  3. PiDome
  4. PiDome Domotica/Home Automation
Scheduled Pinned Locked Moved PiDome
controllerserialgatewayraspberrymqttpidome
199 Posts 17 Posters 146.1k Views 5 Watching
  • FrancoisF Francois
    @John Hi my system was running fine till I what to add more sensor. Pidome do see the sensor but do not present the it in the "New nodes presentation" or the new "Discovered device". I can add the new nodes manually and that works. I am on version 508
    upload-cc402486-ca4b-47b4-a1a3-e5aff44ce45f
    here is info from the applog file:
    upload-d107150c-72ea-4d31-a13c-3e46ceb33697
    JohnJ
    JohnJ
    John
    @Francois Build server is busy with a quick fix for the MQTT gateway. Should be ready in a couple of minutes
    • FrancoisF
      FrancoisF
      Francois
      @John download the ver509 and still doing the same thing.
      upload-1b2b4e0e-98f4-45e6-88f8-d291b384d340
      JohnJ 1 Reply Last reply
        JohnJ
        JohnJ
        John
        @Francois Also not present in the discovery?
        • FrancoisF
          FrancoisF
          Francois
          @John yes it is also not in discovery
          JohnJ 2 Replies Last reply
            JohnJ
            JohnJ
            John
            wrote on last edited by John
            #125
            @Francois Gimme half an hour
            [EDIT] A bit longer, the devices proxy mapping (devices used in plugins) is misbehaving.[/EDIT]
            • T
              tortoisedoc
              @John thanks for the fix, will test it later today. Is the latest build still good to go?
              • JohnJ
                JohnJ
                John
                @tortoisedoc Sending and receiving data is not influenced by the discovery utilities. It is possible new devices are not found (which have an ID assigned). But this should not be the case for nodes which are requesting an id (this is still handled by the driver).
                The path to the hardware is now completely open after receiving of the gateway started message. I will in the meantime ask an other user if he has an issue with the request for the version number from the gateway
                  JohnJ
                  JohnJ
                  John
                  @Francois I have continued the normal development path of this feature. Otherwise i would be "hacking" the code and then remove this to be able to continue normally. I do have a quick build ready, could you check the latest build (510) if it is working for you?
                  • FrancoisF
                    FrancoisF
                    Francois
                    @John This version (510) fix the issue and it did discovered the sensor. Thanks
                      JohnJ
                      JohnJ
                      John
                      @Francois Good!
                      @tortoisedoc Are you able to use the node assignment?
                      T 1 Reply Last reply
                      • FrancoisF
                        FrancoisF
                        Francois
                        @John I must say that you product is getting better with every release. This new discovery process that you now add is making things ever easier to add sensors to the system Thanks for all the hard work that you are putting into this project. I real appreciate this. Keep up the good work. You product just work and I don't have to worries about it.
                          JohnJ
                          JohnJ
                          John
                          @Francois Thanks for your kind words! Too bad you didn't download the release on the builder this evening, you have fallen in a test sequence ;).
                          When the routine is completely implemented i will post a follow up on this feature.
                          • FrancoisF
                            FrancoisF
                            Francois
                            @John I never skip an release the moment there is new release I installed.
                            • JohnJ John
                              @Francois Good!
                              tortoisedoc
                              wrote on last edited by tortoisedoc
                              #134
                              Unfortunately not.
                              See here: appLog.txt
                              At this point, im starting to suspect about the PI. The miniterm shows correctly the gateway startup tho.
                              • C
                                C
                                ceburge
                                • T tortoisedoc
                                  Unfortunately not.
                                  JohnJ
                                  JohnJ
                                  John
                                  @tortoisedoc The only thing i see is a gateway ready message, i do not see any node presenting or asking for a node address. I suspect that this information is also not available in miniterm. If it is, you have to try again without miniterm cause this then is interfering.
                                  • C ceburge
                                    JohnJ
                                    JohnJ
                                    John
                                    #137
                                    @ceburge Is this a fresh install or an update? If this is an update please clear the browser cache and re-open the browser
                                    C 1 Reply Last reply
                                    • JohnJ John
                                      C
                                      C
                                      ceburge
                                      It was indeed an update. The clearing of the browser cache did the trick. Thanks alot.
                                      By the way. Love your work you are doing with PiDome. It is user friendly and something that most people can funtion in. Keep up
                                      the good work.
                                      • C ceburge
                                        the good work.
                                        JohnJ
                                        JohnJ
                                        John
                                        #139
                                        @ceburge Thanks! And that's exactly the thought behind the project (not in the beginning because it was a personal thingy, but has grown in to), try to create something most people would be able to use. It still needs a lot of work, but it's getting there. We have planned very exciting stuff!
                                        PiDome relies heavily on the browser cache, one of the reasons why it responds relatively quick in most situations. So if there is any error with title "Interface error", clear the cache ;).
                                        Cheers!
                                        P.S. the reason for this error is due to the fact the messaging has been optimized, where possible device values which can be updated are now in one single message instead of four (if a device has four controls and/or data fields).
                                        • JohnJ John
                                          tortoisedoc
                                          #140
                                          @John Ok, here more logging:
                                          appLog.txt
                                          There is actually data coming in - but the visual part is empty both in the driver's section as well as the "new" section for non-discovered devices.
                                          PS I tested this in Chrome as well as in Firefox;
                                          and the result is empty : capture.png
