  3. PiDome
  4. PiDome Domotica/Home Automation
Scheduled Pinned Locked Moved PiDome
controllerserialgatewayraspberrymqttpidome
199 Posts 17 Posters 144.4k Views 5 Watching
  • JohnJ John
    @tortoisedoc Yes bluetooth can certainly interfere also (it think around 70 channels) 2.4 ghz - 2.47 +/- band. Especially the older ones. As long as the driver is in waiting for gateway mode not all the data is being send out.
    Also, do you have multiple nodes asking for an address at the same time? (because of the two seconds between requests) Please add one node at a time. 255 is a temporary address, if multiple nodes are requesting a node id multiple nodes will receive the same new address.
    What the driver does is when there is a gateway ready message, it sends out a request for the version number. When this is received from the gateway the driver knows which version (future usage if/when a new protocol is implemented) of mysensors it must load.
    Is it ok with you to test for me that receiving only the gateway message would be sufficient for the driver to enable all sending?
    If possible. could you do the following for me?
    1. Stop the server
    2. Disconnect the gateway.
    3. Start the server with "./server.sh trace".
    4. When the server is started, connect the gateway.
    5. Give it a couple of seconds and take a look at the driver page. After a maximum of let's say 7 seconds it should show the version number instead of "Waiting".
    6. Let a single node ask for an address, and try to supply one.
    7. After the above actions go to "Settings > Server settings" in the web interface and disable debug mode (this also disables trace mode only available via command line).
    8. Please send the log file with your mysensors username so i know it's you to support.a.t.pidome.org
    Trace mode logging provides me with the most information possible. If all of the above is included i can take a look at all these at the same time.
    P.S. Sorry for the late response, wife's birthday today.
    tortoisedoc
    @John Okay. Seems we have something here now; see the attached log here:
    appLog.txt
    in particular :
    2014-12-15 21:55:59,811 [USB-discovery] INFO org.pidome.server.system.hardware.drivers.Drivers - Something went wrong width the hardware: MEthod does not support NID to request driver.
    JohnJ 1 Reply Last reply
    • T tortoisedoc
      appLog.txt
      in particular :
      JohnJ
      JohnJ
      John
      wrote on last edited by John
      #117
      @tortoisedoc Yeah... that one is an oldie and can be discarded, that one was for example going to be used with for example arduino serial devices. Responding to the NID request with a driver id can load the driver specific for the software written on the arduino. this function is disabled in the api for mysensors.
      Ok, i'm seeing the next:
      2014-12-15 21:58:34,527 [Thread-29] TRACE org.pidome.driver.driver.nativeMySensorsDriver14.NativeMySensorsDriver14 - Received from hardware driver: 0;0;3;0;14;Gateway startup complete.
      2014-12-15 21:58:34,530 [Thread-29] DEBUG org.pidome.driver.driver.nativeMySensorsDriver14.NativeMySensorsDriver14 - Handling internal: 0;0;INTERNAL;14;Gateway startup complete.
      2014-12-15 21:58:34,533 [Thread-29] DEBUG org.pidome.driver.driver.nativeMySensorsDriver14.NativeMySensorsDriver14 - Sending internal message to device: '0;0;3;0;2;Get Version'
      2014-12-15 21:58:34,575 [pool-15-thread-1] DEBUG org.pidome.driver.driver.nativeMySensorsDriver14.NativeMySensorsDriver14 - sending: [B@13038e1
      It is sended to the gateway, but there is no response. This routine has been working since implemented (almost the beginning when gateway ready was available).
      @hek Am i missing something? Has the version info message been changed?
      @tortoisedoc At moment of speaking i'm building a new test version on the build server (http://builder.pidome.org) which enables data when gateway ready arrives, but before it asks for a version. So you now should be able to send.
      P.S. there now is a devices discovery page. devices with id appear here, devices without id (node id 255, so requesting one) still appear in the mysensors driver page. Also discovery is now enabled continuously. this is a quick build to get you going
        Nope.
        • FrancoisF
          FrancoisF
          Francois
          wrote on last edited by Francois
          #119
          @John Hi my system was running fine till I what to add more sensor. Pidome do see the sensor but do not present the it in the "New nodes presentation" or the new "Discovered device". I can add the new nodes manually and that works. I am on version 508
          upload-cc402486-ca4b-47b4-a1a3-e5aff44ce45f
          here is info from the applog file:
          upload-d107150c-72ea-4d31-a13c-3e46ceb33697
          JohnJ 2 Replies Last reply
          • FrancoisF Francois
            JohnJ
            JohnJ
            John
            #120
            @Francois Still busy with the centralized device discovery. The commit i did was to quickly have @tortoisedoc up and running to solve the issue he is having. it will be done today so devices will appear in the device discovery list.
            Sorry for any inconvenience this commit has caused
              JohnJ
              JohnJ
              John
              @Francois Build server is busy with a quick fix for the MQTT gateway. Should be ready in a couple of minutes
              • FrancoisF
                FrancoisF
                Francois
                @John download the ver509 and still doing the same thing.
                upload-1b2b4e0e-98f4-45e6-88f8-d291b384d340
                  JohnJ
                  JohnJ
                  John
                  @Francois Also not present in the discovery?
                  • FrancoisF
                    FrancoisF
                    Francois
                    @John yes it is also not in discovery
                      JohnJ
                      JohnJ
                      John
                      #125
                      @Francois Gimme half an hour
                      [EDIT] A bit longer, the devices proxy mapping (devices used in plugins) is misbehaving.[/EDIT]
                      • T
                        tortoisedoc
                        @John thanks for the fix, will test it later today. Is the latest build still good to go?
                        • JohnJ
                          JohnJ
                          John
                          @tortoisedoc Sending and receiving data is not influenced by the discovery utilities. It is possible new devices are not found (which have an ID assigned). But this should not be the case for nodes which are requesting an id (this is still handled by the driver).
                          The path to the hardware is now completely open after receiving of the gateway started message. I will in the meantime ask an other user if he has an issue with the request for the version number from the gateway
                            JohnJ
                            JohnJ
                            John
                            @Francois I have continued the normal development path of this feature. Otherwise i would be "hacking" the code and then remove this to be able to continue normally. I do have a quick build ready, could you check the latest build (510) if it is working for you?
                            • FrancoisF
                              FrancoisF
                              Francois
                              @John This version (510) fix the issue and it did discovered the sensor. Thanks
                                JohnJ
                                JohnJ
                                John
                                @Francois Good!
                                @tortoisedoc Are you able to use the node assignment?
                                • FrancoisF
                                  FrancoisF
                                  Francois
                                  @John I must say that you product is getting better with every release. This new discovery process that you now add is making things ever easier to add sensors to the system Thanks for all the hard work that you are putting into this project. I real appreciate this. Keep up the good work. You product just work and I don't have to worries about it.
                                    JohnJ
                                    JohnJ
                                    John
                                    @Francois Thanks for your kind words! Too bad you didn't download the release on the builder this evening, you have fallen in a test sequence ;).
                                    When the routine is completely implemented i will post a follow up on this feature.
                                    • FrancoisF
                                      FrancoisF
                                      Francois
                                      @John I never skip an release the moment there is new release I installed.
                                      • JohnJ John
                                        @Francois Good!
                                        tortoisedoc
                                        wrote on last edited by tortoisedoc
                                        #134
                                        Unfortunately not.
                                        See here: appLog.txt
                                        At this point, im starting to suspect about the PI. The miniterm shows correctly the gateway startup tho.
                                        • C
                                          C
                                          ceburge
