  3. Interruption Vector
Interruption Vector
9 Posts 4 Posters 2.8k Views 3 Watching
  • flylowgofastF
    flylowgofastF
    flylowgofast
    Hello all,
    few days ago I sent a post to know if I can adapt my hardware to MySensors. SomeOne explained me that is possible, because there isn't constraint with pin to use. That's right, I already have two nodes which work with temperature and door switch.
    But now I have an issue with a node which runs two triacs. I need AC power synchronization to drive my triacs and I use ISR (INT0_vect) { }, but when I compile the sketche I have : multiple definition of `__vector_1'
    I think it occurs because MySensors use this interruption too ?
    Could you help me ?
    regards
    • sundberg84S
      @flylowgofast Post your sketch so we can have a look.
      • flylowgofastF
        flylowgofastF
        flylowgofast
        ok, but it's a little bit long, this is the part : ISR(INT0_vect) {
        #include <OneWire.h>
        #include "config.h"           //Définition des constantes pour le projet DomoFab
        #define MAX_ATTACHED_DS18B20 1
        MyTransportNRF24 transport(CE, CSN, RF24_PA_LEVEL_GW);
        MySensor gw(transport);// signerRADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
        int numSensors=0;
        boolean metric = true;
        MyMessage msgTemp(0,V_TEMP);
        MyMessage msgDoor(1,V_STATUS);
        uint32_t triacTempo;
        volatile uint8_t triac1 = false;
        volatile uint8_t triac2 = false;
        uint16_t analogUp;
        uint16_t analogDown;
        uint8_t doorOpenState;
        uint8_t doorOpenChange = 99; //pour passer la première fois
        unsigned long myTime = 15000; // Pour faire une lecture des valeurs tout de suite
        // ???????????????????????????  Who am I ?????????????????????????????????????????????????????????????????????????????????????????????????????????????
         byte role = API2; // première carte avec pro mini capteur de température et capteur de porte
        // the setup routine runs once when you press reset:
          printf("DomoFab rRF24 API n°: %u start\n\n\r", role);
          // initialize the digital pin as an output.
          pinMode(HALL, INPUT);
          pinMode(TRIAC1, OUTPUT); // output pin for OC2B
          pinMode(TRIAC2, OUTPUT); // output pin for OC1B
          pinMode(ZEROCROSS, INPUT); //passage par zéro du réseau INT0
          digitalWrite(UP, HIGH);    //Set pull up resistor
          digitalWrite(DOWN, HIGH);  //Set pull up resistor
          EIMSK = (1 << INT0);       //INT 0 enable
          EICRA = (1 << ISC00);      //autoriser n'importe quel changement sur INT0 (D2) à générer une interruption;
          printf ("\nConfiguration : API2\n\r");
          sensors.begin();
          gw.begin();
          gw.sendSketchInfo("Temperature Sensor", "1.1");
          Serial.print("nombre de capteur : ");
          Serial.println(numSensors);
          gw.present(0, S_TEMP);
          gw.present(1, S_DOOR);
        /*ISR(TIMER2_COMPB_vect)        // interrupt service routine
        ISR(TIMER1_COMPB_vect)        // interrupt service routine
        ISR(INT0_vect) {
          if (triac1) {
            digitalWrite(TRIAC1, HIGH);
            digitalWrite(TRIAC1, LOW);
            delayMicroseconds(100);
          } else {
            if (triac2) {
              digitalWrite(TRIAC2, HIGH);
              digitalWrite(TRIAC2, LOW);
        // the loop routine runs over and over again forever:
          gw.process();
          //---------------Lecture des valeurs------------------
          if ((millis() - myTime) > 10000) { // toutes les dix secondes
            myTime = millis();
            // Attention à la fréquence 16 ou 8 Mhz pro mini Chinois ou pas !!!
            // Sinon ca ne marche pas et je cherche pendant 3 heures !!!
          float temperature = static_cast<float>(static_cast<int>((gw.getConfig().isMetric?sensors.getTempCByIndex(0):sensors.getTempFByIndex(0)) * 10.)) / 10.;
          #if COMPARE_TEMP == 1
          if (lastTemperature[0] != temperature && temperature != -127.00 && temperature != 85.00) {
          #else
            gw.send(msgTemp.setSensor(0).set(temperature,1));
            lastTemperature[0]=temperature;
          doorOpenState = digitalRead(HALL); // lecture à chaque cycle (urgence)
          if (doorOpenState != doorOpenChange){
            gw.send(msgDoor.setSensor(1).set(doorOpenState));
            doorOpenChange = doorOpenState;
        • sundberg84S
          Hi.
          Cant se any definition of the vector_1 in your code - maybe in any of the libraries?
          There are some info in the arduino forum: http://forum.arduino.cc/index.php?topic=47992.0 have a look and see if that helps you out.
          • flylowgofastF
            flylowgofastF
            flylowgofast
            Yes you're right,
            before MySensors my code was ok, but now MySensors use a librairy in ~/arduino-1.6.7/harware/arduino/avr/cores/arduino/WInterrupts.c
            So this use of interrupt is already declare in this library !
            I don't now how to avoid the issue ?
            • flylowgofastF flylowgofast
              Yes you're right,
              martinhjelmareM
              martinhjelmareM
              martinhjelmare
              @flylowgofast
              Hi!
              Use attachInterrupt instead.
              http://gammon.com.au/interrupts
              And don't use delay inside the ISR. Variables should be volatile.
              • flylowgofastF
                flylowgofastF
                flylowgofast
                @martinhjelmare
                Hi, thank you for your reply, the link is very usefull.
                You said variables should be Volatile, this is the case for my variable triac1 & 2, but I use two other "const" :
                static const uint8_t TRIAC1= 3;    //Triac 1 associé au timer 2 OC2B pour la sortie D3
                static const uint8_t TRIAC2= 10;   //Triac 2 associé au timer 1 OC1B pour la sortie D10
                Have I to add volatile in this case too ?
                  "C's volatile keyword is a qualifier that is applied to a variable when it is declared. It tells the compiler that the value of the variable may change at any time--without any action being taken by the code the compiler finds nearby" (source: http://www.barrgroup.com/Embedded-Systems/How-To/C-Volatile-Keyword )
                  So volatile only affects changes to variables. Your const variables will not change, so there is no need to declare them volatile.
                  • flylowgofastF
                    flylowgofastF
                    flylowgofast
                    thanks to all your contributions, it becomes clear for me.
