  3. Is there a mysensor thread for this "mysensor" pro mini adapter?
17 Posts 6 Posters 5.6k Views 7 Watching
  • NeverDieN
    NeverDieN
    https://oshpark.com/profiles/corysteinmetz
    YveauxY 1 Reply Last reply
    • NeverDieN NeverDie
      YveauxY
      YveauxY
      @NeverDie Don't think so: https://www.google.nl/search?q=linkto%3Aoshpark.com%2Fprofiles%2Fcorysteinmetz&oq=linkto%3Aoshpark.com%2Fprofiles%2Fcorysteinmetz&aqs=chrome..69i57j69i58.9255j0j7&sourceid=chrome&ie=UTF-8
      NeverDieN 1 Reply Last reply
      • YveauxY Yveaux
        NeverDieN
        NeverDieN
        @Yveaux
        OK. The reason I ask is that at the very bottom of the page on the link I provided it says: "See mySensors.org for more information. " Yet, I tried looking here, and I didn't see anything in reference to it.
        • C
          C
          chickey
          I've just actually got around to soldering mine together today after having the pcb's sitting there for months. I had ordered a load of capacitors and resistors but rather naively didn't realise that there were different sizes for smd components, silly looking back now but just didn't realise. My soldering skills have improved slightly though so had another go and managed to assemble it today. Biggest problem was remembering what smd components were which as the ebay sellers never label them well.
          Have you ordered some already?
          Col
          • C chickey
            Col
            NeverDieN
            NeverDieN
            Yes. As it happens, I soldered one together today too. I'm disappointed that the radio board adds to the overall length rather than folding back over the pro mini (a "U" shape, with the radio board floating above the pro mini, would have made the totality more compact). I do like the built-in voltage divider though for measuring higher voltage external batteries. That's useful to have, and it barely adds anything to the cost.
            The JModule (presently on order) should turn out to be more compact, so I'm looking forward to that.
            In my case, I had purchased a variety pack of SMD resistors and capacitors from Amazon, and everything was nicely labeled. :satisfied: If you end up buying more, I'd recommend it.
            • C
              C
              chickey
              What size SMD did you use for yours? I might see if i can get a variety pack myself from amazon, i'm in the uk so have access to amazon. I think one of the resistors is 470r rather than 470k so the voltage divider didn't work although as i'm feeding it with 3v from two AA i used the internal reference method which worked well. I have to say i thought it ended up being quite long too and then when paired with the sensors you end up with some funny shapes to try and fit in a box :-)
              Col
                @NeverDie the reason the radio sticks out is that otherwise the other components would be blocking the radio signal from reaching the antenna.
                • C chickey
                  Col
                  NeverDieN
                  NeverDieN
                  @chickey
                  0805
                    NeverDieN
                    NeverDieN
                    Not sure what you mean. Ssensebender seems to get by that way, doesn't it?
                    A SparkmanS 2 Replies Last reply
                    • C
                      C
                      chickey
                      In case anyone is interested this is what the assembled board looks like on mine minus any case. You could get it a lot thinner if you skipped the connectors and soldered directly but i've an aversion to that as i keep tinkering.
                        A
                        A
                        Adam McCartney
                        @NeverDie I've got a few sensebenders and the range isn't great on them. i'm beginning to wonder if its because of the way the Radio is mounted of the PCB.
                          SparkmanS
                          SparkmanS
                          Sparkman
                          The sensebender PCB is blank in the area below where the antenna is.
                          https://www.openhardware.io/uploads/568d7feb0779a3581858ac2a/394/micro_radio.png
                          • SparkmanS Sparkman
                            NeverDieN
                            NeverDieN
                            @Sparkman
                            Thanks! Makes sense. That clears up what you all are referring to.
                            Now you have me wondering: is the JModule experiencing a problem in this regard?
                            SparkmanS 1 Reply Last reply
                            • C
                              C
                              chickey
                              If anyone is thinking of using this board Cory produced a PDF which has build instructions for 3.3 and 5v, I've uploaded it so it's easy for people to find.
                              0_1463498990546_MySensor Pro Mini V2 - Google Docs.pdf
                                @Sparkman
                                SparkmanS
                                SparkmanS
                                Sparkman
                                @NeverDie said:
                                @Sparkman
                                It will definitely have reduced range in that direction, but any range issues can likely be minimized by orienting it differently. Would be interesting to compare the actual range reduction of it compared to the Sensebender.
                                  @NeverDie said:
                                  @Sparkman
                                  NeverDieN
                                  NeverDieN
                                  @Sparkman
                                  Here's a photo of the one I put together:
                                  Now you can see why, if it had been bent in a "U", I wasn't extremely concerned about having a blank area underneath. :wink: It would have had a ground plane between the RFM69 and the pro mini. Of course, in that case, I would have soldered the pro mini directly to the adapter board, so that it would be out of the way for the RFM69HW to float above it.
                                  The pro mini's are nice because most of the tricky soldering has already been done for you, and they're nearly the same price as just the atmega328p component just by itself. I'm frankly puzzled as to why more designs don't leverage that obvious fact. True, there is some unsoldering work, which is a bit of a hassle: as you can see, I removed the voltage regulator and the two LEDs so that it doesn't waste any energy when running on two AA's. @chickey You may want to do similar, or else you'll waste energy from backfeeding your pro mini's voltage regulator.
                                  C 1 Reply Last reply
                                    @Sparkman
                                    C
                                    C
                                    chickey
                                    @NeverDie Thanks i'd took the 1 led off but have taken d13 and the regulator off now. Sitting at around 2.7v although as i'm more so testing i'm reporting the temp as often as every 5mins if it changes.
