  3. [SOLVED] Mysensors Lux
10 Posts 3 Posters 2.4k Views 2 Watching
  • the cosmic gateT
    the cosmic gateT
    the cosmic gate
    After we moved to oneother different house , is started the mysensors again.The lux sensors give this error :+1: ```
    send: 1-1-0-0 s=0,c=1,t=23,pt=3,l=2,st=fail:102
    • the cosmic gateT
      the cosmic gateT
      the cosmic gate
      to be honest this is the one and only sensors we connected now so i dont now what the others will tell
      fot now i changes the radio already and check the capacitor , but still fails ?
      • TheoLT
        TheoLT
        TheoL
        Stupid question. But have you checked if the gateway is up and running?
        the cosmic gateT 2 Replies Last reply
        • sundberg84S
          "st=fail" means the receiving node or gateway has problems sending ack back to the sending node.
          As @TheoL said - are your receiving node (repeater or gateway) working? What does that log say?
          Its probably a hardware issue (power and/or range). Try adding a capacitor (http://www.mysensors.org/build/connect_radio#connecting-a-decoupling-capacitor) to the receiving radio, change power source, move receiver/sender closer to each other or build a repeater.
          • TheoLT TheoL
            the cosmic gateT
            the cosmic gateT
            the cosmic gate
            This post is deleted!
            • TheoLT TheoL
              the cosmic gateT
              the cosmic gateT
              the cosmic gate
              Gateway log says: ok
              Hmm maybe check the soldering etc
              TheoLT 1 Reply Last reply
              • the cosmic gateT the cosmic gate
                TheoLT
                TheoLT
                TheoL
                @the-cosmic-gate problems like yours aren't very easy to solve. What hapens if you place the lux sensor within a meter or 2 from the gateway?
                • the cosmic gateT
                  the cosmic gateT
                  the cosmic gate
                  problem solved :) issue : soma bad soldered resistor on the (china) NRF24L01+.
                  After i replaced the radio on the gateway
                  send: 1-1-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                  sensor started, id=1, parent=0, distance=1
                  send: 1-1-0-0 s=255,c=3,t=11,pt=0,l=16,sg=0,st=ok:Light Lux Sensor
                  send: 1-1-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
                  send: 1-1-0-0 s=0,c=0,t=16,pt=0,l=0,sg=0,st=ok:
                  54612
                  send: 1-1-0-0 s=0,c=1,t=23,pt=3,l=2,sg=0,st=ok:54612
                  send: 1-1-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
                  send: 1-1-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.4
                  0```
                    54612
                    0```
                    TheoLT
                    TheoLT
                    TheoL
                    @the-cosmic-gate Great! And you're also good with a soldering iron. I don't think I could replace an SMD resistor ;-)
                    the cosmic gateT 1 Reply Last reply
                    • TheoLT TheoL
                      the cosmic gateT
                      the cosmic gateT
                      the cosmic gate
                      i didn't solder the SMD :) just replaced the whole radio :) much more easy
                      btw: congratz :P
