTR_PORT with ATTR_DEVICE.
              * Add tcp_port in config.
              * Use fork pymysensors repo, temporarily.
              * Try to guess if tcp or serial gateway is configured, by validating
                  device name as an ip address. If successful setup tcp gateway, if it
                  fails, setup serial gateway.
              * Update device_state_attributes to show correct device, ethernet or
                  serial.
          commit 278fdc0983a8528945e13cf912da82f3bc5fe14c
          Merge: 6dc49df 8ffa368
          Author: Daniel Høyer Iversen <daniel.h.iversen@ntnu.no>
          Date:   Fri Feb 26 10:49:10 2016 +0100
              Merge pull request #1385 from balloob/rfxtrx
              improve rfxtrx sensor
          My Projects
          2 Door Chime Sensor
          • D drock1985
            @martinhjelmare
                    serial.
            martinhjelmareM
            martinhjelmareM
            martinhjelmare
            #25
            @drock1985
            Sorry, I forgot I've only updated the pymysensors project, so you checking the home-assistant git log is no use. Well, I think your're running the lastest version anyway, since you got it working just now. Everything should be ok.
            Let me know if you experience any problems.
            If everything seems ok for you after some time of testing, I don't see why we can't release this very soon. My limited testing after the lastest update, show no problems.
            • Dave DanD
              Dave DanD
              Dave Dan
              Hey @martinhjelmare,
              I finally got this working.
              I'm doing tests with a couple of multi-sensors (Temp, Hum, Light & motion). The discovery worked very well, no issue at all after following all the above steps.
              What I'm not seeing wotking are the updates. I always see the same values. I'm checking messages with MYSController and I see the GW is receiving the events and updates but I can't see new values showing in the portal.
              Still testing ...
              • Dave DanD Dave Dan
                Still testing ...
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @Dave-Dan
                Do you mean that the sensors are not showing the latest values in the gui?
                If the last value from a sensor is the same as the previous value, a state change won't happen. So the value will be reported as being as old as the previous value. Could this explain what you see?
                • Dave DanD
                  Dave DanD
                  Dave Dan
                  actually, I just got it working ...
                  yes, I was referrring to that. The way I have built the sensor is that everytime a movement is detected is sending all sensors statuses to the GW. This sensors are designed to be plugged (no battery powered) so no concern on power consumption.
                  I restarted the server and now updates are working.
                  What I'm seeing in the log is constantly this message:
                  16-03-14 10:39:53 INFO (Thread-9) [mysensors.mysensors] Permission denied when writing to /home/pi/dev/home-assistant/path/mysensors3.json
                  If I'm not wrong this is the persistence.
                  Apart of this I now see updates coming in ...
                  • martinhjelmareM
                    martinhjelmareM
                    martinhjelmare
                    Good!
                    The path to the persistence file must exist, not the file itself, but the directory tree above, and hass should have write permission to it.
                    I usually put the file in the same directory as configuration.yml.
                    • Dave DanD
                      Dave DanD
                      Dave Dan
                      Ok, couple of things that I'm seeing now.
                      1. Everytime I restart the server the MySensor nodes are no longer in the system. I have to restart them to get them in again. All of them are in the persistence file.
                      2. Now i can only have 1 node added.
                        While in the persistence file I see multiple nodes, once I add one of them I can't add anymore. No error if fired (at least not that I've seen).
                        martinhjelmareM
                        martinhjelmareM
                        martinhjelmare
                        @Dave-Dan
                        Can you attach the persistence file here and post your config, and I'll take a look?
                        • Dave DanD
                          Dave DanD
                          Dave Dan
                          wrote on last edited by Dave Dan
                          #32
                          Sure!
                          Consistence file:
                          {"156": {"sketch_version": null, "children": {}, "battery_level": 0, "sketch_name": null, "type": 17, "sensor_id": 156}, "102": {"sketch_version": null, "children": {}, "battery_level": 0, "sketch_name": null, "type": 17, "sensor_id": 102}}
                          the Configuration is very light. Actually is the by default config and i just added this to test MySensors:
                          mysensors:
                            gateways:
                              - device: 192.168.1.X
                                persistence_file: '/home/pi/.homeassistant/MSPersistence.json'
                                tcp_port: 5003
                            debug: true
                            persistence: true
                            version: '1.5'
                          let me know if you need anything else.
                          • martinhjelmareM
                            martinhjelmareM
                            martinhjelmare
                            In the persistence file I can see two issues.
                            Sketch name is null for both nodes.
                            Both nodes don't have any children.
                            Are you using a non default example sketch, if so can you post it?
                            • Dave DanD
                              Dave DanD
                              Dave Dan
                              hey Martin,
                              that's correct, those are the 2 items I saw that was little curious about.
                              The sketch I'm using, while custom, is a mix of different sketches that can be found in the MySensors page.
                              As you'll see below, each node (which are identical) have all the information (Sketch name, version, etc). And all of them have 4 childs:
                              - Ambient Humidity
                              - Ambient Temperature
                              - Ambient Light
                              - Movement (Motion Sensor Trip).
                              But I might have something wrong so ... happy to learn! :)
                              #include <DHT.h>
                              #define NODE_ID 102
                              #define SKETCH_NAME "dyaSensor (HTLM) v1.2"
                              #define SKETCH_VERSION "1.2"
                              #define CHILD_ID_HUM 0
                              #define CHILD_ID_TEMP 1
                              #define CHILD_ID_LIGHT 2
                              #define CHILD_ID_MOV 3
                              #define HUMIDITY_SENSOR_DIGITAL_PIN 4
                              #define LIGHT_SENSOR_ANALOG_PIN 0
                              #defin TEMP_CORRECTION 2
                              unsigned long SLEEP_TIME = 1000; // Sleep time between reads (in milliseconds)
                              DHT dht;
                              float lastTemp;
                              float lastHum;
                              int lastLightLevel;
                              boolean metric = true;
                              //Building Messages
                              MyMessage msgHum(CHILD_ID_HUM, V_HUM);            // Initialize humidity message
                              MyMessage msgTemp(CHILD_ID_TEMP, V_TEMP);         // Initialize temperature message
                              MyMessage msgLum(CHILD_ID_LIGHT, V_LIGHT_LEVEL);  // Initialize Light message
                              MyMessage msgMov(CHILD_ID_MOV, V_TRIPPED);        // Initialize motion message
                                gw.begin(NULL, NODE_ID, false);
                                gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
                                Serial.println("Presenting Humidity Sensor");
                                gw.present(CHILD_ID_HUM, S_HUM, "Humidity Sensor");
                                Serial.println("Presenting Temperature Sensor");
                                gw.present(CHILD_ID_TEMP, S_TEMP, "Temperature Sensor");
                                Serial.println("Light Level Sensor");
                                gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL, "Light Level Sensor");
                                Serial.println("Presenting Motion Sensor");
                                gw.present(CHILD_ID_MOV, S_MOTION, "Motion Sensor");
                                // By calling process() you route messages in the background
                                gw.process();
                                float temperature = dht.getTemperature()-TEMP_CORRECTION;
                                if (isnan(temperature)) {
                                  lastTemp = temperature;
                                  if (!metric) {
                                  Serial.print("- T: ");
                                  Serial.println(temperature);
                                if (isnan(humidity)) {
                                    lastHum = humidity;
                                    Serial.print("- H: ");
                                    Serial.println(humidity);
                                int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
                                  lastLightLevel = lightLevel;
                                  gw.send(msgLum.set(lightLevel));
                                  Serial.print("- L: ");
                                  Serial.println(lightLevel);
                                // Read digital motion value
                                gw.send(msgMov.set(tripped?"1":"0"));  // Send tripped value to gw
                                Serial.println(tripped?"- Movement Detected":"- No Movement Detected");
                                gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
                                @drock1985
                                :thumbsup:
                                Dave DanD
                                Dave DanD
                                Dave Dan
                                #35
                                Hey @martinhjelmare
                                Does the above reply to @drock1985 means that I can do a basic installation as per https://home-assistant.io/
                                pip3 install homeassistant
                                hass --open-ui
                                followed by
                                and will have a valid testing env without going into all the above steps of creating a virtualenv??
                                If so I'd rather more this avenue because I can clean up everything with a new installation, install the zip and have a new testing env in minutes :)
                                martinhjelmareM 2 Replies Last reply
                                  Hey @martinhjelmare
                                  hass --open-ui
                                  followed by
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  @Dave-Dan
                                  I can't see any big issues with your sketch, just one small:
                                  I guess this is a typo:
                                  Since your sketch looks ok, I think something must have gone wrong with the communication between node and gateway. Have you been monitoring the comm, with a serial monitor, on the node side for example, to make sure all messages are sent ok?
                                    Hey @martinhjelmare
                                    hass --open-ui
                                    followed by
                                    martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    @Dave-Dan
                                    The zip file you install from my github account, is the mysensors tcp gateway branch of home-assistant. So you shouldn't install home-assistant first, if you're going to install my branch.
                                    If you don't have any other version of home-assistant that you wish to keep, on the same computer, you can install my branch directly. You just have to make sure you uninstall it and remove ~/.homeassistant/lib before installing an update from me, if I commit some updates.
                                    Yeah, setting up a dev machine can be a hassle the first time, and not so useful if you're not developing with it.
                                      @Dave-Dan
                                      Dave DanD
                                      Dave DanD
                                      Dave Dan
                                      @martinhjelmare
                                      thanks for the hint ... definetly a typo :$
                                      Yes, I'm monitoring the GW with MYSController as my GW is ethernet and I see all messages showing with no issue. But, I'll be happy to review again. :)
                                        @martinhjelmare
                                        martinhjelmareM
                                        martinhjelmareM
                                        martinhjelmare
                                        @Dave-Dan
                                        Yes, please start from the beginning:
                                        Remove the persistence file
                                        Start hass
                                        Wait until you see that hass has (:smile:) connected to the gateway
                                        Start a node
                                        Start the next node
                                        If you can post the serial log from that here, and also the log from hass, that would be great.
                                        • D
                                          D
                                          drock1985
                                          @martinhjelmare
                                          Haven't had any issues with the sensors I have on my Dev unit; so far so good.
                                          Are you thinking of releasing the ethernet GW code in this weeks update?
                                          My Projects
                                          2 Door Chime Sensor
