  3. Relay with sleep..
Relay with sleep..
4 Posts 3 Posters 2.0k Views 3 Watching
  • C
    C
    cablesky
    Can i use the Relay-Sketch with the Sleep-Function?
    I would like check every 5 Minutes, if the switch for the relay is changed. If the switch is changed, then the relay switch.
    I use mysensors with FHEM.
    Anybody know that?
    KoreshK 1 Reply Last reply
      There is a new feature called "smart sleep" coming in 2.0, but it must be supported by the controller which has to buffer messages and send them when node wakes up.
      It's probably not supported by FHEM yet.
      • C
        C
        cablesky
        @hek : Thank you!
        I use the RFM69-Module with the 2.0 API. The Serial-Controller for FHEM use an Arduino Mini Pro with RFM69.
        Who knows, if this support SmartSleep?
        • C cablesky
          Anybody know that?
          KoreshK
          KoreshK
          Koresh
          Anybody know that?
          Hm. Very interesting. Can you clarify a little what its purpose is. Thanks :)
