  3. How to find out if message was successfully delivered?
13 Posts 6 Posters 5.0k Views 6 Watching
  • A
    A
    arraWX
    I did successfully build the Power Meter Pulse Sensor and use it with Domoticz.
    Next, I would like to have a LED on the sensor indicate whether messages are successfully delivered (e.g one blink) or not (e.g. three blinks).
    As far as I understand the ack should be set true while sending. E.g.
    gw.send(kwhMsg.set(kwh, 4)),true)
    However, I cannot figure out how to evaluate the result. I.e. if the destination node send ack back.
    BartEB F B 3 Replies Last reply
    • A arraWX
      BartEB
      BartEB
      BartE
      wrote on last edited by BartE
      Hi @arraWX
      When you set the ack boolean to true while sending a message the gateway will return the message with the ACK bit set.
      So you have to handle this message with code like this
      setup ()
         ... do stuff
        ... do more stuff
        if (message.isAck()) {
            if (message.sensor == YOUR_KWH_SENSOR_ID) {
                   toggleLed();
      F 1 Reply Last reply
      • A arraWX
        F
        F
        flopp
        @arraWX
        I solved it by doing this, it is just a few rows from the sketch
        MyMessage voltage_msg(CHILD_ID_BATTERY, V_VOLTAGE);
        gw.present(CHILD_ID_BATTERY, S_MULTIMETER);
        int sensorValue = analogRead(A0);
        float batteryVolt=sensorValue*(3.3/1023);
        resend((voltage_msg.set(batteryVolt, 3)), 10);
        void resend(MyMessage &msg, int repeats)
          int repeat = 1;
          int repeatdelay = 0;
          boolean sendOK = false;
          while ((sendOK == false) and (repeat < repeats)) {
            if (gw.send(msg)) {
              sendOK = true;
            } else {
              sendOK = false;
              Serial.print("Error ");
              Serial.println(repeat);
              repeatdelay += 500;
            } repeat++; delay(repeatdelay);
        which means, it will send batteryVolt with 3 decimals to Controller and try 10 times.
        If it doesn't get OK after 10 times it will not try again until it is time to send data next time.
        • A arraWX
          B
          B
          boozz
          @arraWX
          You could also use code like this:
          bool delivered = gw.send(kwhMsg.set(kwh, 4)),true);
          if !(delivered){
          // put code here to take corrective actions, ...
          BR,
          Boozz
          BartEB 1 Reply Last reply
          • B boozz
            @arraWX
            if !(delivered){
            BR,
            Boozz
            BartEB
            BartEB
            BartE
            @boozz and @flopp what you check here is that the message successfully was broadcast-ed to the next node.
            This can be either the gateway or a repeater node.
            With the reception of an acknowledge message you are sure that the original message was delivered at the gateway (and back).
            • BartEB BartE
              F
              F
              flopp
              wrote on last edited by flopp
              @BartE
              Oh, then my check is just half way.
              I will test with your ACK, seems the best solution to confirm that it was sent OK
              • F flopp
                @BartE
                BartEB
                BartEB
                BartE
                @flopp
                Here is a reliable delivery discussion with more information
                  The reliable delivery stuff in MySensors is utterly confusing. In the discussion BartE linked to there is this post which suggested ways to prevent even more people from being confused by the documentation and code. Unfortunately, it turned out that 2 and 3 had already been done in the development version, but it is not available in the official documentation since the development version hasn't been made stable yet. Learning that all my hard work was in vain really pissed me off.
                  I am really sorry that you also had to learn the hard way how this stuff works.
                  • F
                    F
                    flopp
                    I have tested around now.
                    Domoticz on RPi 3.5273
                    Mysensors 1.5.1
                    Arduino UNO(clone) NRF24+ with 100uF cap
                    And what I see is that a acknowledge is working better if the value change since last time, strange.
                    float temp=0;
                    #define CHILD_ID_TEMP 1
                    unsigned long SLEEP_TIME = 10000; // Sleep time between reads (in milliseconds)
                      gw.begin(incomingMessage, AUTO);
                      gw.sendSketchInfo("Humidity", "9",true);
                      gw.present(CHILD_ID_TEMP, S_TEMP,"def" ,true);
                    temp=temp+0.2;
                    gw.send(msgTemp.set(temp, 1),true);
                    gw.wait(SLEEP_TIME);
                    Debug output
                    send: 22-22-4-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
                    send: 22-22-4-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:4
                    read: 0-4-22 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                    sensor started, id=22, parent=4, distance=2
                    send: 22-22-4-0 s=255,c=3,t=11,pt=0,l=8,sg=0,st=ok:Humidity
                    send: 22-22-4-0 s=255,c=3,t=12,pt=0,l=1,sg=0,st=ok:9
                    send: 22-22-4-0 s=1,c=0,t=6,pt=0,l=3,sg=0,st=ok:def
                    send: 22-22-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:0.2
                    read: 0-4-22 s=255,c=3,t=11,pt=0,l=8,sg=0:Humidity
                    read: 0-4-22 s=255,c=3,t=12,pt=0,l=1,sg=0:9
                    read: 0-4-22 s=1,c=0,t=6,pt=0,l=3,sg=0:def
                    read: 0-4-22 s=1,c=1,t=0,pt=7,l=5,sg=0:0.2
                    send: 22-22-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:0.4
                    read: 0-4-22 s=1,c=1,t=0,pt=7,l=5,sg=0:0.4
                    send: 22-22-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:0.6
                    read: 0-4-22 s=1,c=1,t=0,pt=7,l=5,sg=0:0.6
                    send: 22-22-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:0.8
                    read: 0-4-22 s=1,c=1,t=0,pt=7,l=5,sg=0:0.8
                    send: 22-22-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:1.0
                    read: 0-4-22 s=1,c=1,t=0,pt=7,l=5,sg=0:1.0
                    send: 22-22-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:1.2
                    read: 0-4-22 s=1,c=1,t=0,pt=7,l=5,sg=0:1.2
                    send: 22-22-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:1.4
                    read: 0-4-22 s=1,c=1,t=0,pt=7,l=5,sg=0:1.4
                    send: 22-22-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:1.6
                    read: 0-4-22 s=1,c=1,t=0,pt=7,l=5,sg=0:1.6
                    Same value every send, same sketch but I removed temp=temp+0.2
                    Debug output
                    send: 22-22-4-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:0.0
                    read: 0-4-22 s=1,c=1,t=0,pt=7,l=5,sg=0:0.0
                    • BartEB BartE
                      Hi @arraWX
                      setup ()
                         ... do stuff
                        ... do more stuff
                                   toggleLed();
                      F
                      F
                      flopp
                      you can actually remove TRUE, that mean this is a Repeater Node
                      • A
                        A
                        arraWX
                        A big thanks to all of you! I learned a lot from your answers.
                        For now I think that hardware ack is sufficient. I can now place a sensor in different locations and tell from its LED wether or not messages are recieved by the gateway (I have no repeater nodes yet).
                        • Mark SwiftM
                          Mark SwiftM
                          Mark Swift
                          wrote on last edited by Mark Swift
                          @arraWX Can you given an example of a sketch you run with the LED logic in?
                          A 1 Reply Last reply
                          • Mark SwiftM Mark Swift
                            A
                            A
                            arraWX
                            @Mark-Swift In the sensebender sketch I replaced
                            gw.send(msgTemp.set(temperature,1));
                            with
                                if(gw.send(msgTemp.set(temperature,1)))
                                  digitalWrite(LED_PIN,LOW);
                                else
                                  digitalWrite(LED_PIN,HIGH);
                            LED is OFF if meassages are successfully delivered. LED turns ON if meassage delivery fails and stays ON until a new meassage is successfully delivered.
                            Note that I use mysensors 1.5 as I did not yet update to mysensors 2.0. In 2.0 gw. is not needed
