  3. Sensebender battery life
5 Posts 4 Posters 4.3k Views 5 Watching
  • D Offline
    Dwalt
    It has been 9 months since the first shipment of sensebenders started appearing in post boxes around the world. Has anyone managed to kill a battery with this thing? I have three (with added PIR & LDR) which have been running since June off single CR123 batteries and all three are still reporting 90%+ battery level. Just wondering how others have performed...
    Y 1 Reply Last reply
    • D Dwalt
      Y Offline
      Y Offline
      @Dwalt said:
      PIR
      Just wondering, which PIR are you using?
      D 1 Reply Last reply
      • hekH Offline
        hekH Offline
        Ye, mine is still alive, sending temp/hum without hickups since june. Would be nice to get a year on 2xAA. Mine report 66% battery level.
        At the next battery switch I'll probably lower the send frequency even further. Sending every minute is a bit overkill.
        • T Offline
          T Offline
          tbowmo
          Mine has been running since june as well, on 2xAA. They are reporting 73% left.. I'm measuring every minute, but only transmitting if temperature has changed more than 0.5 degrees.. (More or less the standard sketch as in development branch)
          • Y Yveaux
            @Dwalt said:
            PIR
            Dwalt
            @Yveaux
            I used panasonic PIRs, they are hard to find and price ranges widely. I submitted the build last summer.
