  3. Relay and light dimmer with light level in one node
7 Posts 3 Posters 3.5k Views 3 Watching
  • J
    J
    jacek
    wrote on last edited by jacek
    I have a problem with programing one node with light dimmer, temp, light level and relay.
    Node with temp,, light level and light dimmer node work perfectli but when I add relay with button then node work fine when I click the button on node to turn on or off light and click another button to turn on or off relay and on domoticz icons is read state from node fine but problem is when I wont turn "on" or "off" light or relay from domoticz, if I wont turn "on" light from domoticz on node is on light and relay and I dont know why :( can you help mi with this, please ?
    I add that light can "on" only when light level is smaller then 350 but relay must working independently light level.
    Code for relay is betwen tags "//WENT" and "//END"
    This is my code from node:
    #include <Encoder.h>
    #include <Bounce2.h>
    #include <OneWire.h>
    #define ONE_WIRE_BUS 19 // Pin where dallase sensor is connected
    #define MAX_ATTACHED_DS18B20 1
    #define LED_PIN 3           // Arduino pin attached to MOSFET Gate pin
    #define KNOB_ENC_PIN_1 4    // Rotary encoder input pin 1
    #define KNOB_ENC_PIN_2 5    // Rotary encoder input pin 2
    #define KNOB_BUTTON_PIN 6   // Rotary encoder button pin
    #define photoPin A6         // Fotorezystor
    #define FADE_DELAY 10       // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    #define SEND_THROTTLE_DELAY 400 // Number of milliseconds before sending after user stops turning knob
    #define SN "DimmableLED /w button"
    #define SV "1.2"
    #define CHILD_ID_LIGHT 16
    #define ID 15
    #define EEPROM_DIM_LEVEL_LAST 1
    #define EEPROM_DIM_LEVEL_SAVE 2
    #define LIGHT_OFF 0
    #define LIGHT_ON 1
    //WENT
    #define WENT_RELAY_PIN  17  // Arduino Digital I/O pin number for relay
    #define WENT_BUTTON_PIN  18  // Arduino Digital I/O pin number for button
    #define CHILD_ID_WENT 17   // Id of the sensor child
    #define RELAY_ON 1
    #define RELAY_OFF 0
    //END
    int dimValue;
    int fadeTo;
    int fadeDelta;
    int persons;
    byte oldButtonVal;
    bool changedByKnob=false;
    bool sendDimValue=false;
    unsigned long lastFadeStep;
    unsigned long sendDimTimeout;
    char convBuffer[10];
    int numSensors=0;
    boolean metric = true;
    unsigned long on = 0;
    unsigned long onT = 0;
    MyMessage msg(0,V_TEMP);
    MyMessage dimmerMsg(CHILD_ID_LIGHT, V_DIMMER);
    MyMessage msgl(0, V_LIGHT_LEVEL);
    //WENT
    MyMessage msgW(CHILD_ID_WENT,V_ARMED);
    Bounce debouncer2 = Bounce();
    int oldValue=0;
    bool state;
    //END
    Encoder knob(KNOB_ENC_PIN_1, KNOB_ENC_PIN_2);
    Bounce debouncer = Bounce();
    int lastLightLevel;
       // The third argument enables repeater mode.
    //  gw.begin(NULL, AUTO, true);
      //Send the sensor node sketch version information to the gateway
     // gw.sendSketchInfo("Repeater Node", "1.0");
      // Set knob button pin as input (with debounce)
      pinMode(KNOB_BUTTON_PIN, INPUT);
      pinMode(photoPin, INPUT);
      digitalWrite(KNOB_BUTTON_PIN, HIGH);
      debouncer.attach(KNOB_BUTTON_PIN);
      debouncer.interval(5);
      oldButtonVal = debouncer.read();
      // Set analog led pin to off
      analogWrite( LED_PIN, 0);
      // Init mysensors library
      gw.begin(incomingMessage, ID, true);
      gw.present(CHILD_ID_LIGHT, S_DIMMER);
      gw.sendSketchInfo(SN, SV);
      // Retreive our last dim levels from the eprom
      fadeTo = dimValue = 0;
      byte oldLevel = 0;
      Serial.print("Sending in last known light level to controller: ");
      Serial.println(oldLevel);
      gw.send(dimmerMsg.set(oldLevel), true);
      Serial.println("Ready to receive messages...");
      sensors.begin();
         gw.present(i, S_TEMP);
      gw.present(15, S_LIGHT_LEVEL);
      //WENT
      gw.sendSketchInfo("Relay & Button", "1.0");
     // Setup the button
      pinMode(WENT_BUTTON_PIN,INPUT);
      // Activate internal pull-up
      digitalWrite(WENT_BUTTON_PIN,HIGH);
      debouncer2.attach(WENT_BUTTON_PIN);
      debouncer2.interval(4);
      gw.present(CHILD_ID_WENT, V_ARMED);
      digitalWrite(WENT_RELAY_PIN, RELAY_OFF);
      pinMode(WENT_RELAY_PIN, OUTPUT);
      state = gw.loadState(CHILD_ID_WENT);
      digitalWrite(WENT_RELAY_PIN, state?RELAY_ON:RELAY_OFF);
      //END
      // Process incoming messages (like config and light state from controller)
      gw.process();
    //WENT
    debouncer2.update();
      // Get the update value
      int value = debouncer2.read();
      if (value != oldValue && value==0) {
          gw.send(msgW.set(state?false:true), true); // Send new state and request ack back
      oldValue = value;
    //END
      // Sprawdzenie temperatury
      CheckTemp();
      onT = onT + 1;
      on = on + 1;
      if (on > 401 + 2*ID) {
      // Poziom swiata
      lightLevel();
      on = 0;
      if (analogRead(photoPin) > 350) { persons = 0;} else {persons = 1;}
      // Check if someone has pressed the knob button
      checkButtonClick();
      // Fade light to new dim value
      fadeStep();
    void lightLevel()
    int lightLevel = (analogRead(photoPin));
      Serial.println(lightLevel);
          gw.send(msgl.set(lightLevel));
          lastLightLevel = lightLevel;
    void CheckTemp()
        #if COMPARE_TEMP == 1
        #else
              if (onT > 400 + 2*ID) {
             onT = 0; }
        //WENT
      if (message.isAck()) {
      if (message.type == V_ARMED) {
         // Change relay state
         state = message.getBool();
         // Store state in eeprom
         gw.saveState(CHILD_ID_WENT, state);
         // Write some debug info
         Serial.print(message.sensor);
      //END
      if (message.type == V_LIGHT && persons == 1) {
        // Incoming on/off command sent from controller ("1" or "0")
        int lightState = message.getString()[0] == '1';
        int newLevel = 0;
        if (lightState==LIGHT_ON) {
          // Pick up last saved dimmer level from the eeprom
          newLevel = loadLevelState(EEPROM_DIM_LEVEL_SAVE);
        // Send dimmer level back to controller with ack enabled
        gw.send(dimmerMsg.set(newLevel), true);
        // We do not change any levels here until ack comes back from gateway
        return;
      } else if (message.type == V_DIMMER && persons == 1) {
        // Incoming dim-level command sent from controller (or ack message)
        fadeTo = atoi(message.getString(convBuffer));
        // Save received dim value to eeprom (unless turned off). Will be
        // retreived when a on command comes in
        if (fadeTo != 0)
          saveLevelState(EEPROM_DIM_LEVEL_SAVE, fadeTo);
     if (persons == 1){
           saveLevelState(EEPROM_DIM_LEVEL_LAST, fadeTo);
           Serial.print("New light level received: ");
           Serial.println(fadeTo);
         if (!changedByKnob)
           knob.write(fadeTo);
           // Cancel send if user turns knob while message comes in
           changedByKnob = false;
           sendDimValue = false;
           // Stard fading to new light level
           startFade();
    } else if (persons == 0){
      if (message.getString() != 0)
              {gw.send(dimmerMsg.set(0), true);}
       else
              {return;}
    void checkButtonClick()
    if ( persons == 1 ) {
      debouncer.update();
      byte buttonVal = debouncer.read();
      byte newLevel = 0;
      if (buttonVal != oldButtonVal && buttonVal == LOW) {
        if (dimValue==0) {
          // Turn on light. Set the level to last saved dim value
         // int saved = loadLevelState(EEPROM_DIM_LEVEL_SAVE);
         int saved = 100;
          newLevel = saved > 0 ? saved : 100;
        gw.send(dimmerMsg.set(newLevel),true);
      oldButtonVal = buttonVal;
    void startFade() {
      fadeDelta = ( fadeTo - dimValue ) < 0 ? -1 : 1;
      lastFadeStep = millis();
    // This method provides a graceful none-blocking fade up/down effect
    void fadeStep() {
      unsigned long currentTime  = millis();
      if ( dimValue != fadeTo && currentTime > lastFadeStep + FADE_DELAY) {
        dimValue += fadeDelta;
        analogWrite( LED_PIN, (int)(dimValue / 100. * 255) );
        lastFadeStep = currentTime;
        Serial.print("Fading level: ");
        Serial.println(dimValue);
        if (fadeTo == dimValue && changedByKnob) {
          sendDimValue = true;
          sendDimTimeout = currentTime;
      // Wait a few millisecs before sending in new value (if user still turns the knob)
      if (sendDimValue && currentTime > sendDimTimeout + SEND_THROTTLE_DELAY)  {
         // We're done fading.. send in new dim-value to controller.
         // Send in new dim value with ack (will be picked up in incomingMessage)
        gw.send(dimmerMsg.set(dimValue), true); // Send new dimmer value and request ack back
    // Make sure only to store/fetch values in the range 0-100 from eeprom
    int loadLevelState(byte pos) {
      return min(max(gw.loadState(pos),0),100);
    void saveLevelState(byte pos, byte data) {
      gw.saveState(pos,min(max(data,0),100));
    J sundberg84S 2 Replies Last reply
    • J jacek
      #define SV "1.2"
      #define ID 15
      #define LIGHT_OFF 0
      #define LIGHT_ON 1
      //WENT
      #define RELAY_ON 1
      #define RELAY_OFF 0
      //END
      int dimValue;
      int fadeTo;
      int fadeDelta;
      int persons;
      byte oldButtonVal;
      int numSensors=0;
      //WENT
      int oldValue=0;
      bool state;
      //END
      int lastLightLevel;
        byte oldLevel = 0;
        sensors.begin();
        //WENT
       // Setup the button
        //END
        gw.process();
      //WENT
        oldValue = value;
      //END
        CheckTemp();
        onT = onT + 1;
        on = on + 1;
        // Poziom swiata
        lightLevel();
        on = 0;
        checkButtonClick();
        fadeStep();
      void lightLevel()
      void CheckTemp()
          #else
               onT = 0; }
          //WENT
        //END
          int newLevel = 0;
          return;
          if (fadeTo != 0)
       if (persons == 1){
           if (!changedByKnob)
             knob.write(fadeTo);
             startFade();
         else
                {return;}
        debouncer.update();
        byte newLevel = 0;
          if (dimValue==0) {
           int saved = 100;
      void startFade() {
      void fadeStep() {
      J
      J
      jacek
      Nobody can help me?
        Sorry, it's pretty hard to follow this code...
        You should probably look at the debug log and add your own debug prints to narrow down your problem.
        First check that message arrives to node then follow up what happens to your incoming data.
        • J jacek
          #define SV "1.2"
          #define ID 15
          #define LIGHT_OFF 0
          #define LIGHT_ON 1
          //WENT
          #define RELAY_ON 1
          #define RELAY_OFF 0
          //END
          int dimValue;
          int fadeTo;
          int fadeDelta;
          int persons;
          byte oldButtonVal;
          int numSensors=0;
          //WENT
          int oldValue=0;
          bool state;
          //END
          int lastLightLevel;
            byte oldLevel = 0;
            sensors.begin();
            //WENT
           // Setup the button
            //END
            gw.process();
          //WENT
            oldValue = value;
          //END
            CheckTemp();
            onT = onT + 1;
            on = on + 1;
            // Poziom swiata
            lightLevel();
            on = 0;
            checkButtonClick();
            fadeStep();
          void lightLevel()
          void CheckTemp()
              #else
                   onT = 0; }
              //WENT
            //END
              int newLevel = 0;
              return;
              if (fadeTo != 0)
           if (persons == 1){
               if (!changedByKnob)
                 knob.write(fadeTo);
                 startFade();
             else
                    {return;}
            debouncer.update();
            byte newLevel = 0;
              if (dimValue==0) {
               int saved = 100;
          void startFade() {
          void fadeStep() {
          @jacek said:
          when I add relay with button then node work fine when I click the button on node to turn on or off light and click another button to turn on > or off relay and on domoticz icons is read state from node fine but problem is when I wont turn "on" or "off" light or relay from domoticz
          This is found in several threads in this forum. Its most probably a ack issue, Domoticz needs a ack back from the node that it has been turned on/off but this does not reach back to the gateway. Follow the logs in gateway and node and you will see.
          You need to treat this problem like a radio issue, either you need more range or it can also be a power issue with the radio making it fail.
          • J
            J
            jacek
            Thank you for answers.
            I do something like this:
            I clear the code from parts whitch use RELAY but in domoticz I do not delete RELAY switch
             /* Default MOSFET pin is 3
             *  Arduino      Encoder module
             *  5V           5V (+)
             *  GND          GND (-)
             *  4            CLK (or putput 1)
             *  5            DT  (or output 1)
             *  6            SW (Switch/Click)
            #define SV "1.2"
            #define ID 15
            #define LIGHT_OFF 0
            #define LIGHT_ON 1
            ////WENT
            //#define WENT_RELAY_PIN  17  // Arduino Digital I/O pin number for relay
            //#define WENT_BUTTON_PIN  18  // Arduino Digital I/O pin number for button
            //#define CHILD_ID_WENT 17   // Id of the sensor child
            //#define RELAY_ON 1
            //#define RELAY_OFF 0
            ////END
            int dimValue;
            int fadeTo;
            int fadeDelta;
            int persons;
            byte oldButtonVal;
            int numSensors=0;
            ////WENT
            //MyMessage msgW(CHILD_ID_WENT,V_ARMED);
            //Bounce debouncer2 = Bounce();
            //int oldValue=0;
            //bool state;
            ////END
            int lastLightLevel;
              byte oldLevel = 0;
              sensors.begin();
            //  //WENT
            //// Send the sketch version information to the gateway and Controller
            //  gw.sendSketchInfo("Relay & Button", "1.0");
            // // Setup the button
            //  pinMode(WENT_BUTTON_PIN,INPUT);
            //  // Activate internal pull-up
            //  digitalWrite(WENT_BUTTON_PIN,HIGH);
            //  // After setting up the button, setup debouncer
            //  debouncer2.attach(WENT_BUTTON_PIN);
            //  debouncer2.interval(4);
            //  // Register all sensors to gw (they will be created as child devices)
            //  gw.present(CHILD_ID_WENT, V_ARMED);
            //  // Make sure relays are off when starting up
            //  digitalWrite(WENT_RELAY_PIN, RELAY_OFF);
            //  // Then set relay pins in output mode
            //  pinMode(WENT_RELAY_PIN, OUTPUT);
            //  // Set relay to last known state (using eeprom storage)
            //  state = gw.loadState(CHILD_ID_WENT);
            //  digitalWrite(WENT_RELAY_PIN, state?RELAY_ON:RELAY_OFF);
            //  //END
              gw.process();
            ////WENT
            //debouncer2.update();
            //  // Get the update value
            //  int value = debouncer2.read();
            //  if (value != oldValue && value==0) {
            //      gw.send(msgW.set(state?false:true), true); // Send new state and request ack back
            //  oldValue = value;
            ////END
              CheckTemp();
              onT = onT + 1;
              on = on + 1;
              // Poziom swiata
              lightLevel();
              on = 0;
              checkButtonClick();
              fadeStep();
            void lightLevel()
            void CheckTemp()
                #else
                     onT = 0; }
            //    //WENT
            // // We only expect one type of message from controller. But we better check anyway.
            //  if (message.isAck()) {
            //     Serial.println("This is an ack from gateway");
            //  if (message.type == V_ARMED) {
            //     // Change relay state
            //     state = message.getBool();
            //     // Store state in eeprom
            //     gw.saveState(CHILD_ID_WENT, state);
            //     // Write some debug info
            //     Serial.print("Incoming change for sensor:");
            //     Serial.print(message.sensor);
            //     Serial.print(", New status: ");
            //     Serial.println(message.getBool());
            //  //END
                int newLevel = 0;
                return;
                if (fadeTo != 0)
             if (persons == 1){
                 if (!changedByKnob)
                   knob.write(fadeTo);
                   startFade();
               else
                      {return;}
              debouncer.update();
              byte newLevel = 0;
                if (dimValue==0) {
                 int saved = 100;
            void startFade() {
            void fadeStep() {
            and Domoticz:
            Domoticz
            When I send from domoticz turn "on" or "off" Relay domoticz send to node and to child_id 17 but node send do domoticz reck to child_id 16
            read: 0-1-15 s=17,c=1,t=2,pt=0,l=1,sg=0:1
            send: 15-15-1-0 s=16,c=1,t=3,pt=2,l=2,sg=0,st=ok:100
            read: 0-1-15 s=16,c=1,t=3,pt=2,l=2,sg=0:100
            and if we send from domoticz do child_id 16 answers is OK
            read: 0-1-15 s=16,c=1,t=2,pt=0,l=1,sg=0:0
            send: 15-15-1-0 s=16,c=1,t=3,pt=2,l=2,sg=0,st=ok:0
            read: 0-1-15 s=16,c=1,t=3,pt=2,l=2,sg=0:0
            • sundberg84S
              Do you need two childs, one for dimmer and one for on/off? I dont think so. Either its a dimmer where 0% is off or its a switch.
              • J
                J
                jacek
                OK thanks everyone for help, this is code witch works very well:
                Only I must add the line where the light will be turn "off" when light level will be > 350 after 5 minutes.
                #define SV "1.2"
                #define ID 15
                #define LIGHT_OFF 0
                #define LIGHT_ON 1
                //WENT
                #define RELAY_ON 1
                #define RELAY_OFF 0
                #define noRelays 1
                const int relayPin[] = {17};          //  switch around pins to your desire
                const int buttonPin[] = {18};      //  switch around pins to your desire
                class Relay             // relay class, store all relevant data (equivalent to struct)
                public:
                  int buttonPin;                   // physical pin number of button
                  int relayPin;             // physical pin number of relay
                  byte oldValue;                    // last Values for key (debounce)
                  boolean relayState;               // relay status (also stored in EEPROM)
                //END
                int dimValue;
                int fadeTo;
                int fadeDelta;
                int persons;
                byte oldButtonVal;
                int numSensors=0;
                //WENT
                Relay Relays[noRelays];
                Bounce debouncer1[noRelays];
                MyMessage msg1[noRelays];
                //END
                int lastLightLevel;
                  byte oldLevel = 0;
                  sensors.begin();
                  //WENT
                 gw.sendSketchInfo("MultiRelayButton", "0.9b");
                    delay(250);
                    // Initialize Relays with corresponding buttons
                    for (int i = 0; i < noRelays; i++){
                    Relays[i].buttonPin = buttonPin[i];              // assign physical pins
                    Relays[i].relayPin = relayPin[i];
                    msg1[i].sensor = i;                                   // initialize messages
                    msg1[i].type = V_LIGHT;
                    debouncer1[i] = Bounce();                        // initialize debouncer
                    debouncer1[i].attach(buttonPin[i]);
                    debouncer1[i].interval(5);
                    pinMode(Relays[i].buttonPin, INPUT_PULLUP);
                    Relays[i].relayState = gw.loadState(i);                               // retrieve last values from EEPROM
                    digitalWrite(Relays[i].relayPin, Relays[i].relayState? RELAY_ON:RELAY_OFF);   // and set relays accordingly
                    gw.send(msg1[i].set(Relays[i].relayState? true : false));                  // make controller aware of last status
                    gw.present(i, S_LIGHT);                               // present sensor to gateway
                    delay(250);
                  //END
                  gw.process();
                //WENT
                for (byte i = 0; i < noRelays; i++){
                    debouncer1[i].update();
                    byte value = debouncer1[i].read();
                    if (value != Relays[i].oldValue && value == 0){
                    digitalWrite(Relays[i].relayPin, Relays[i].relayState?RELAY_ON:RELAY_OFF);
                    gw.saveState( i, Relays[i].relayState );}                 // save sensor state in EEPROM (location == sensor number)
                        Relays[i].oldValue = value;
                //END
                  CheckTemp();
                  onT = onT + 1;
                  on = on + 1;
                  // Poziom swiata
                  lightLevel();
                  on = 0;
                  checkButtonClick();
                  fadeStep();
                void lightLevel()
                void CheckTemp()
                    #else
                         onT = 0; }
                {// if (message.sensor == 17){
                //} else {
                  if (message.type == V_LIGHT && persons == 1 && message.sensor == 16) {
                    int newLevel = 0;
                    return;
                  } else if (message.type == V_DIMMER && persons == 1  && message.sensor == 16) {
                    if (fadeTo != 0)
                 if (persons == 1  && message.sensor == 16){
                     if (!changedByKnob)
                       knob.write(fadeTo);
                       startFade();
                   else
                          {return;}
                 //WENT
                 if (message.type == V_LIGHT){
                        if (message.sensor <noRelays){            // check if message is valid for relays..... previous line  [[[ if (message.sensor <=noRelays){ ]]]
                        digitalWrite(Relays[message.sensor].relayPin, Relays[message.sensor].relayState? RELAY_ON:RELAY_OFF); // and set relays accordingly
                        gw.saveState( message.sensor, Relays[message.sensor].relayState ); // save sensor state in EEPROM (location == sensor number)
                  //END
                  debouncer.update();
                  byte newLevel = 0;
                    if (dimValue==0) {
                     int saved = 100;
                void startFade() {
                void fadeStep() {
