  3. MySensors Newbie Questions
5 Posts 2 Posters 1.4k Views 3 Watching
  • CrankyCoderC
    CrankyCoderC
    CrankyCoder
    I normally don't post multiple questions in 1 post. But most of these are of the type "can mysensors ______" so yes and now will lead me to creating other posts :)
    So here we go!!
    1. can mysensors acknowledge receipt of a command?
    2. is it possible to have multiple gateway devices setup for fault tolerance?
    3. can mysensors "sensor/buttons" speak directly to another node without going through the gateway?
    Thanks!!!
    Very excited to have come across mysensors!
    Home Automation Tinkerer
    www.CrankyCoder.net
    Gateway: MQTTClientGateway
    MySensors: 2.3
      Welcome @Jason-Brunk
      1. Yes
      2. No
      3. Depends on you topology. A sensor always sends to its parent node. If a route to the other node exists in the parent it will direct it without deliver the message further back in the hierarchy.
      Gateway -> Repeater -> Node A
                       \-> Node B
      A sending to B will will only pass Repeater.
      • CrankyCoderC
        CrankyCoderC
        CrankyCoder
        Thank you for the welcome :)
        1. sweet - any links where I can read up on this?
        2. bummer - but definitely not a deal breaker :)
        3. i see, that makes sense.
        www.CrankyCoder.net
        MySensors: 2.3
          See "Sending data" here:
          https://www.mysensors.org/download/sensor_api_15#the-full-api
          Second argument to send() enables end-to-end ack.
          • CrankyCoderC
            CrankyCoderC
            CrankyCoder
            awesome!! thank you!
            www.CrankyCoder.net
            MySensors: 2.3
