  3. Can I connect two PIR sensors to a mini pro/328p and use interrupt on both?
4 Posts 3 Posters 1.2k Views 3 Watching
  • Cliff KarlssonC
    Cliff KarlssonC
    Cliff Karlsson
    Can I connect two PIR sensors to a mini pro/328p and use interrupts on both plus radio? I read before that only pin 2,3 could be use for intererupts and the radio uses pin 2.
    AWIA 1 Reply Last reply
      AWIA
      AWIA
      AWI
      @Cliff-Karlsson The radio interrupt is not used at the moment, so you can use both for other purposes
      • Cliff KarlssonC
        Cliff KarlssonC
        Cliff Karlsson
        reply
        But if the radio is connected to pin-2 how would I use that pin? do I need to edit some of the mysensors config files ?
          You just don't connect it. That's all :) The MySensors nrf code does not use the interrupt so there is no code to remove.
