  3. Sending Message from SerialGateway Node to RelayActuator
9 Posts 2 Posters 5.9k Views 2 Watching
  • سیدعظیم عباسس
    سیدعظیم عباسس
    سیدعظیم عباس
    This is the sample code of SerialGateway I am using
     * The ArduinoGateway prints data received from sensors on the serial link.
     * The gateway accepts input on seral which will be sent out on radio network.
     * The GW code is designed for Arduino Nano 328p / 16MHz
     * Wire connections (OPTIONAL):
     * - Inclusion button should be connected between digital pin 3 and GND
     * - RX/TX/ERR leds need to be connected between +5V (anode) and digital pin 6/5/4 with resistor 270-330R in a series
     * LEDs (OPTIONAL):
    #define NO_PORTB_PINCHANGES
    #include <MySigningNone.h>
    #include <MyTransportRFM69.h>
    #include <MyTransportNRF24.h>
    #include <MyHwATMega328.h>
    #include <MySigningAtsha204Soft.h>
    #include <MySigningAtsha204.h>
    #include <MyParserSerial.h>
    #include <stdarg.h>
    #include <PinChangeInt.h>
    #include "GatewayUtil.h"
    #define INCLUSION_MODE_TIME 1 // Number of minutes inclusion mode is enabled
    #define INCLUSION_MODE_PIN  3 // Digital pin used for inclusion mode button
    #define RADIO_ERROR_LED_PIN 4  // Error led pin
    #define RADIO_RX_LED_PIN    6  // Receive led pin
    #define RADIO_TX_LED_PIN    5  // the PCB, on board LED
    MyTransportNRF24 transport(RF24_CE_PIN, RF24_CS_PIN, RF24_PA_LEVEL_GW);
    //MyTransportRFM69 transport;
    // Message signing driver (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
    //MySigningNone signer;
    //MySigningAtsha204Soft signer;
    //MySigningAtsha204 signer;
    // Hardware profile
    MyHwATMega328 hw;
    // Construct MySensors library (signer needed if MY_SIGNING_FEATURE is turned on in MyConfig.h)
    // To use LEDs blinking, uncomment WITH_LEDS_BLINKING in MyConfig.h
    #ifdef WITH_LEDS_BLINKING
    MySensor gw(transport, hw /*, signer*/, RADIO_RX_LED_PIN, RADIO_TX_LED_PIN, RADIO_ERROR_LED_PIN);
    #else
    MySensor gw(transport, hw /*, signer*/);
    char inputString[MAX_RECEIVE_LENGTH] = "";    // A string to hold incoming commands from serial/ethernet interface
    int inputPos = 0;
    boolean commandComplete = false;  // whether the string is complete
    void parseAndSend(char *commandBuffer);
    void output(const char *fmt, ... ) {
       va_list args;
       va_start (args, fmt );
       vsnprintf_P(serialBuffer, MAX_SEND_LENGTH, fmt, args);
       va_end (args);
       Serial.print(serialBuffer);
      gw.begin(incomingMessage, 0, true, 0);
      setupGateway(INCLUSION_MODE_PIN, INCLUSION_MODE_TIME, output);
      // Add interrupt for inclusion button to pin
      PCintPort::attachInterrupt(pinInclusion, startInclusionInterrupt, RISING);
      // Send startup log message on serial
      serial(PSTR("0;0;%d;0;%d;Gateway startup complete.\n"),  C_INTERNAL, I_GATEWAY_READY);
      gw.process();
      checkButtonTriggeredInclusion();
      checkInclusionFinished();
      if (commandComplete) {
        // A command wass issued from serial interface
        // We will now try to send it to the actuator
        parseAndSend(gw, inputString);
        inputPos = 0;
      SerialEvent occurs whenever a new data comes in the
     hardware serial RX.  This routine is run between each
     time loop() runs, so using delay inside loop can delay
     response.  Multiple bytes of data may be available.
    void serialEvent() {
      while (Serial.available()) {
        // get the new byte:
        char inChar = (char)Serial.read();
        // if the incoming character is a newline, set a flag
        // so the main loop can do something about it:
        if (inputPos<MAX_RECEIVE_LENGTH-1 && !commandComplete) {
          if (inChar == '\n') {
            inputString[inputPos] = 0;
            commandComplete = true;
          } else {
            // add it to the inputString:
            inputString[inputPos] = inChar;
            inputPos++;
        } else {
           // Incoming message too long. Throw away
            inputPos = 0;
    and this is the RelayActuator sample code
     * Version 1.0 - Henrik Ekblad
    //MyTransportRFM69 radio;
    MyHwATMega328 hw;
    MySensor gw(radio, hw);
      gw.sendSketchInfo("Relay", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      gw.process();
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
         // Write some debug info
         Serial.print(message.sensor);
    This is output of SerialMonitor
    fisend: 105-105-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
    send: 105-105-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.4
    send: 105-105-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    repeater started, id=105, parent=0, distance=1
    send: 105-105-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
    send: 105-105-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
    send: 105-105-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    Now I want to send Message from gateway to switch the relay pin 3 of RelayActuator , please guide me I am new to mysensor. How can i send a message from gateway to RelayActuator node.
      Use the development branch (at least on gateway).
      // Prepare message
      MyMessage msg(1, V_STATUS);
      msg.setDestination(105);
      //.... and where you want to send add...
      send(msg.set(1));  // Turn on
      send(msg.set(0));  // Turn off
      • سیدعظیم عباسس
        سیدعظیم عباسس
        سیدعظیم عباس
        And if we want to send message through Serial Monitor
          Then you just have to read the instructions here:
          http://www.mysensors.org/download/serial_api_15
          • سیدعظیم عباسس
            سیدعظیم عباسس
            سیدعظیم عباس
            The incomingMessage function in RelayActuator is checking message type as V_LIGHT
            how can we send this message from serial monitor of SerialGateway
              V_LIGHT (alias for V_STATUS) has sub-typ value 2 if you look in the table.
              • سیدعظیم عباسس
                سیدعظیم عباسس
                سیدعظیم عباس
                what does this function does
                  Your node seems to have id 105 (telling from serial log). So in order to send message from the gateway itself you have to set that destination of the message.
                  If you send through the serial interface you also need to specify the correct node id of course.
                  • سیدعظیم عباسس
                    سیدعظیم عباسس
                    سیدعظیم عباس
                    Thanks that really worked for me.
