  3. Step by step (guide) to enable nodes as repeaters
2 Posts 2 Posters 1.1k Views 1 Watching
  • parachutesjP
    parachutesjP
    parachutesj
    wrote on last edited by parachutesj
    Moin,
    as I am struggling with the range of my nodes, I thought it is a must to enable them as repeaters when not running on batteries.
    I am a bit confused as I found different settings in forum compared to the API documentation.
    EDIT (after clarification): this is for code prior 2.0 release:
    In API it says it needs 3 steps:
    • Enable repeater-mode in gw.begin();
      gw.begin(NULL, AUTO, true)
    • Keep node awake all time (no slepping!)
    • calling process() in your loop()
    EDIT: this is for code from release 2.0 onwards:
    What I also found is a definition
    #define MY_REPEATER_FEATURE
    ~~So, what is that all about? ~~
    Thank you and best Regards,
    SJ
    • tbowmoT
      tbowmoT
      tbowmo
      @parachutesj
      #define MY_REPEATERFEATURE is for 2.0.0 branch, as all the c++ and classes stuff has been stripped out, to reduce overall size of the core library
      That means, for 1.5 you need to use gw.begin(..) to enable repeater mode, and for 2.0 you add the #define..
