  3. Home Assistant
  4. Any plan to implement Ethernet GW?
69 Posts 5 Posters 26.0k Views 6 Watching
  • Dave DanD
    Dave DanD
    Dave Dan
    Hey @martinhjelmare,
    I've been able to do some tests this time.
    From a Sensoring standpoint (retreive information from sensors to show in dashboard) works perfetly fine.
    I found the issue that I was referring before.
    Let's say you have already included a number of nodes and everything is working but for any reason you want to reset and start again. My logic was to remove the MSPersistance.json file, create a new one and the system will reconfigure again.
    What I'm seeing is that if you do that the system enters in a limbo situation where no nodes are added but those that were beforer are not added either. you can't see them in the dashboard nor in the Developers Tools section.
    Next step is to start testing relays, dimmers, etc.
    Let me know if you need more detils on the scenario.
    thanks!
    • Dave DanD Dave Dan
      thanks!
      martinhjelmareM
      martinhjelmareM
      martinhjelmare
      Can you describe more in detail how you did this? Do you have an example persistence file before and after your modifications?
      • Dave DanD
        Dave DanD
        Dave Dan
        Sure!
        the persistence once I've added some nodes looks like this:
        {"104": {"sketch_version": "1.0", "children": {"0": {"id": 0, "values": {"1": "38.0"}, "type": 7}, "1": {"id": 1, "values": {"0": "22.0"}, "type": 6}, "2": {"id": 2, "values": {"23": "34"}, "type": 16}, "3": {"id": 3, "values": {"16": "0"}, "type": 1}}, "battery_level": 0, "sensor_id": 104, "type": 17, "sketch_name": "dyaSensor (HTLM)"}, "106": {"sketch_version": "1.0", "children": {"0": {"id": 0, "values": {"1": "37.0"}, "type": 7}, "1": {"id": 1, "values": {"0": "22.0"}, "type": 6}, "2": {"id": 2, "values": {"23": "5"}, "type": 16}, "3": {"id": 3, "values": {"16": "0"}, "type": 1}}, "battery_level": 9, "sensor_id": 106, "type": 17, "sketch_name": "dyaSensor (HTLM)"}, "156": {"sketch_version": null, "children": {}, "battery_level": 0, "sensor_id": 156, "type": 17, "sketch_name": null}, "101": {"sketch_version": "1.2", "children": {"0": {"id": 0, "values": {"1": "34.0"}, "type": 7}, "1": {"id": 1, "values": {"0": "21.0"}, "type": 6}, "2": {"id": 2, "values": {}, "type": 16}, "3": {"id": 3, "values": {"16": "0"}, "type": 1}}, "battery_level": 0, "sensor_id": 101, "type": 17, "sketch_name": "dyaSensor (HTLM) v1.2"}, "102": {"sketch_version": "1.0", "children": {"0": {"id": 0, "values": {"1": "36.0"}, "type": 7}, "1": {"id": 1, "values": {"0": "18.0"}, "type": 6}, "2": {"id": 2, "values": {"23": "69"}, "type": 16}, "3": {"id": 3, "values": {"16": "0"}, "type": 1}}, "battery_level": 2, "sensor_id": 102, "type": 17, "sketch_name": "dyaSensor (HTLM)"}}
        after my modification (meaning, clear everything) looks this way:
          Sure!
          martinhjelmareM
          martinhjelmareM
          martinhjelmare
          @Dave-Dan
          Did you do it like this?
          1. Stop hass.
          2. Remove old persistence file.
          3. Create new persistence file with the same name and path, containing an empty JSON object, "{}".
          4. Start hass.
          5. Start node. Result: Messages are coming in to gateway, but node sensors are not added to entities nor shown in GUI.
          • Dave DanD
            Dave DanD
            Dave Dan
            wrote on last edited by Dave Dan
            #52
            Exactly that.
            maybe something to do with the fact that those items are already included in the DB (for history, etc) and the system can't add them again? (just guessing)
            One more thing.
            If I move the file and create a new one instead of deleting it. And after trying to add the items again I stop everything and restore the backup everything works again.
              Exactly that.
              One more thing.
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @Dave-Dan
              I don't know yet, but I'll try to reproduce this and figure it out. Thanks for this report, and taking your time to test this.
              I haven't had time to push my latest commits, that I had planned. I want to just test them quickly on my side before I push. But since you experience this problem, I think it's best to troubleshoot this first, before I push any new commits.
              I'll post back here, once I have more info.
              • Dave DanD
                Dave DanD
                Dave Dan
                hey @martinhjelmare,
                would it be possible to have an updated compilation with the 0.16 versión? I think the one you have above is 0.15 still (or older, right?)
                I'd like to do more testing and integrate other items (for example the new Vera integration) with MySensors actuations, etc.
                thanks in advance.
                  thanks in advance.
                  martinhjelmareM
                  martinhjelmareM
                  martinhjelmare
                  @Dave-Dan
                  I'd like to investigate the issue you reported before I push any new commits or rebase off dev. Sorry to keep you waiting.
                  • Dave DanD
                    Dave DanD
                    Dave Dan
                    ahh, ok, makes sense.
                    no problem at all! :)
                    • D
                      drock1985
                      @Dave-Dan
                      out of curiosity, did you try a different name for the persistence file after deleting your first one, or did you use the same name?
                      My Projects
                      2 Door Chime Sensor
                      Washing Machine Monitor
                      • Dave DanD
                        Dave DanD
                        Dave Dan
                        hey @drock1985,
                        No I didn't test that before, but I just did with the same results :(
                        I can see in the log how messages are arriving to HA (see below). It's just I can't see them either in the group I created for them or in the Developer Tools.
                        16-03-31 09:42:37 DEBUG (Thread-20) [mysensors.mysensors] Received 101;1;1;0;0;20.0
                        16-03-31 09:42:37 DEBUG (Thread-20) [mysensors.mysensors] Received 101;0;1;0;1;36.0
                        16-03-31 09:42:37 DEBUG (Thread-20) [mysensors.mysensors] Received 101;3;1;0;16;0
                        If I go back and restore the previous file I can see them on both the group and the Developer Tools section.
                        @martinhjelmare, hope this helps as well ... is is there any specific test you want me to perform please let me know.
                          @Dave-Dan
                          1. Stop hass.
                          4. Start hass.
                          martinhjelmareM
                          martinhjelmareM
                          martinhjelmare
                          @Dave-Dan
                          I finally had some time to test this again. Sorry for the long delay.
                          I followed the steps here:
                          @martinhjelmare said:
                          @Dave-Dan
                          1. Stop hass.
                          4. Start hass.
                          but I'm not able to reproduce your experienced problem. On my end, the node and sensor are added ok. Do you have any more clues what might be different on your end?
                          HA config:
                          mysensors:
                            gateways:
                              - device: '192.168.1.18'
                                persistence_file: '/home/martin/.homeassistant/mysensors3.json'
                                tcp_port: 5003
                            debug: true
                            persistence: true
                            version: '1.5'
                            optimistic: false
                          console log:
                          configuration.yaml  home-assistant.db  home-assistant.log  known_devices.yaml  lib  mysensors3.json
                          martin@martin-nuc:~/.homeassistant$ cat mysensors3.json
                          {"1": {"children": {"1": {"values": {"40": "ffffff", "2": "0", "3": "0"}, "id": 1, "type": 26}}, "sketch_version": "1.1", "sketch_name": "DimmableLED", "battery_level": 0, "sensor_id": 1, "type": 17}}
                          martin@martin-nuc:~/.homeassistant$ rm mysensors3.json
                          martin@martin-nuc:~/.homeassistant$ ls
                          martin@martin-nuc:~/.homeassistant$ atom .
                          {"1": {"battery_level": 0, "sensor_id": 1, "sketch_name": "DimmableLED", "children": {"1": {"values": {"40": "ffffff", "2": "0", "3": "0"}, "id": 1, "type": 26}}, "sketch_version": "1.1", "type": 17}}
                          sensor serial log:
                          send: 1-1-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                          send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
                          send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                          read: 0-0-1 s=255,c=3,t=15,pt=2,l=2,sg=0:0
                          read: 0-0-1 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                          sensor started, id=1, parent=0, distance=1
                          send: 1-1-0-0 s=1,c=0,t=26,pt=0,l=0,sg=0,st=ok:
                          send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=11,sg=0,st=ok:DimmableLED
                          send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                          send: 1-1-0-0 s=1,c=2,t=3,pt=0,l=0,sg=0,st=ok:
                          send: 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:0
                          send: 1-1-0-0 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:0
                          send: 1-1-0-0 s=1,c=1,t=40,pt=0,l=6,sg=0,st=ok:ffffff
                          read: 0-0-1 s=1,c=1,t=2,pt=0,l=1,sg=0:1
                          Changing level to 100, from 0
                          send: 1-1-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,st=ok:1
                          send: 1-1-0-0 s=1,c=1,t=3,pt=2,l=2,sg=0,st=ok:100
                          read: 0-0-1 s=1,c=1,t=2,pt=0,l=1,sg=0:0
                          Changing level to 0, from 100
                          hass log:
                          16-04-10 14:23:01 INFO (Thread-8) [mysensors.mysensors] Trying to connect to ('192.168.1.18', 5003)
                          16-04-10 14:23:01 INFO (Thread-21) [homeassistant.core] Timer:starting
                          16-04-10 14:23:01 INFO (Thread-8) [mysensors.mysensors] Connected to ('192.168.1.18', 5003)
                          16-04-10 14:23:03 INFO (Thread-23) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                          16-04-10 14:23:03 INFO (Thread-24) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -
                          16-04-10 14:23:30 INFO (Thread-3) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.69, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>, new_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.66, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>>
                          16-04-10 14:24:30 INFO (Thread-2) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.66, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>, new_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.6, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>>
                          16-04-10 14:25:30 INFO (Thread-16) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=sun.sun, old_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.6, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>, new_state=<state sun.sun=above_horizon; next_rising=03:40:47 11-04-2016, icon=mdi:air-conditioner, elevation=35.54, next_setting=17:52:06 10-04-2016, friendly_name=Customized Sun @ 14:23:01 10-04-2016>>
                          16-04-10 14:25:41 INFO (Thread-25) [homeassistant.components.http] "GET /static/frontend-833d09737fec24f9219efae87c5bfd2a.html HTTP/1.1" 200 -
                          16-04-10 14:25:42 INFO (Thread-26) [homeassistant.components.http] "GET /static/favicon.ico HTTP/1.1" 200 -
                          16-04-10 14:25:42 INFO (Thread-27) [homeassistant.components.http] "GET /api/bootstrap HTTP/1.1" 200 -
                          16-04-10 14:25:42 INFO (Thread-28) [homeassistant.components.http] "GET /api/stream?api_password=no_password_set&restrict=state_changed,component_loaded,service_registered HTTP/1.1" 200 -
                          16-04-10 14:25:53 INFO (Thread-8) [homeassistant.components.mysensors] No sketch_name: node 1
                          16-04-10 14:25:55 INFO (Thread-8) [homeassistant.components.mysensors] No sketch_name: node 1
                          16-04-10 14:25:59 INFO (Thread-8) [homeassistant.components.mysensors] Adding new devices: <Entity DimmableLED 1.1: off>
                          16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=None, new_state=<state light.dimmableled_11=unavailable; friendly_name=DimmableLED 1.1 @ 14:25:59 10-04-2016>>
                          16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=None, new_state=<state group.all_lights=unknown; hidden=True, entity_id=[], auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>>
                          16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=unknown; hidden=True, entity_id=[], auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>, new_state=None>
                          16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=None, new_state=<state group.all_lights=unknown; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>>
                          16-04-10 14:25:59 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=unavailable; friendly_name=DimmableLED 1.1 @ 14:25:59 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>>
                          16-04-10 14:25:59 INFO (Thread-17) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=unknown; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>, new_state=<state group.all_lights=off; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>>
                          16-04-10 14:25:59 INFO (Thread-23) [homeassistant.components.api] Found broken event stream to 127.0.0.1, cleaning up
                          16-04-10 14:26:19 INFO (Thread-29) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_on, domain=homeassistant, service_data=entity_id=light.dimmableled_11, service_call_id=140012061724232-1>
                          16-04-10 14:26:19 INFO (Thread-15) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_on, domain=light, service_data=entity_id=['light.dimmableled_11'], service_call_id=140012061724232-2>
                          16-04-10 14:26:19 INFO (Thread-9) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-2>
                          16-04-10 14:26:19 INFO (Thread-15) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-1>
                          16-04-10 14:26:19 INFO (Thread-29) [homeassistant.components.http] "POST /api/services/homeassistant/turn_on HTTP/1.1" 200 -
                          16-04-10 14:26:21 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=on, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>>
                          16-04-10 14:26:22 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=off; V_STATUS=on, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:25:59 10-04-2016>, new_state=<state light.dimmableled_11=on; V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, rgb_color=[255, 255, 255], child_id=1, V_STATUS=on, brightness=255, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, node_id=1 @ 14:26:22 10-04-2016>>
                          16-04-10 14:26:22 INFO (Thread-7) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=off; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:25:59 10-04-2016>, new_state=<state group.all_lights=on; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:26:22 10-04-2016>>
                          16-04-10 14:26:26 INFO (Thread-30) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_off, domain=homeassistant, service_data=entity_id=light.dimmableled_11, service_call_id=140012061724232-3>
                          16-04-10 14:26:26 INFO (Thread-6) [homeassistant.core] Bus:Handling <Event call_service[L]: service=turn_off, domain=light, service_data=entity_id=['light.dimmableled_11'], service_call_id=140012061724232-4>
                          16-04-10 14:26:26 INFO (Thread-13) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-4>
                          16-04-10 14:26:26 INFO (Thread-6) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=140012061724232-3>
                          16-04-10 14:26:26 INFO (Thread-30) [homeassistant.components.http] "POST /api/services/homeassistant/turn_off HTTP/1.1" 200 -
                          16-04-10 14:26:27 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=on; V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, rgb_color=[255, 255, 255], child_id=1, V_STATUS=on, brightness=255, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, node_id=1 @ 14:26:22 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:26:27 10-04-2016>>
                          16-04-10 14:26:27 INFO (Thread-18) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=group.all_lights, old_state=<state group.all_lights=on; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:26:22 10-04-2016>, new_state=<state group.all_lights=off; hidden=True, entity_id=('light.dimmableled_11',), auto=True, order=1, friendly_name=all lights @ 14:26:27 10-04-2016>>
                          16-04-10 14:26:28 INFO (Thread-8) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=light.dimmableled_11, old_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=100, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:26:27 10-04-2016>, new_state=<state light.dimmableled_11=off; V_STATUS=off, node_id=1, V_RGB=ffffff, V_PERCENTAGE=0, battery_level=0, device=192.168.1.18:5003, friendly_name=DimmableLED 1.1, child_id=1 @ 14:26:27 10-04-2016>>
                          • Dave DanD
                            Dave DanD
                            Dave Dan
                            hey Martin.
                            Sorry, I've been traveling for a while.
                            So I just rebuilt my environment and I can't repro the issue anymore.
                            If you can't either and no one else is experiencing this I think we can close this down. My environment might be the only thing that is creating the issue.
                            If the issue happen again I can update with the new information.
                              hey Martin.
                              martinhjelmareM
                              martinhjelmareM
                              martinhjelmare
                              @Dave-Dan
                              Great! Then I'll move forward and push my latest changes to my github branch. I'll post here when that is done. You're welcome to test these by the update instructions above.
                              If nothing comes up, my plan is to have this merged in the next release of home assistant.
                                subutux
                                I've also tested your pymysensors version with tcp gateway. I've had an excessive cpu usage on my pi Zero (actually, a constant 100%). After some debugging I've found that I've had to add a sleep of 0.2 to the while loop of the top socket readout. My cpu usage returned normal.
                                What I've also encountered is that when the tcp gateway looses connection, pymysensors still thinks it's connected. I've buildin an active check by requesting the gateway version every 10 seconds.
                                Would you like me to make a pull request ?
                                martinhjelmareM 3 Replies Last reply
                                • S subutux
                                  martinhjelmareM
                                  martinhjelmareM
                                  martinhjelmare
                                  @subutux
                                  Thanks for the feedback!
                                  I've got some commits that are not pushed yet with some changes, but a pull request should be good anyhow. Great!
                                    I've updated the branch at my fork of pymysensors. If you have installed the ethernet branch of my fork of home-assistant, you should uninstall/reinstall that, or just make a new virtual environment and install again. You should remove the lib directory in your home assistant config directory as well.
                                    Eg:
                                    rm -r ~/.homeassistant/lib
                                    mkvirtualenv -p /usr/bin/python3 hasstest2
                                    cd ~/dev/home-assistant
                                    git branch -D mysensors-tcp-gateway
                                    git fetch origin mysensors-tcp-gateway
                                    git checkout mysensors-tcp-gateway
                                    pip3 install -e .
                                    pip3 install colorlog
                                    pip3 install python-Levenshtein
                                    martinhjelmareM
                                    martinhjelmareM
                                    martinhjelmare
                                    #64
                                    I've now pushed some updates to my ethernet gateway branch of pymysensors and rebased my home-assistant mysensors-tcp-gateway branch off latest upstream dev branch and pushed that to my github.
                                    To upgrade follow the instructions below.
                                    Eg:
                                    pip3 install -e .
                                    • S subutux
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      #65
                                      @subutux
                                      Please rebase your pymysensors branch off my latest updates, before you make the PR. Thanks.
                                      • S subutux
                                        martinhjelmareM
                                        martinhjelmareM
                                        martinhjelmare
                                        #66
                                        @subutux
                                        I went ahead and added your fix for the 100% cpu usage. Although I settled for a very short 0.02 seconds. It was enough for my intel based processor. If you still experience problems and think we should increase it, let me know.
                                        Please make a PR for the check of the connection here https://github.com/theolind/pymysensors if you have time.
                                        My plan is to try and have this make the release of home assistant that is planned during this week. I think it should be good enough for a first version now. We can add polish for the next release.
                                        • D
                                          drock1985
                                          Hi @martinhjelmare
                                          I see HA got released early, and that the ethernetgateway was added. I'll check it out later on tonight but, thanks again for all the work you do on the MySensors project.
                                          My Projects
                                          2 Door Chime Sensor
