  2. Bug Reports
  3. Bug in SenseBenderDefault sketch
8 Posts 4 Posters 2.8k Views 3 Watching
  • T Offline
    T Offline
    TheoL
    I was wondering why my SenseBender kept reporting every minute, even though the temperature and humidity didn't change.
    It's a minor one. But in the sendTempHumidityMeasurements(bool force) method, the difference is determined by dividing with 100 and not 100.0 this causes a wrong rounding and always reports a difference higher than the treshhold. Resulting in a temperature report every minute. Even though the temperature hasn't changed much.
    corrected code.
     * Sends temperature and humidity from Si7021 sensor
     * Parameters
     * - force : Forces transmission of a value (even if it's the same as previous measurement)
    void sendTempHumidityMeasurements(bool force)
      bool tx = force;
      si7021_env data = humiditySensor.getHumidityAndTemperature();
      float oldAvgHum = raHum.getAverage();
      raHum.addValue(data.humidityPercent);
      float diffTemp = abs(lastTemperature - (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths)/100.0); // <-- fixed
      float diffHum = abs(oldAvgHum - raHum.getAverage());
      Serial.print(F("TempDiff :"));Serial.println(diffTemp);
      Serial.print(F("HumDiff  :"));Serial.println(diffHum);
      if (isnan(diffHum)) tx = true;
      if (diffTemp > TEMP_TRANSMIT_THRESHOLD) tx = true;
      if (diffHum >= HUMI_TRANSMIT_THRESHOLD) tx = true;
      if (tx) {
        measureCount = 0;
        float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
        int humidity = data.humidityPercent;
        Serial.print("T: ");Serial.println(temperature);
        Serial.print("H: ");Serial.println(humidity);
        gw.send(msgTemp.set(temperature,1));
        gw.send(msgHum.set(humidity));
        lastTemperature = temperature;
        lastHumidity = humidity;
    ps. I'm sorry I don't have a github account.
    • mfalkviddM Offline
      nice catch!
      T 1 Reply Last reply
        nice catch!
        T Offline
        T Offline
        TheoL
        @mfalkvidd Thanx! It took my a while, but got it.
        • T Offline
          T Offline
          TheoL
          Also, do I compile the Sketch for 8Mhz or 1Mhz?
          • H Offline
            H Offline
            wrote on last edited by hek
            From what I can tell, this has already been fixed:
            https://github.com/mysensors/Arduino/blob/development/libraries/MySensors/examples/SensebenderMicro/SensebenderMicro.ino#L248
            Back in October :)
            https://github.com/mysensors/Arduino/blame/development/libraries/MySensors/examples/SensebenderMicro/SensebenderMicro.ino#L248
            • H hek
              Back in October :)
              @hek so the real problem is too long release cycles, and/or not enough backporting?
              • H Offline
                H Offline
                Yes! :anguished:
                • T Offline
                  T Offline
                  tbowmo
                  @TheoL
                  the sensebender is runing on 8Mhz as default. Originally I made so that it could switch to 1Mhz in order to lower the current consumption. But since we are sleeping for 99% of the time, where it's only the watchdog timer that is running, I don't see that much of a power savings running at 1Mhz, compared to 8Mhz.
                  In theory if running on 1Mhz the awaken time is also 8 times longer, than when it's running on 8Mhz.. So that can also contribute to a more "equal" power consumption.
                  So in short.. Compile for 8Mhz :)
                  12.1k
