  3. Automated garage door
33 Posts 9 Posters 18.1k Views 11 Watching
  • D Offline
    This post is deleted!
    • D dbemowsk
      So I finally got a sketch that gives me all of the functions that I need for my garage door. The two main things that I needed were a way to toggle the door opener, and a way to display the current state of the door in Domoticz. Getting to the door to toggle open and closed was easy. The hard part was getting Domoticz to display the state of the door. I was told by @AWI that I needed a V_TEXT variable and a S_TEXT sencode:sor type. He mentioned that these were not available in version 1.5, but they could be added manually in your sketch by adding these lines of code to your sketch:
      // new V_TEXT variable type (development 20150905)
      const int V_TEXT = 47 ;
      // new S_INFO sensor type (development 20150905)
      const int S_INFO = 36 ;
      Here is the final working sketch:
        MyGarageDoor for MySensors
        Arduino garage door control
        June 16,2016
        This will allow the MySensors gateway to monitor and control your garage door opener.  This will
        monitor the internal upper and lower limit switches of the door opener to determine door position
        for status as well as have a relay switched output that can control either the momentary contact
        switch connected to the door opener or wired directly to the switch contacts of a door opener
        remote to activate the door.
        This sketch features the following:
        Allows you to monitor the door position and return it's status based on the following:
          1 - When either the upper or lower door limit switches are reached, the door is said to be
              either fully open or fully closed. When a limit switch is triggered, the lastLimit and
              currentState variables are set to either OPEN or CLOSED based on the limit switch that was
              triggered.
          2 - If the upper and lower limit inputs both read high, then the door is said to be in motion.
              The door's direction of motion is determined from the lastLimit variable.  If the lastLimit
              of the door is OPEN, then the currentState variable should be set to CLOSING.  If the
              lastLimit of the door is CLOSED, then the currentState variable should be set to OPENING.
        Checks for door obstructions and throws an error by checking the currentState and lastLimit
        variables when the upper limit is reached.  If the upper limit is triggered and the currentState
        is set to CLOSING and the lastLimit is set to OPEN, this should indicate that the door reversed
        when closing and returned to the fully opened position.  The error state should only appear if
        BOTH the lastLimit and currentState conditions match.  If lastLimit is OPEN and the lastState is
        OPENING, this would indicate that the door was manually reversed.  This chech should only be
        needed when the upper limit is reached.
        Allows you to toggle the opener to either open or close the door.  When the door is toggled, the
        currentState should be checked and if the state is either OPENING or CLOSING, the currentState
        should invert telling that the door has changed direction.  This is done to prevent an error if
        the door is reversed manually when closing.
        PARTS LIST:
        Arduino pro mini
        nRF24L01 radio module
        AMS1117 3.3v regulator
        0.1uf capacitor
        10uf electrolytic capacitor
        4.7uf electrolytic capacitor (for radio module)
        5v reed relay
        2N3904 transistor for relay
        1k resistor
        Two small signal diodes for incoming signals from door opener
        Wiring from garage door opener
        Yellow = Upper limit D7
        Brown = Lower limit D8
        Gray = Signal ground
        Relay D5
        Version history:
        1.1 : Added the V_TEXT variable and S_INFO sensor type, and created the "Status" child
      #define SKETCH_NAME "MyGarageDoor"
      #define SKETCH_VERSION "1.1"
      #define CHILD_ID_OPENER 0
      #define CHILD_ID_STATUS 1
      #define UPPER_LIMIT_SENSOR 8  //Pin used for input from the garage door upper limit sensor
      #define LOWER_LIMIT_SENSOR 7  //Pin used for input from the garage door lower limit sensor
      #define DOOR_ACTUATOR_RELAY 5 //Pin used to toggle the door actuator relay
      #define RELAY_ON 1            // GPIO value to write to turn on attached relay
      #define RELAY_OFF 0           // GPIO value to write to turn off attached relay
      #define TOGGLE_INTERVAL 1000  //Tells how many milliseconds the relay will be held closed
      #define CLOSED 0
      #define OPEN 1
      #define CLOSING 2
      #define OPENING 3
      const char *currentState[] = { "Closed", "Open", "Closing", "Opening" };
      //Current state of the door
      int cState;
      //Last state of the door
      int lState;
      //The last full limit position of the door (open or closed)
      int lLimit = 0;
      //Used for the error condition when the door is unexpectedly reversed
      boolean obstruction = false;
      MyMessage msgOpener(CHILD_ID_OPENER, V_STATUS);
      MyMessage msgStatus(CHILD_ID_STATUS, V_TEXT);
       * setup - Initialize the garage door sensor
        pinMode(UPPER_LIMIT_SENSOR, INPUT);
        pinMode(LOWER_LIMIT_SENSOR, INPUT);
        pinMode(DOOR_ACTUATOR_RELAY, OUTPUT);
        Serial.println( SKETCH_NAME );
        gw.begin( incomingMessage, AUTO );
        gw.sendSketchInfo( SKETCH_NAME, SKETCH_VERSION );
        // Register the garage door sensor with the gateway
        gw.present( CHILD_ID_OPENER, S_BINARY );
        gw.present( CHILD_ID_STATUS, S_INFO );
       * loop - The main program loop
        gw.process();
        //Get the state of the door
        getState();
        //Here we check if the state has changed and update the gateway with the change.  We do this
        //after all processing of the state because we need to know if there was an obstruction
        if (lState != cState) {
          gw.send( msgStatus.set( obstruction == true ? "OBSTRUCTION" : currentState[cState] ) );
          //Once the obstruction is checked and sent, we can clear it
          //If the current state is full open or full closed we need to set the last limit
          if ( (cState == OPEN) || (cState == CLOSED) ) {
            setLastLimit( cState );
        //If the relay is on, shut it off
        if ( digitalRead( DOOR_ACTUATOR_RELAY ) == 1) {
          relayOff();
       * incomingMessage - Process the incoming messages and watch for an incoming boolean 1
       *                   to toggle the garage door opener.
      void incomingMessage( const MyMessage &message ) {
        //We only expect one type of message from controller. But we better check anyway.
        if ( (message.type == V_STATUS) && (message.getBool() == RELAY_ON) ) {
          //Toggle the door opener
          toggleDoor();
       * toggleDoor - Used to activate the garage door opener
      void toggleDoor() {
        digitalWrite( DOOR_ACTUATOR_RELAY, RELAY_ON );
        //Keep the relay on for the amount of time defined by TOGGLE_INTERVAL
        delay( TOGGLE_INTERVAL );
       * relayOff - Used to turn off the door opener relay after the TOGGLE_INTERVAL
      void relayOff() {
        digitalWrite( DOOR_ACTUATOR_RELAY, RELAY_OFF );
        //Added this to tell the controller that we shut off the relay
        gw.send( msgOpener.set(0) );
       * getState - Used to get the current state of the garage door.  This will set the cState variable
       *            to either OPEN, CLOSED, OPENING and CLOSING
      void getState() {
        int upper = digitalRead( UPPER_LIMIT_SENSOR ); //read the upper sensor
        int lower = digitalRead( LOWER_LIMIT_SENSOR ); //read the lower sensor
        //Save the last state of the door for later tests
        lState = cState;
        //Check if the door is open
        if ((upper == HIGH) && (lower == LOW)) {
          //Set the current state to open
          cState = OPEN;
          //Check if the door is closed
        } else if ((upper == LOW) && (lower == HIGH)) {
          //Set the current state to closed
          cState = CLOSED;
          //Check if the door is in motion
        } else if ((upper == HIGH) && (lower == HIGH)) {
          //If in motion and the last full position of the door was open
          if (lLimit == OPEN) {
            //Set the current state to closing
            cState = CLOSING;
            //If in motion and the last full position of the door was closed
          } else {
            //Set the current state to opening
            cState = OPENING;
       * setLastLimit - Checks the limit passed with the last limit (lLimit) and sets the last limit
       *                if there was a change.  It also checks the states against the limits and issues
       *                an obstruction error if the limit and last limit
       * @param limit  integer limit - The limit to be checked
      void setLastLimit( int limit ) {
        //Here is where we check for our error condition
        if ( (lLimit == OPEN) && (limit == OPEN) && (lState == CLOSING) ) {
          //An obstruction has reversed the door.  No need to set the last limit because it already equals
          //the limit we are trying to set it to
          obstruction = true;
          //If we made it here and the last limit does not equal the limit we are setting then change it.  If
          //the last limit is equal to the limit we are setting then the last state was something other than
          //closing, so we don't need to do anything.
        } else if ( lLimit != limit ) {
          //Everything okay, set the last limit
          lLimit = limit;
      Dringie
      @dbemowsk Thanks for sharing
      • D Offline
        @Dringie The only thing I think that I am going to add for now is to turn this on as a repeater node. I have this wired for power with an old modified wall brick cell phone charger that was 5 volts, so it will be powered all the time. I think it is a good place for a repeater anyway. If you find any problems or can suggest any improvements, I am all ears.
        • D Offline
          Dringie
          I will also use signing when I get round to building this node.
          Waiting for the signing chips from China.
          I might add a relay for lights, so the lights come on at night when opened. (Night lua code to be used in domoticz).
          Postman feature is something I'm going over in my head. E.g.. When postman delivers a parcel I can remotely open the garage slightly and it close again after 30 secs. Not sure if I want to write code in the node or in Domoticz. I think the node would be more fail proof.
          D 1 Reply Last reply
          • D Dringie
            @Dringie What type of garage door opener do you have?
            • D dbemowsk
              Dringie
              @dbemowsk
              Hormann motor, 3 section up and over door. I have placed position magnet sensors on the door runner.
              My door works like yours with obstacles.
              I will wire my node straight into the motor.
              For the postman feature, I was going to add an extra reed switch on the runner to stop the door at a low hight.
              • D Offline
                I had some problems using magnetic reed switches with my old HA setup. My main problem was that when the door would open, it would not always stop in the same spot. It was close to that spot, but enough off where the magnet wouldn't register. That was why I dug into the opener to find the limit switches. Going that route has been a ton more reliable since I am getting the state right from where the door opener tells the door to stop.See my very first pic in this post.
                • cliffordbakerC Offline
                  cliffordbaker
                  The idea of using relay is good as relay control one electrical circuit by opening and closing contacts in another circuit. In the programing model try to give a trigger input. This would work.
                  • D Offline
                    For those interested, I have updated my sketch for my garage door controller to MySensors 2.0.
                      Originally built for MySensors 1.5 June 16,2016
                      Updated to MySensors 2.0 October 21, 2016
                            triggered.
                      PARTS LIST:
                      Arduino pro mini
                      0.1uf capacitor
                      5v reed relay
                      1k resistor
                      Relay D5
                      Version history:
                      1.2 : Added the heartbeat signal to tell the controller that the sensor is still alive.
                            Scripting or other code must be used on the HA controller side to react to the
                            heartbeat signal and take appropriate action.
                      2.0 : Converted to MySensors 2.0
                    //Set up the nRF24L01+
                    #include <SimpleTimer.h>
                    #define SKETCH_VERSION "1.2"
                    #define UPPER_LIMIT_SENSOR 6  //Pin used for input from the garage door upper limit sensor
                    #define TOGGLE_INTERVAL 1500  //Tells how many milliseconds the relay will be held closed
                    #define HEARTBEAT_INTERVAL 120000 //Number of miliseconds before the next heartbeat
                    #define CLOSED 0
                    #define OPEN 1
                    #define CLOSING 2
                    #define OPENING 3
                    #define OBSTR_MAX 20
                                                 "Closed",
                                                 "Open",
                                                 "Closing",
                                                 "Opening"
                    int cState;
                    int lState;
                    int lLimit = 0;
                    int obstruction_count = 0;
                    // the timer object used for the heartbeat
                    SimpleTimer heartbeat;
                     * presentation - Present the garage door sensor
                    void presentation() {
                    } //End presentation
                      // Set up the pins for reading the upper and lower limit sensors
                      // Set up the pin to control the door opener
                      // Set the heartbeat timer to send the current state at the set interval
                      heartbeat.setInterval(HEARTBEAT_INTERVAL, sendCurrentState);
                    } //End setup
                      getState();
                      if ((lState != cState) || obstruction == true) {
                        sendCurrentState();
                        obstruction_count ++;
                        if (obstruction_count >= OBSTR_MAX) {
                        relayOff();
                      heartbeat.run();
                    } //End loop
                     * receive - Process the incoming messages and watch for an incoming boolean 1
                    void receive( const MyMessage &message ) {
                        toggleDoor();
                    } //End receive
                     * sendCurrentState - Sends the current state back to the gateway
                    void sendCurrentState() {
                    } //End sendCurrentState
                    void toggleDoor() {
                    } //End toggleDoor
                    void relayOff() {
                    } //End relayOff
                    void getState() {
                      lState = cState;
                        cState = OPEN;
                        cState = CLOSED;
                          cState = CLOSING;
                        } else {
                          cState = OPENING;
                    } //End getState
                        obstruction = true;
                        lLimit = limit;
                    } //End setLastLimit
                    S 1 Reply Last reply
                    • D dbemowsk
                              triggered.
                        PARTS LIST:
                        Arduino pro mini
                        0.1uf capacitor
                        5v reed relay
                        1k resistor
                        Relay D5
                        Version history:
                      #define CLOSED 0
                      #define OPEN 1
                      #define CLOSING 2
                      #define OPENING 3
                                                   "Closed",
                                                   "Open",
                                                   "Closing",
                                                   "Opening"
                      int cState;
                      int lState;
                      int lLimit = 0;
                      } //End setup
                        getState();
                          sendCurrentState();
                          relayOff();
                        heartbeat.run();
                      } //End loop
                          toggleDoor();
                      } //End receive
                      void toggleDoor() {
                      } //End toggleDoor
                      void relayOff() {
                      } //End relayOff
                      void getState() {
                        lState = cState;
                          cState = OPEN;
                          cState = CLOSED;
                            cState = CLOSING;
                          } else {
                            cState = OPENING;
                      } //End getState
                          obstruction = true;
                          lLimit = limit;
                      stevefury
                      @dbemowsk hi, first off all, very nice job, i read your setup and i like what you did, but im not ready yet to master this c++ like you and i am trying to compile your sketch but i have some faults, with heartbeat interval, and maybe you can show me the way?
                      thanks
                      • S stevefury
                        thanks
                        stevefury
                        @stevefury said in Automated garage door:
                        thanks
                        nobody???
                        skywatchS 1 Reply Last reply
                        • S stevefury
                          thanks
                          nobody???
                          skywatchS Offline
                          skywatchS Offline
                          skywatch
                          ... but i have some faults, with heartbeat interval,
                          Some faults? Ah well then, that's easy to fix!
                          nobody???
                          All the psychic team are on holiday, so you will have to help those who might be willing to help you. So.....
                          1. Post the code (in full) that you have problems with (use code tags </>).
                          2. Post the detailed messages for the errors you enounter.
                          3. Tell us exactly what is wrong and/or why you think it is wrong and what you are expecting.
                          • skywatchS skywatch
                            nobody???
                            zboblamontZ Offline
                            zboblamontZ Offline
                            zboblamont
                            @skywatch :sweat_smile:
