  3. Unable to get simple Gateway + Button Sensor to work together
2 Posts 2 Posters 1.2k Views 3 Watching
  • thekeenoT
    thekeenoT
    thekeeno
    wrote on last edited by thekeeno
    Hi all,
    I started testing a simple configuration with a Serial Gateway and Binary Switch Sensor and I'm unable to get the two devices to interact with each other.
    The gateway is an Uno linked to a standard (no antenna) NRF24L01+ with a 47uF cap across 3v3 and GND. The code on it looks like so:
     * LEDs (OPTIONAL):
     * - To use the feature, uncomment MY_LEDS_BLINKING_FEATURE in MyConfig.h
    // Enable serial gateway
    #define MY_GATEWAY_SERIAL
    #if F_CPU == 8000000L
    #define MY_BAUD_RATE 38400
    // Flash leds on rx/tx/err
    // Set blinking period
    // Enable inclusion mode
    The sensor is an Uno linked to a standard (no antenna) NRF24L01+ with a 47uF cap across 3v3 and GND. Code on it is as so:
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "0"
    #define PRIMARY_CHILD_ID 3
    #define SECONDARY_CHILD_ID 4
      // Setup the buttons
      // Activate internal pull-ups
      present(SECONDARY_CHILD_ID, S_DOOR);
      uint8_t value;
      static uint8_t sentValue=2;
      static uint8_t sentValue2=2;
      sleep(5);
      if (value != sentValue) {
         send(msg.set(value==HIGH ? 1 : 0));
         sentValue = value;
      if (value != sentValue2) {
         send(msg2.set(value==HIGH ? 1 : 0));
         sentValue2 = value;
      sleep(PRIMARY_BUTTON_PIN-2, CHANGE, SECONDARY_BUTTON_PIN-2, CHANGE, 0);
    I managed to get the gateway to interact with both Domoticz and Home Assistant but neither reported the button to exist. I checked the serial output. On the gateway it says:
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:RADIO:OK
    0;255;3;0;9;TSM:GW MODE
    0;255;3;0;9;TSM:READY
    0;255;0;0;18;2.0.0
    0;255;3;0;9;TSP:SANCHK:OK
    On the Sensor it says:
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSP:MSG:SEND 255-255-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR
    !TSM:FPAR:FAIL
    !TSM:FAILURE
    TSM:PDT
    TSM:INIT
    TSM:RADIO:OK
    TSM:FPAR
    TSM:FPAR
    How should I interpret this error? Can't find anything on specific debug messages in the FAQ.
    Sketches were uploaded from a computer running Win 10 Home, Arduino 1.6.9 and MySensors 2.0.0 and all the code used above is copied near-verbatim from the MySensors examples.
    Is there any way for me to verify that the problem doesn't lie with my NRF24L01+ devices themselves?
    All help is massively appreciated!
    tekkaT 1 Reply Last reply
    • thekeenoT thekeeno
      Hi all,
       * LEDs (OPTIONAL):
        uint8_t value;
        sleep(5);
           sentValue = value;
           sentValue2 = value;
      0;255;0;0;18;2.0.0
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR
      !TSM:FPAR:FAIL
      !TSM:FAILURE
      TSM:PDT
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR
      tekkaT
      tekkaT
      tekka
      @thekeeno You can enable verbose mode for the nRF24:
      #define MY_DEBUG_VERBOSE_RF24
      Please enable it for both, GW and node, and post the debug log here. Thanks.
