  3. Node is not using repeater to talk to gateway
42 Posts 3 Posters 10.5k Views 1 Watching
  • K Offline
    K Offline
    karl261
    Total madness: I uploaded the same sketch again, and now it is using 99.
    Questions:
    1. Can I see in the log whether it "found" the parent or if it is using the parent I put into the sketch?
    2. Is it possible to avoid this transport failure counter? Like, when I put
      #define MY_PARENT_NODE_ID 99
      into my sketch I just want the node to send, whether it reaches the parent or not. Is that possible?
    • K karl261
      @tekka But now I found something: the repeater sketch does not work, if MY_DEBUG is commented out. I tried several times forth and back. On the gw I get the output below.
      0;255;3;0;9;TSP:MSG:READ 99-99-255 s=255,c=3,t=7,pt=0,l=0,sg=0:
      0;255;3;0;9;TSP:MSG:BC
      0;255;3;0;9;TSP:MSG:FPAR REQ (sender=99)
      0;255;3;0;9;TSP:CHKUPL:OK
      0;255;3;0;9;TSP:MSG:GWL OK
      0;255;3;0;9;!TSP:MSG:SEND 0-0-99-99 s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=fail:0
      0;255;3;0;9;TSP:CHKUPL:OK (FLDCTRL)
      K Offline
      K Offline
      karl261
      I checked and re-programmed the repeater. It seems that it has gone away. I can use my repeater without MY_DEBUG. I don't know what caused this, but the repeater is working now.
