  3. Vera
  4. Ethernet Gateway without NRF24L01+
22 Posts 5 Posters 8.7k Views 5 Watching
    Inclusion mode is supposed to stop after 1 minute. So it sounds like communication between controller and gateway is fine.
    Did you reset the sensor node during inclusion mode was activated?
    Have you looked in the gateway debug log (while gateway is connected to your computer)?
    mlg
    wrote on last edited by mlg
    #21
    @hek
    I found one solution,I turn on sensor in ethernet gateway and press start inclusion and reload engine in Vera .In this way automatically add the sensor
    However compiled another code by adding a relay but is not added is something wrong?
    it is necessary void before, presentation ? and assign a child ID to RELAY ?
     * Version 1.0 - Henrik EKblad
     * Contribution by Tomas Hozza <thozza@gmail.com>
     * LED purposes:
    #define MY_GATEWAY_W5100
    #define MY_IP_ADDRESS 192,168,1,169   // If this is disabled, DHCP is used to retrieve address
    #define MY_PORT 5003
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // #define MY_INCLUSION_MODE_BUTTON_PIN  4
    #include <Ethernet.h>
    boolean lastTripped = 0;
    #define RELAY_1  2  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    // Initialize motion message
        sendSketchInfo("Motion Relay", "1.0");
        present(CHILD_ID, S_MOTION);
        present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
      // Read digital motion value
        if (lastTripped != tripped ) {
          send(msg.set(tripped?"1":"0")); // Send new state and request ack back
          Serial.println(tripped);
          lastTripped=tripped;
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    • stofakillerS
      stofakillerS
      stofakiller
      I did'nt have much succes with the radiodevice, and i have made the gateway :-)
      But have i missed the code eg for the sensors???
      Regards,
      Jan
