  3. Count car-starts
Count car-starts
47 Posts 5 Posters 17.9k Views 3 Watching
    Great work @flopp! Just one comment: You call loop if the 5 resend tries isn't enough. That will re-start the loop. What it also will do is to keep all variables in the loop and resend functions in memory. These will add up over time, which will crash your Arduino after a while. So if you start the engine at work and it takes too long time to reach home, the Arduino will have crashed before it is able to update the gateway. See http://arduino.stackexchange.com/questions/355/how-much-can-i-recurse-how-much-can-i-recurse-how-much-caqfsdrfw for technical details on stack usage and recursion.
    You might want to do something like this instead:
    bool resend(MyMessage &msg, int repeats)
      if (sendOK == false && repeat == repeats){
        return false;
      return true;
    and then change all
    resend(..., 5);
    to
    if (!resend(..., 5)) return;
    This will have the same effect, but will not accumulate stuff on the stack.
    F
    F
    flopp
    wrote on last edited by flopp
    #21
    @mfalkvidd
    Thanks for taking time to read my sketch :satisfied:
    if !(resend((lastCounterMsg.set(starts)), 5)) return;
    Arduino IDE says
    Car_counter.ino.ino: In function 'void resend(MyMessage&, int)':
    Car_counter.ino:117: error: return-statement with a value, in function returning 'void' [-fpermissive]
    Car_counter.ino:119: error: return-statement with a value, in function returning 'void' [-fpermissive]
    expected '(' before '!' token
    • F
      F
      flopp
      #22
      @mfalkvidd
      this must help, or?
      void send();
      resend((volumeMsg.set(starts)), 5);
      resend((lastCounterMsg.set(starts)), 5);
      gw.wait(1000);
      Serial.println("");
      Serial.println("store 0 to EEPROM");
      gw.saveState(0,0);                            // set 0 start to EEPROM, all have been sent
      Serial.println("sleep");                      // mission accomplished
      while(1){}
      // check if "st:fail" during gw.send, thanks n3ro
      void resend(MyMessage &msg, int repeats)
        int repeat = 1;
        boolean sendOK = false;
        int repeatdelay = 2000;
        while ((sendOK == false) and (repeat < repeats)) {
          if (gw.send(msg)) {
            sendOK = true;
          else {
            sendOK = false;
            Serial.print("Error ");
            Serial.println(repeat);
          repeat++; delay(repeatdelay);
          void send();;
        Sorry, I forgot to change void resend to bool resend. I have updated my previous post.
        F 2 Replies Last reply
          And no, movin the code from loop to send does not help. The problem is that you will get recursive calls. send calls resend which calls send which calls resend which calls send which calls resend....and so on. For each call, the Arduino will store all variables on the stack and memory usage will grow and grow.
          F 1 Reply Last reply
            F
            F
            flopp
            @mfalkvidd
            OK, so you have to go back to where it comes from
              F
              F
              flopp
              #26
              @mfalkvidd
              Sorry, didnt work. Almost same error
              Car_counter_1.2:84: error: expected '(' before '!' token
              Car_counter_1.2:86: error: expected '(' before '!' token
                F
                F
                flopp
                #27
                @mfalkvidd
                But if I put ! inside ( it works
                if (!resend((volumeMsg.set(starts)), 5))return;
                  Yes, sorry about that. I edited my previous post to have ! inside ().
                  • F
                    F
                    flopp
                    #29
                    This post is deleted!
                    Z 1 Reply Last reply
                    • F flopp
                      [[topic:post-is-deleted]]
                      Z
                      Z
                      Zeph
                      wrote on last edited by Zeph
                      #30
                      OK, let me see if I understand your overall flow.
                      You have your node connected to switched 12V power in the car. When you turn on the car, the uC gets power, when you turn off the car it loses power. When the car is cranking, the voltage drops enough that it tends to reset again (or else the cranking position on your key switch actually cuts off auxiliary power used by the uC).
                      So if you are at home and in range, loop() is called by the Arduino runtime just once; at the end of loop() the uC goes into an infinite busy loop rather than return, staying there until power is lost again. If you are away from home or the packets are lost for other reasons, resend() will cause a return from loop(), so that loop() will be called again by the Arduino runtime, so it will just keep trying until either power is lost, or it makes contact with your wireless network again.
                      Meanwhile every time it starts, the first byte of eeprom is incremented in setup(), and then loop() tries to fetch VAR1, and send VAR1+eeprom(0) back. If it succeeds, then the first byte of eeprom is zeroed.
                      Right?
                      That sounds reasonable. My immediate concern would be inconsistent operation during cranking, if the input voltage went just low enough to make the uC unstable. If your car's wiring cuts the power entirely, not a problem. Likewise there appears to be time for the uC to boot, and fully update eeprom, before losing power during cranking. (It's best not to be writing eeprom as voltage drops). It appears that those are not problems for your system tho.
                      F mfalkviddM 2 Replies Last reply
                      • F flopp
                        @tbowmo
                        Yes, but I dont want to jeopardize my cars :)
                        12v can be handle by the Arduino Pro min on RAW pin
                        Z
                        Z
                        Zeph
                        #31
                        Cars go well above 14V during operation (as well as having noise glitches on top of that). If the regulator is only good up to 12v, operation could be marginal. Hence the suggestion from @tbowmo of a couple of diodes in the power feed, to drop a bit of the voltage as seen by the regulator.
                        • Z Zeph
                          Right?
                          F
                          F
                          flopp
                          #32
                          @Zeph
                          Fully correct :) thanks for summarizing.
                          Car A have a built in USB where I, today, take power. I have to test if the voltage will go low so the uC will not get correct power but not 0 volt(restart), I don't know what will happen then. This was your question?
                          Car B have cigarette plug(12v output) so I use a converter to 5V, I think these converters can handle low input and still have 5V on output.
                          I will test it for a while and count starts in my head(good luck)
                          Next idea is to have a buzzer to beep when it has successfully sent data to Controller, just as information and if it beeps when I am away from home I have a mistake in the sketch
                          • Z Zeph
                            F
                            F
                            flopp
                            @Zeph
                            you are right about 14V.
                            Best should be to hide uC and connect to power(which only have power after crank)
                            • Z Zeph
                              Right?
                              #34
                              This is correct. However, shouldn't the BOD take care of that problem? Might be a good idea to set the BOD to 4.3V i stead of the default 2.7 though?
                                F
                                F
                                flopp
                                #35
                                @mfalkvidd said:
                                What does that mean exactly? Write to eeprom when power disappear, how is that possible without power?
                                This is correct. However, shouldn't the BOD take care of that problem? Might be a good idea to set the BOD to 4.3V instead of the default 2.7 though?
                                Perfect, then it will die sooner I guess
                                • F flopp
                                  #36
                                  Writing is not instantaneous. It might only take a millisecond, but during that time things can happen. So when the write starts, there is enough power. But half-way through the write power is lost. That leaves the eeprom in an unknown state.
                                    F
                                    F
                                    flopp
                                    #37
                                    @mfalkvidd
                                    Ok, I read it "to write as counting voltage drop" but it was "write to eeprom during voltage drop".
                                    It is now clear, thanks
                                    • tbowmoT
                                      tbowmoT
                                      tbowmo
                                      @flopp
                                      A more exotic "hack" could be to tap into the OBD2 interface, and for example check engine RPM to see if motor is running, or not.
                                      See this link..
                                      http://mechanics.stackexchange.com/questions/24171/how-to-detect-engine-ignition-on-off-status-using-obd2
                                      • tbowmoT tbowmo
                                        @flopp
                                        See this link..
                                        F
                                        F
                                        flopp
                                        @tbowmo
                                        Something like this?
                                        This looks really nice, something I want to try later on
                                        http://youtu.be/kmZ2PUMOKB8
                                        • F
                                          F
                                          flopp
                                          My sketch seems to work, only problem is presentation in domoticz
                                          I will add a buzzer to now when it has reported to gateway
