  3. Has anyone made a 2 or 4 channel relay , and is that worked correct ?
40 Posts 7 Posters 12.0k Views 5 Watching
  • sundberg84S sundberg84
    Strange... im out of ideas at this point. Hardware failure?
    Im not that good looking at the code, but I maybe someone else is.
    R
    R
    Reza
    :( thank you
    this is strange for me too . pin 3 dont working . but pin4 worked . also if i change cable of pin 3 and 4 other relay working and pin 3 dont work
    I change 2 line :
    #define RELAY_1 4
    #define NUMBER_OF_RELAYS 2
    but so pin 4 dont work and pin 5 working....
    barduinoB 1 Reply Last reply
    • R Reza
      :/ why delete your post ? :(
      barduinoB
      barduinoB
      barduino
      @Reza,
      I'm a noob at electronics and arduinos and have a wild imagination :smiley:
      I had a theory but was unsure, so I decided to test it first rather than cause more confusion.
      I know this is a place of sharing, but more than once I caused more problems when trying to help.
      I don't want to bring some stupid idea into the fold.
      I'll report back.
      • R Reza
        :( thank you
        I change 2 line :
        #define RELAY_1 4
        barduinoB
        barduinoB
        barduino
        wrote on last edited by barduino
        #23
        @Reza,
        I guess reality is stranger than fiction.
        To eliminate any bad connections I started by this:
          pinMode(3, OUTPUT);
          pinMode(4, OUTPUT);
          pinMode(5, OUTPUT);
          pinMode(6, OUTPUT);
          digitalWrite(3,LOW);
          digitalWrite(4,LOW);
          digitalWrite(5,LOW);
          digitalWrite(6,LOW);
            for( int i=3;i<=6;i++){
              digitalWrite(i,HIGH);
              delay(500);
              digitalWrite(i,LOW);
              delay(500);
        Using a 4 relay board, connected pins 3 through 6, I get a nice effect of all pins light up in sequence and then turn off in sequence.
        With the relay sketch from the examples (lib 2.0.0) and debugging the load state values which where set to 0 for each sensor I have for each relay (off, ON, ON, ON).
        Then on the setup I decide to reduce it to this:
            pinMode(pin, OUTPUT);
            digitalWrite(pin,LOW);
            Serial.print("Pin ");
            Serial.print(pin);
            Serial.println(" to LOW");
        Same result or each relay (off, ON, ON, ON).
        Starting repeater (RNNRA-, 2.0.0-beta)
        Radio init successful.
        Pin 3 to LOW
        Pin 4 to LOW
        Pin 5 to LOW
        Pin 6 to LOW
        send: 15-15-0-0 s=255,c=3,t=15,pt=0,l=2,sg=0,st=ok:
        send: 15-15-0-0 s=255,c=0,t=18,pt=0,l=10,sg=0,st=ok:2.0.0-beta
        send: 15-15-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
        read: 0-0-15 s=255,c=3,t=6,pt=0,l=1,sg=0:M
        send: 15-15-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
        send: 15-15-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
        send: 15-15-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
        Presenting sensor:1
        send: 15-15-0-0 s=2,c=0,t=3,pt=0,l=0,sg=0,st=ok:
        Presenting sensor:2
        send: 15-15-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=ok:
        Presenting sensor:3
        send: 15-15-0-0 s=4,c=0,t=3,pt=0,l=0,sg=0,st=ok:
        Presenting sensor:4
        Init complete, id=15, parent=0, distance=1
        So I decided to re-initialize the pins once more in the loop section:
            if (isFirstTime){
              for (int sensor=1, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++,pin++) {
                  currState = loadState(sensor);
                  Serial.print("Current Status sensor:");
                  Serial.print(sensor);
                  Serial.print("\t");
                  Serial.print("State:");
                  Serial.print(currState);
                  Serial.print("\t");
                  Serial.print("Pin:");
                  Serial.println(pin);
                  digitalWrite(pin, currState?RELAY_ON:RELAY_OFF);
                  wait(500);
              isFirstTime = false;
        Now I have all relays off:
        Current Status sensor:1	State:0	Pin:3
        Current Status sensor:2	State:0	Pin:4
        Current Status sensor:3	State:0	Pin:5
        Current Status sensor:4	State:0	Pin:6
        Now sending some messages:
        Relay 1
        read: 0-0-15 s=1,c=1,t=2,pt=0,l=1,sg=0:1
        Incoming change for sensor:1 On pin:3, New status: 1
        read: 0-0-15 s=1,c=1,t=2,pt=0,l=1,sg=0:0
        Incoming change for sensor:1 On pin:3, New status: 0
        Works fine but guess what, Relay 4 also turned ON after Relay 1
        Relay 2:
        read: 0-0-15 s=2,c=1,t=2,pt=0,l=1,sg=0:1
        Incoming change for sensor:2 On pin:4, New status: 1
        read: 0-0-15 s=2,c=1,t=2,pt=0,l=1,sg=0:0
        Incoming change for sensor:2 On pin:4, New status: 0
        Works fine but Relay 4 blinks and stays on
        Relay 3:
        read: 0-0-15 s=3,c=1,t=2,pt=0,l=1,sg=0:1
        Incoming change for sensor:3 On pin:5, New status: 1
        read: 0-0-15 s=3,c=1,t=2,pt=0,l=1,sg=0:0
        Incoming change for sensor:3 On pin:5, New status: 0
        Relay 4:
        read: 0-0-15 s=4,c=1,t=2,pt=0,l=1,sg=0:1
        Incoming change for sensor:4 On pin:6, New status: 1
        read: 0-0-15 s=4,c=1,t=2,pt=0,l=1,sg=0:0
        Incoming change for sensor:4 On pin:6, New status: 0
        These relays are solid state 5v, arduino pro mini 5v and I both used the power from computer USB and a 6000 mAh phone battery with the same results.
        Here is the full code:
         * Version 1.0 - Henrik Ekblad
        // Define Node ID
        #define MY_NODE_ID 15
        #define MY_REPEATER_FEATURE
        #define NUMBER_OF_RELAYS 4 // Total number of attached relays
        #define RELAY_ON HIGH  // GPIO value to write to turn on attached relay
        #define RELAY_OFF LOW // GPIO value to write to turn off attached relay
        bool isFirstTime = true;
        bool currState;
            Serial.print(pin);
            present(sensor, S_LIGHT);
            Serial.print("Presenting sensor:");
            Serial.println(sensor);
            if (isFirstTime){
                  Serial.print("\t");
                  Serial.print("\t");
                  wait(500);
          if (message.type==V_LIGHT) {
             // Change relay state
             // Store state in eeprom
             // Write some debug info
             Serial.print(message.sensor);
             Serial.print(" On pin:");
             Serial.print(message.sensor-1+RELAY_1);
        This could be some issue with the development branch of 2.0.0, its been some time since I refreshed.
        So refreshing the libs I see a new before() section and an empty setup() from the RelayActuator example
        void before() {
        Now it runs fine
        send: 15-15-0-0 s=255,c=0,t=18,pt=0,l=10,sg=0,st=fail:2.0.0-beta
        read: 0-0-15 s=2Starting repeater (RNNRA-, 2.0.0-beta)
        send: 15-15-0-0 s=3,c=0,t=3,pt=0,l=0,sg=0,st=fail:
        Incoming change for sensor:1, New status: 1
        Incoming change for sensor:1, New status: 0
        Incoming change for sensor:2, New status: 1
        Incoming change for sensor:2, New status: 0
        Incoming change for sensor:3, New status: 1
        Incoming change for sensor:3, New status: 0
        Incoming change for sensor:4, New status: 1
        Incoming change for sensor:4, New status: 0
        All relays behaving as expected before and after running a clearEEPROMconfig sketch.
        So perhaps there is an issue with v1.5 but it seems the development branch of 2.0 is fine.
        Or you can try to debug the hell out of it with plenty of Serial.prints.
        Check with a simple sketch if your relays are fine.
        If so check what are you getting from the loadState, make sure its boolean, initialize the pins to LOW in setup and if it doesn't work again in loop just once.
        Try to have the relays always starting as off with no load or save state.
        Cheers
        • R
          R
          Reza
          if any one built a 2 or 4 channel please help me , please send me the codes that you use , and wiring and please told me what you use adaptor ( how much V and A ) ? which arduino use ?
          TheoLT 1 Reply Last reply
          • R Reza
            TheoLT
            TheoLT
            TheoL
            @Reza Since it's already a long thread I didn't want to read everything. But just a stupid question. Did you measure the relay? It would be my starting point. Because if that's not working, the rest will not work either.
            Also I once had a relay connected to a ProMini 5V, which I powered over FDTI. But I forgot to setup my FDTI programmer to 5V. By this the Arduino didn't have enough power to switch on the relay. It took me a while before I discovered that, because the NFR24L01+ antenna was working just fine.
            Before I add an external power source to an Arduino, I always feed the Arduino through the USB of my computer. In my experience it has always supplied enough power for controlling a relay state. You could try it, just to eliminate power supply issues.
            Just a few tips for you my friend. I hope you'll be able to find the cause of your troubles really soon.
            Take care.
            R 1 Reply Last reply
            • TheoLT TheoL
              Take care.
              R
              R
              Reza
              wrote on last edited by Reza
              #26
              Take care.
              hi thank you for help me , connected the in1 to pin3 and in2 to pin4 , but pin 4 work and 3 dont work ! (voltag Priority is pin 3 , is this true ? but pin 3 is off and pin4 is work !! also i change pin3 and 4 so other relay is work and other one connect to pin3 dont work ! i test this with a adaptor 5V and 1A but dont work , do need i use a adaptor with more amper ?
              also i use a "ClearEepromConfig" program for my arduino and program relay again but dont work again...
              ( my arduino is a arduino nano )
              • R Reza
                Take care.
                TheoLT
                TheoLT
                TheoL
                @Reza what happens if you connect pin 3 to in2 and pin 4 to in1? That's the easiest way to check your relay. I'm not an expert. Buy my guess is, that if there's a power problem, you wouldn't be able to control any one of the relays. But maybe someone with more knowledge will be able to confirm or deny that,
                • TheoLT TheoL
                  R
                  R
                  Reza
                  Each relay connect to pin 4 is correct ,and each relay connect to pin 3 is not correct, ok thank you :(
                  • R Reza
                    TheoLT
                    TheoLT
                    TheoL
                    @Reza I'm not sure. But if I understand you correctly, my gut feeling is that your pin 3 on the Arduino is broken (or not correctly setup in the code). Could be a power issue, but I seriously doubt it.
                    Just try the blink sketch example. Hookup an LED to pin 3 and change the BLINK_LED pin to pin 3 instead of 13. That way you can check if pin 3 is working correctly.
                    • TheoLT TheoL
                      R
                      R
                      Reza
                      i change code to :
                      #define RELAY_1 4
                      and in wiring in1=pin4 and in2=pin5
                      so pin 5 is working but pin4 is not work !!!
                      • R Reza
                        i change code to :
                        #define RELAY_1 4
                        TheoLT
                        TheoLT
                        TheoL
                        @Reza In that case, since it's so predictable, it's a bug in your sketch. At least that's what I think. Unfortunately I have busy weekend and week ahead, so I don't think I have the time to investigate your code. I'm really sorry. I have to check if I have a spare relay, and if I can find one I'm willing to check your sketch. But as mentioned before I can't promise that.
                        Hopefully others might be able to help you sooner. Take care.
                        • TheoLT TheoL
                          R
                          R
                          Reza
                          ok :( thank you very much
                          • NuubiN
                            NuubiN
                            Nuubi
                            Maybe using increment operator causes your problem [https://www.arduino.cc/en/Reference/Increment]
                            Replacing pin++ with pin=pin+1 in your code should fix it.
                            • NuubiN Nuubi
                              R
                              R
                              Reza
                              hi thank you , I will test this and I will report results
                              • R Reza
                                TheoLT
                                TheoLT
                                TheoL
                                @Reza
                                So I took your Sketch and refactored it. Just to be sure that nothing strange is in the code. I don't think there was anything strange in it. I just don't like the ID of defining one relay and calculate the others. But that's just me. I'd like to be able to debug, but with the way this sketch is set-up, checking what might be wrong is just harder to do.
                                Haven't tested it on an Arduino, don't have any empty breadboard at the moment.
                                #define NUMBER_OF_RELAYS 2     // Total number of attached relays
                                #define SKETCH_NAME      "Relay"
                                #define SKETCH_VERSION   "1.0"
                                MySensor gw; // don't bother with singing yet. First get the sketch and hardware to work...!!!!
                                  gw.begin( incomingMessage, AUTO, true ); // Initialize library and add callback for incoming messages
                                  gw.sendSketchInfo( SKETCH_NAME, SKETCH_VERSION); // Send the sketch version information to the gateway and Controller
                                  for ( int sensor = 0; sensor < NUMBER_OF_RELAYS; sensor++ ) {
                                    gw.present( sensor + 1, S_LIGHT );           // Present the actuator to the GW
                                    pinMode( RELAY_1 + sensor, OUTPUT );         // Assign Relay_pin as output
                                    digitalWrite( RELAY_1 + sensor, RELAY_OFF ); // turn of the relay (some relay need inverted value. You'll have to check yours.). Turning it of is for safety!!!
                                    gw.wait( 50 );                               // my gateway sometimes just can't handle to much child presents after each other
                                    gw.request( sensor + 1, V_LIGHT );           // Request current state from Home Automation controller. I just don't see any reason to store it in the EPROM
                                  gw.process();
                                  if ( message.type==V_LIGHT ) { // We only expect one type of message from controller. But we better check anyway.
                                     int relayPin = RELAY_1 + message.sensor - 1;
                                     if ( message.sensor >= 1 && message.sensor <= NUMBER_OF_RELAYS ) { // make sure message is for a known pin. You wouldn't want to write to a pin that's being used for the radio.
                                       digitalWrite( relayPin, message.getBool() ? RELAY_ON : RELAY_OFF ); // Change relay state
                                       Serial.print( ", relay_pin: " );
                                       Serial.print( relayPin );
                                Sketch should work. Please post the serial output of this sketch.
                                My first steps would be:
                                1. Use the sketch I provided (should work, or I missed something).
                                2. Disconnect RELAY from Arduino.
                                3. Connect LEDs to the arduino with resistor (330 Ohm should be just fine)
                                Test this. The reason I would remove the relay is to be sure there's no power issue. The arduino should be able to provide enough power for driving a simple LED.
                                If this works you know that it's a hardware problem and from there on, you can investigate what the problem is.
                                R 2 Replies Last reply
                                • TheoLT TheoL
                                  @Reza
                                    gw.process();
                                  R
                                  R
                                  Reza
                                  @TheoL said:
                                  @Reza
                                    gw.process();
                                  very very thank you , i will test this and i will comeback <3
                                  • TheoLT TheoL
                                    @Reza
                                      gw.process();
                                    R
                                    R
                                    Reza
                                    #37
                                    @TheoL said:
                                    @Reza
                                      gw.process();
                                    @TheoL this is trueeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee <3 <3 <3
                                    so where was problem ? so this sketch will work for 4 or 8 channel ?
                                    this problem was just for me ? or all ?
                                    • R Reza
                                      @TheoL said:
                                      @Reza
                                        gw.process();
                                      TheoLT
                                      TheoLT
                                      TheoL
                                      @Reza The Sketch is working? If so great. I wasn't sure, because I wasn't able to test it. I can't tell what was wrong. I just rewrote it. In theory it's possible to add 6 relays this way. This is because pin 9 is in use by the NFR24L01+ antenna. You could use pin 2 as a starting pin (you don't need to connect the radio to pin 2, because it's not using it). So you might be able to add up 7 relays with this sketch.
                                      Because you also have pin 0 + 1 and the 6 analog pins, you can add up to 15 relays, but you'll need a different Sketch for this. Just let me now if you can get it to work with the max of 7 relays.
                                      • TheoLT TheoL
                                        R
                                        R
                                        Reza
                                        yes this is working true.
                                        ok.
                                        very very very very thank you <3 <3 <3
                                        • R Reza
                                          ok.
                                          TheoLT
                                          TheoLT
                                          TheoL
                                          @Reza Glad that I could help. I was just thinking. I've added a wait in between the presentation of the relays childs to the gateway. Maybe that made the difference. Anyway good luck and enjoy the greatness of MySensors and it's wonderful community.
