  3. Vera
  4. Ethernet Gateway without NRF24L01+
22 Posts 5 Posters 8.7k Views 5 Watching
    mlg
    Is possible create ethernet gateway to communicate directly with vera edge without driver NRF24L01 ?
    I want to connect the sensors directly on Arduino without wireless network, only the vera edge and connected Arduino via network cable.
    It's possible ? I have not found any example, I can not change the existing Ethernet controller code :(
    Corrently Hardware :
    Vera Edge UI7
    Arduno Uno R3
    W5100 Ethernet Shield for Uno
    Motion Sensor (HC-SR501)
    2 Channel Relay - For Open Close garage door
    • OitzuO
      OitzuO
      Oitzu
      Pinging @marceloaqno i remember he had something in the pipline. ;)
        Yes, use the development branch and move the relevant parts of the motion sensor to the GatewayW5100 sketch. With relevant, I mean the stuff inside setup() and loop().
        The gateway should not not be put into sleep, so you have to remove that line and make sure to send the value only when it changes from the last reading.
        https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/MotionSensor/MotionSensor.ino#L70
        M 1 Reply Last reply
          mlg
          wrote on last edited by mlg
          @hek
          // #define MY_RADIO_NRF24
          #define MY_GATEWAY_W5100
          //#define MY_W5100_SPI_EN 4
          // radio on the same spi bus.
            #define MY_SOFTSPI
          //#define MY_RF24_CE_PIN 5
          //#define MY_RF24_CS_PIN 6
          // Enable to UDP
          //#define MY_USE_UDP
          #define MY_IP_ADDRESS 192,168,1,169   // If this is disabled, DHCP is used to retrieve address
          #define MY_PORT 5003
          //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 254
          // Flash leds on rx/tx/err
          #define MY_LEDS_BLINKING_FEATURE
          // Set blinking period
          // Enable inclusion mode
          #define MY_INCLUSION_MODE_BUTTON_PIN  4
          //#define MY_DEFAULT_ERR_LED_PIN 7  // Error led pin
          //#define MY_DEFAULT_RX_LED_PIN  8  // Receive led pin
          //#define MY_DEFAULT_TX_LED_PIN  9  // the PCB, on board LED
          #if defined(MY_USE_UDP)
            #include <EthernetUdp.h>
          #include <Ethernet.h>
          //unsigned long SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
          // Initialize motion message
          void presentation()  {
            sendSketchInfo("Motion Sensor", "1.0");
            present(CHILD_ID, S_MOTION);
            // Read digital motion value
            Serial.println(tripped);
            send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
            //sleep(INTERRUPT,CHANGE, SLEEP_TIME);
          dont work :(
            Two problems.
            1. The sketch will flood the gateway with messages, You should only send when tripped value is updated.
            2. The error in Vera indicates a problem in communication with the gateway. Did you set it up correctly (ip address in Vera).
              Two problems.
              mlg
              @hek
              Tks , I changed the code
                  if (lastTripped != tripped ) {
                    send(msg.set(tripped?"1":"0")); // Send new state and request ack back
                    lastTripped=tripped;
              but vera continues with the same status :(
              some additional info
              • M mlg
                @hek
                mlg
                @hek
                Ok , the message "cant decect device" has disappeared, however not appear the motion sensor, how can I make inclusion?
                • M mlg
                  @hek
                  mlg
                  Connected but motion sensor not appear, someone help?
                  <a class=@mlg " class="img-markdown img-fluid" />
                    Did you turn on inclusion mode on Vera and restart sensor a few times?
                      mlg
                      @hek
                      Yes but Start the button does not work :(
                      I press but the state does not change, the start it is always green.
                      • M mlg
                        @hek
                        mlg
                        Any idea?
                        Already I realized the factory reset Vera , erase the eeprom arduino and inclusion using the Pin 4, but no effect :(
                        the code that currently have the Arduino
                        //#if !defined(MY_W5100_SPI_EN) && !defined(ARDUINO_ARCH_SAMD)
                          //#define MY_SOFTSPI
                          //#define MY_SOFT_SPI_SCK_PIN 14
                          //#define MY_SOFT_SPI_MISO_PIN 16
                          //#define MY_SOFT_SPI_MOSI_PIN 15
                        //#endif
                        boolean lastTripped = 0;
                          Strange...you are using the UI7 branch of the Vera plugin right?
                          You could try commenting these two lines away:
                          //  #define MY_INCLUSION_BUTTON_FEATURE
                          //  #define MY_INCLUSION_MODE_BUTTON_PIN  4
                          In case a floating pin causing troubles.
                            mlg
                            @hek
                            Yes UI7 branch, I already commented these two lines and check the cables, when I press start button the rx and tx lights flashing
                            • M mlg
                              @hek
                              mlg
                              for restart sensor a few times, simply disconnect the gnd cable or all cables?
                              • einarthE
                                einarthE
                                einarth
                                Isn't digital pin 4 used by the Ethernet shield?
                                Probably not the cause of your problems but just noticed when looking over your code..
                                • einarthE einarth
                                  mlg
                                  @einarth
                                  I already commented this line in the code , my final code
                                  //#endif
                                  @hek
                                  After other factory reset , start button now work !! but the inclusion no ! I press start and after 1 minute change automatically to stop.
                                  • M mlg
                                    @einarth
                                    //#endif
                                    @hek
                                    mlg
                                    Any Ideia?
                                      Inclusion mode is supposed to stop after 1 minute. So it sounds like communication between controller and gateway is fine.
                                      Did you reset the sensor node during inclusion mode was activated?
                                      Have you looked in the gateway debug log (while gateway is connected to your computer)?
                                      M 2 Replies Last reply
                                        mlg
                                        @hek
                                        How I make sensor node reset ? Disconnected all cables ? digital pin 3 + gnd + 5v ?
                                        If I disconect all cables I log that
                                        0;255;3;0;9;Starting gateway (R-NGA-, 2.0.0-beta)
                                        IP: 192.168.1.169
                                        0;255;3;0;9;Init complete, id=0, parent=0, distance=0
                                        0;255;3;0;9;Eth: connect
                                        0;255;3;0;9;Eth: 0;0;3;0;5;1
                                        0;255;3;0;9;Eth:
                                        • M mlg
                                          @hek
                                          IP: 192.168.1.169
                                          0;255;3;0;9;Eth:
                                          mlg
                                          @hek
                                          It's normal? If I disconnect the cables get 1/0/1/0 and not stopped
