  2. Announcements
  3. Converting a sketch from 1.5.x to 2.0.x
52 Posts 21 Posters 38.0k Views 26 Watching
  • Maurizio ColluM Maurizio Collu
    @martinhjelmare
    Thanks Martin.
    I uploaded the GatewaySerial to the arduino working as gateway, but if I upload the sketch and I open the monitor, I obtain this error:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;!TSM:RADIO:FAIL
    0;255;3;0;9;!TSM:FAILURE
    0;255;3;0;9;TSM:PDT
    What does it mean?
    martinhjelmareM
    martinhjelmareM
    martinhjelmare
    @Maurizio-Collu said:
    @martinhjelmare
    Thanks Martin.
    0;255;3;0;9;TSM:PDT
    What does it mean?
    @tekka knows this best, and he wrote a post explaining some of those messages here:
    https://forum.mysensors.org/topic/4347/can-t-get-sensors-talking/3
    Maurizio ColluM 1 Reply Last reply
      @martinhjelmare
      Thanks Martin.
      0;255;3;0;9;TSM:PDT
      What does it mean?
      Maurizio ColluM
      Maurizio ColluM
      Maurizio Collu
      @martinhjelmare Thanks a ot.
      Is there any guide/manual where all these messages are explained?
      Plus, is there anywhere written what all these terms mean?
      TSP:MSG:SEND 255-255-0-0 s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=ok:
      Kind Regards
      mfalkviddM tekkaT 2 Replies Last reply
        Kind Regards
        @Maurizio-Collu do you mean except the link martinhjelmare provided?
          Maurizio ColluM
          Maurizio ColluM
          Maurizio Collu
          @mfalkvidd Yes, basically this part (I'm sure it is explained somewhere, but I can't find where)
          SOrry for my newbieness...
            Kind Regards
            tekkaT
            tekkaT
            tekka
            wrote on last edited by tekka
            #45
            @Maurizio-Collu Yes, the doc is in preparation, the meaning of these messages is described here (this is a PR that harmonizes the log message and will be pushed to 2.0.1).
            In brief:
            TSP:MSG:SEND refers to message sending function in the transport state machine
            255-255-0-0 is the routing information, i.e. sender-last-next-destination
            • s=sensor ID (255 = internal)
            • c=command (3 = C_INTERNAL)
            • t=type (3 = I_ID_REQUEST)
            • pt=payload type (0 = P_STRING)
            • l=message length (0)
            • sg=signature flag (0 = not signed)
            • ft=failed transmission counter (0 = no failed uplink transmission at this* oint)
            • st=send status (OK)
            • : actual message (empty)
            => Your node has no assigned ID (=255) and is requesting a new ID from the controller.
            Please refer to the serial protocol or API for additional information.
            Good luck!
            • pndgt0P
              pndgt0P
              pndgt0
              I was trying to implement the irrigation controller but realized that was not migrated to MySensors 2.0.
              I followed the instructions provided in the first post and arrived to a version that compiles with no errors. Nonetheless, as I am newbie, I would appreciate if someone could review some changes that I am not sure about. Those changes are related with the original sketch which has direct calls to process() in several while statements. First I tried to change the process() with _process() but several errors appeared, so finally I removed all the calls to process() but am not sure. I have the modified code here IrrigationController.ino in which I commented the lines added / deleted / modified. Any help / direction would be greatly appreciated.
              Boots33B 1 Reply Last reply
              • pndgt0P pndgt0
                Boots33B
                Boots33B
                Boots33
                @pndgt0
                The sketches that require external libraries are not included in the V2 install anymore but they are available here in the new V2 format. You will find the irrigation sketch there.
                pndgt0P 1 Reply Last reply
                • Boots33B Boots33
                  @pndgt0
                  pndgt0P
                  pndgt0P
                  pndgt0
                  @Boots33 Great! Thank you for the quick response and the URL. I took that version. Just wanted to let you know that to successfully compile it was needed to remove the #include <LiquidCrystal.h> and probably an update to that sketch would be needed at Github respository.
                  Thank you again!
                  • pndgt0P pndgt0
                    Thank you again!
                    Boots33B
                    Boots33B
                    Boots33
                    @pndgt0 That may be because you do not have the LiquidCrystal library installed. They have the external libraries there as well
                    • paqorP
                      paqorP
                      paqor
                      This post is deleted!
                      • siodS
                        siodS
                        siod
                        wrote on last edited by siod
                        #51
                        I built a 2.0 MQTT gateway and am experimenting with a sensor using 1.5 library. I can see incoming data in the serial monitor, but the data is a bit different then when I was using the 1.5 MQTT gateway. In openhab I used this:
                        {mqtt="<[mysensor:MyMQTT/3/2/1/V_TRIPPED:state:CLOSED:1],<[mysensor:MyMQTT/3/2/1/V_TRIPPED:state:OPEN:0]"}
                        But now I must skip the V_Tripped part to make it work like this:
                        {mqtt="<[mysensor:mygateway1-out/3/2/1/0/16:state:OPEN:1],<[mysensor:mygateway1-out/3/2/1/0/16:state:CLOSED:0]"}
                        Is this how it is supposed to be or do I have to make the sensor node 2.0 compatible first? I thought the payload is saved in the V_TRIPPED variable, but it doesn´t seem to work in the new 2.0 library. Pls advise-
                        edit:
                        Ok, digged a bit deeper: if I understand it right, I don´t need "V_TRIPPED" or any other value in my controllers code (which is openhab actually) anymore but still in my sensor node code of course. So the gateway will transform "V_Tripped" into sub-typ "16". Correct? So all I´ll have to change is my openhab code, right?
                        still learning...
                        YveauxY 1 Reply Last reply
                        • siodS siod
                          edit:
                          YveauxY
                          YveauxY
                          @siod correct. The conversion of value code to text has been removed in the 2.0.0 implementation, so now the raw values codes are reported in the topic.
