  3. OpenHAB
  4. MQTT Dimmer
MQTT Dimmer
3 Posts 2 Posters 3.0k Views 2 Watching
    moskovskiy82
    I have set up an led dimmer.
    It somehow works when i send an mqtt command like this
    $ mosquitto_pub -t mygateway1-in/88/0/0/0/3 -m "10"
    This is what i have in my items
    Dimmer  Dimmed_Light    "Dimmer Light [%d %%]"  <slider> { mqtt=">[mymosquitto:mygateway1-in/88/0/0/3:state:*:default]" }
    Then a rule
     * This is a demo rule which simulates a real dimmer by reacting to increase/decrease commands
     * and posting an updated state on the bus
    rule "Dimmed Light"
        when
            Item Dimmed_Light received command
        then
            var Number percent = 100
            if(Dimmed_Light.state instanceof DecimalType) percent = Dimmed_Light.state as DecimalType
            if(receivedCommand==INCREASE) percent = percent + 5
            if(receivedCommand==DECREASE) percent = percent - 5
            if(percent<0)   percent = 0
            if(percent>100) percent = 100
            postUpdate(Dimmed_Light, percent);
    end
    Sitemap Slider item=Dimmed_Light
    Somehow clicking on slider buttons does nothing. I don'e even see the messages when i subscribe to the mymosquitto:mygateway1-in channel. So seems the problem i have misconfiguration in the items string.
    At the same time relay module works defined in items like this
    Switch vent_vsr_high "Vent High" { mqtt=">[mymosquitto:mygateway1-in/55/3/1/0/2:command:ON:1],>[mymosquitto:mygateway1-in/55/3/1/0/2:command:OFF:0]" }```
    CJ CassarinoC 1 Reply Last reply
    • M moskovskiy82
      Then a rule
      rule "Dimmed Light"
          when
          then
      end
      CJ CassarinoC
      CJ CassarinoC
      CJ Cassarino
      @moskovskiy82
      Looking for an answer on this too? Did you happen to figure this out?
        moskovskiy82
        Check out the other topic http://forum.mysensors.org/topic/3664/mqtt-dimmer-message/7
