  3. Newbie trying to compile a sketch/installing mysensors library
5 Posts 3 Posters 1.6k Views 3 Watching
  • blebbensB
    blebbensB
    blebbens
    I´m trying to build my first mqtt-Gateway using an arduino nano V3 clone and a ethernet W5100 shield.
    Downloaded the arduino-master.zip and unzipped it into the sketchbook directory. But, arduino IDE tells me on startup that it´s not a valid library.
    Afterwards I tried to use codebender on chrome. By clicking the run on arduino button, codebender tells me the same like the Arduino IDE itself:
    "(sketch file) MQTTGateway.ino:77:10: fatal error: 'DigitalIO.h' file not found
    #include <DigitalIO.h>
    1 error generated."
    Little help would be great...
    • TheoLT
      TheoLT
      TheoL
      How did you install the mySensors library?
      • blebbensB blebbens
        1 error generated."
        @blebbens Instructions are available at https://www.mysensors.org/about/arduino#installing-the-sensor-libraries (not sure if you've already used them)
        • blebbensB
          blebbensB
          blebbens
          Think, the description is a bit confusing. Watched the video and copied Arduino-master.zip´s directory libraries to /user/documents/arduino/libraries and c:\program files(x86)\arduino\libraries.
          Now on compiling I get the following (german) message:
          WARNUNG: Kategorie '' in der Bibliothek UIPEthernet ist ungültig und wird auf 'Uncategorized' festgelegt
          Mehrere Bibliotheken wurden für "MsTimer2.h" gefunden
          Benutzt: C:\Users\R\Documents\Arduino\libraries\MsTimer2
          Nicht benutzt: F:\Program Files (x86)\Arduino\libraries\MsTimer2
          Mehrere Bibliotheken wurden für "DigitalIO.h" gefunden
          Benutzt: C:\Users\R\Documents\Arduino\libraries\DigitalIO
          Nicht benutzt: F:\Program Files (x86)\Arduino\libraries\DigitalIO
          Mehrere Bibliotheken wurden für "MySigningNone.h" gefunden
          Benutzt: C:\Users\R\Documents\Arduino\libraries\MySensors (used)
          Nicht benutzt: F:\Program Files (x86)\Arduino\libraries\MySensors (not used)
          • blebbensB
            blebbensB
            blebbens
            I copied the libraries to 2 directories, so the IDE finds 2 versions of the same library.
            But, the first message seems to be the problem:
            WARNING: category '' in library UIPEthernet not valid and will be categorized as 'Uncategorized'
